add_group slow on mac
Postby GWD » Sat Dec 24, 2011 7:03 am
I've a script that runs good on my PC. But when my friend uses it on his mac with the same model it's much slower (more than 10x). After a lot of testing to narrowed down the problem, adding a group with add_group on a big model is much slower on mac than on pc. How can we avoid this problem?
GWD
PluginStore Author
PluginStore Author
Re: add_group slow on mac
Postby thomthom » Sat Dec 24, 2011 1:11 pm
Are you sure it's add_group being slow?
Are you by any chance also using Sketchup.status_text as well? Updating the progress of your script?
Do you have a sample script you're testing with?
PluginStore Author
PluginStore Author
Postby GWD » Sat Dec 24, 2011 1:53 pm
thomthom wrote:Are you sure it's add_group being slow?
We use indeed the Sketchup.status_text in our script for updating the progress. But this isn't to problem because the problem also occurs with te following simple script.
Create a model with 1000 solids and run the following script:
model = Sketchup.active_model
entities = model.entities
for n in 1..1000 do
g = entities.add_group
g.name = n.to_s
point1 = Geom::Point3d.new(n*10,0,0)
c = g.entities.add_cpoint point1
g.explode
On PC this goes fast, on mac this takes a very long time.
GWD
PluginStore Author
PluginStore Author
Postby thomthom » Sat Dec 24, 2011 2:17 pm
hm... will have to have a look...
as for status text: viewtopic.php?f=180&p=305388#p305248
PluginStore Author
PluginStore Author
Postby th3lurker » Wed Jan 18, 2012 8:07 am
I've had the same problem. I wrote an import tool for a custom format, and add_group (if i create a group for each volume) or add_face/add_point(if i create just one main group, and keep adding to that) greatly slows down the import. It gets exponentially slower (1.2 secs for 100 volumes, 120 seconds for 1400, 0.02 secods/add_group in the beginning, ~0.2 seconds/add_group near the end). I tested this with the GWD's code, and even without all my other code, it is just as slow. Any ideas/ workarounds? I work on windows vista (not my fault :D ).
th3lurker
Postby Dan Rathbun » Wed Jan 18, 2012 12:13 pm
You might try saving the model to a temp file, after each group. That should clear the undo stack.
The file must have a name other than "Untitled" or the save dialog will popup.
Also use the disable_ui flag in an operation:
Code: Select all
disable_ui = true
PC =( RUBY_PLATFORM =~ /(mswin|mingw)/ ? true : false )
save = true
for n in 1..1000 do
  begin
    model.start_operation("Group#{n}",disable_ui)
    g.name = n.to_s
    g.explode
  rescue
    model.abort_operation
  else
    model.commit_operation
    # opt save model here
    if save
      if PC
        Sketchup.send_action(57603)
      else # Mac
        Sketchup.send_action("saveDocument:")
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby thomthom » Wed Jan 18, 2012 12:28 pm
    Dan Rathbun wrote:
    Code: Select all
          if PC
          else # Mac
            # may be convoluted on Mac
    Why not use Model.save ?
    http://code.google.com/apis/sketchup/do ... .html#save
    And I don't see how saving would free up the undo stack. :?: Seems to operate the same after a save...
    I don't think saving has any effect - it's SketchUp that process existing geometry whenever new is added in order for auto-merge to work.
    PluginStore Author
    PluginStore Author
    Postby Dan Rathbun » Wed Jan 18, 2012 1:38 pm
    thomthom wrote:Why not use Model.save ?
    I was under the impression that the API would not let use use that method to overwrite the current file. But I just tested it and yes, it does work.
    thomthom wrote:And I don't see how saving would free up the undo stack. :?: Seems to operate the same after a save...
    And, your're correct again. (Maybe I made an assumption.) On PC we can clear the undo stack by saving, then asking for a new model, then reloading the old model. (The API does not have a method to close the active model, yet. So it may be a no go on Mac.)
    Here's an updated example:
    Code: Select all
    disable_ui = true
    save = true
    if save
      path = UI.savepanel("Save Model to","*.skp")
      if path.nil?
        save = false
      else
        path = File.expand_path(path)
    for n in 1..1000 do
      begin
        g.name = n.to_s
        g.explode
      rescue => e
        puts("Error #<#{e.class.name}: #{e.message}>")
        puts(e.backtrace)
      else
        if save
          Sketchup.active_model.save(path)
          Sketchup.file_new
          Sketchup.open_file(path)
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby Dan Rathbun » Wed Jan 18, 2012 1:55 pm
      Is it explode that is slow ? Or adding group definitions ?
      If making groups (and explode) is avoided, is it still as slow ?
      Does turning off shadows and textures speed things up ?
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Postby TIG » Wed Jan 18, 2012 2:02 pm
        There are issues with model.save.
        It only saves by name, but not path obtained using File from model.path etc.
        It does NOT save by the name of the current SKP, although it returns 'true'...
        To test this make a simple SKP and save it as 'aaa.skp'.
        model=Sketchup.active_model
        Dir.pwd
        ### if not where aaa.skp is located use
        Dir.chdir(File.dirname(model.path))
        ### now use
        model.save("xxx.skp")### it saves a copy as xxx.skp
        ### you are still inside aaa.rb
        model.save(File.basename(model.path))### saves as itself - aaa.skp [supposedly, as it returns 'true' !]
        ### Now edit the SKP with a noticeable change, and repeat
        Exit without saving further...
        xxx.skp WILL show the changes
        aaa.skp will NOT show the changes, that it said were saved, BUT were not!
        Global Moderator
        Postby thomthom » Wed Jan 18, 2012 2:03 pm
        Dan Rathbun wrote:Is it explode that is slow ? Or adding group definitions ?
        Both. Adding geometry gets slower and slower in SU. When you explode you take the entities from one context and add it to another - so it suffers from the same slowdown of adding them.
        Dan Rathbun wrote:Does turning off shadows and textures speed things up ?
        It seems to be that SU processes all existing geometry when anything is added to a context.
        PluginStore Author
        PluginStore Author
        Postby Dan Rathbun » Wed Jan 18, 2012 2:17 pm
        TIG wrote:There are issues with model.save.
        Thanks TIG... I knew you had expounded on this subject before.. and tried to get the Google team to fix this save BS.
        Well, the example above at least DOES clear the undostack on PC...
        which is why (ThomThom) I originally used the send_action for the PC menu's "Save" option. (Which does work.)
          Dan Rathbun
          PluginStore Author
          PluginStore Author
          Postby thomthom » Wed Jan 18, 2012 2:19 pm
          Dan Rathbun wrote:which is why (ThomThom) I originally used the send_action for the PC menu's "Save" option. (Which does work.)
          ...under Windows only...
          :roll: *sigh* the Ruby API makes my head ache all too often...
          PluginStore Author
          PluginStore Author
          Postby Dan Rathbun » Wed Jan 18, 2012 2:20 pm
          YUP. On PC, Sketchup.send_action("save:") returns false. I wonder what the standard action is for Mac ?
          Dittos.. on the API.
            Dan Rathbun
            PluginStore Author
            PluginStore Author
            Postby thomthom » Wed Jan 18, 2012 2:26 pm
            I wish that PolygonMesh had more features in the Ruby API. In the C++ SDK you can define more info when you create the mesh. Under the Ruby API you are more limited.
            One example, you can retrieve the mesh of any geometry - from that you can get info on hidden/soft edges and UV mapping. But you cannot create a mesh with UV mapping or control hidden/smooth. That severely limits the usability of PolygonMesh as a method of creating geometry.
            So either complex and very slow geometry creation, or simple and less slow creation.
            Or use the C++ API - ...which require C++ knowledge... :( Slower development...
            PluginStore Author
            PluginStore Author
            Postby Dan Rathbun » Wed Jan 18, 2012 4:07 pm
            Dan Rathbun wrote:YUP. On PC, Sketchup.send_action("save:") returns false. I wonder what the standard action is for Mac ?
            Ok.. it's Sketchup.send_action("saveDocument:") (at least it works on PC, and is listed on the Apple site as an action for the NSDocument class.)
              Dan Rathbun
              PluginStore Author
              PluginStore Author
              Postby GWD » Wed Jan 18, 2012 9:33 pm
              the Sketchup.send_action("saveDocument:") works on mac!
              GWD
              PluginStore Author
              PluginStore Author
              Postby TIG » Thu Jan 19, 2012 11:42 am
              BUT saveDocument simply saves the current SKP and leaves the undo stack alone.
              IF we use
              pwd=Dir.pwd
              so we don't need to worry about full paths etc...
              Then use
              skp=File.basename(model.path)
              tmp=rand.to_s+File.basename(model.path)
              model.save(tmp)
              Sketchup.open_file(tmp)
              Sketchup.open_file(skp)
              on completion tidy up
              File.delete(tmp) if File.exist?(tmp)
              Dir.chdir(pwd)
              it will cause the "undo stack" to empty ! :shock:
              BUT at the expense of the time delay of saving/opening/etc etc...
              There seems no easy way to clear the "undo stack" otherwise... :?
              Global Moderator
              Postby thomthom » Thu Jan 19, 2012 12:33 pm
              And we have no signs of "clearing the undo stack" will actually improve the performance of adding geometry, do we?
              PluginStore Author
              PluginStore Author
              Postby driven » Fri Jan 20, 2012 2:22 am
              GWD wrote:the Sketchup.send_action("saveDocument:") works on mac!
              Was this a query? if so, the answer is yes, normally, but the way Dan has used it in the earlier snippets, the Dialog appears, but fails to change the windows name and the script then really does strange things in 'no mans land'
              i.e. it's not 'Untitled Window', or your given name, just 'Sketchup'. The cursor pulses, the view disintegrates[holes appeared] then the whole computer freezes... repeatable, yes but I'll pass.
              In my curiosity to learn some ruby, I cobbled together some additional test scripts and ran them on my mac.
              Script 1: 1.52668809890747 and generates 2000 undo steps #### this is the original from this thread
              Script 2: 0.175029039382935 and generates 1001 undo steps
              Script:3: 0.419209957122803 and generates 2 undo steps
              Script 4: 0.0664420127868652 and generates 2 undo steps #### this uses disable_ui and draws after the timer stops, so add 0.04 maybe...
              My scripts a probably really badly constructed, but they reliably return this similar timings... john
              Code: Select all
              # timer snippet from http://stackoverflow.com/questions/2289381/how-to-time-an-operation-in-milliseconds-in-ruby
              def time
                now = Time.now.to_f
                yield
                endd = Time.now.to_f
                endd - now
              time{
              # This code draws a line of points in 1.52668809890747
              # and generates 2000 undo steps
              for n in 1..1000 do
               g.name = n.to_s
               point1 = Geom::Point3d.new(n*1,0,0)
               g.explode
              def time
                now = Time.now.to_f
                yield
                endd - now
              time{
              # This code draws a line of points in 0.175029039382935
              # and generates 1001 undo steps
               entities = model.active_entities
               centerpoint = Geom::Point3d.new
               full_group = entities.add_group()
               (0..1000).each do |i|
               # Create a line of points
               centerpoint = [i*1,10,0]
               full_group.entities.add_cpoint centerpoint
              full_group.explode
              def time
                now = Time.now.to_f
                yield
                endd - now
              time{
              # This code draws a line of points in  0.389806985855103 on mac
              # and generates 2 undo steps
              require 'sketchup.rb'
              require 'LangHandler.rb'
              # Using language handler makes sure that the string "Create Line" gets translated.
              # This is important as this string is shown in undo menu.
              $make_cp_line_string = LanguageHandler.new("gettingstarted.strings");
              def cp_line()
                   selection = model.selection
                # Create a transaction so the box is one undo
                model.start_operation($make_cp_line_string.GetString("Create cp_Line"))
                points_group = entities.add_group()
                entities = points_group.entities
               centerpoint = [i*1,20,0].to_a
               c_pl = points_group.entities.add_cpoint centerpoint
               points_group.name = "Points Group"
               points_group.description = "Example Group"
               selection.add points_group
               end #create
              cp_line
              selection.length
              selection.each { |entity| (entity.explode) }
              def time
                now = Time.now.to_f
                yield
                endd - now
              time{
              # This code draws a line of points in 0.0667488574981689 with disable_ui on mac
              $make_dcp_line_string = LanguageHandler.new("gettingstarted.strings");
              def dcp_line()
                   disable_ui = true
                model.start_operation($make_dcp_line_string.GetString("Create cp_Line"),disable_ui)
                dis_pnts_group = entities.add_group()
                entities = dis_pnts_group.entities
               centerpoint = [i*1,30,0].to_a
               dc_pl = dis_pnts_group.entities.add_cpoint centerpoint
               dis_pnts_group.name = "Dis Points Group"
               dis_pnts_group.description = "Example 2 Group"
               selection.add dis_pnts_group
               end #create
              dcp_line
              selection.length
              disable_ui = false
              driven
              PluginStore Author
              PluginStore Author
              Postby Dan Rathbun » Fri Jan 20, 2012 2:04 pm
              Well, John, you've proved that disable_ui is much faster that not.
              But the topic is about that add_group and explode group is slow. Which you've also proved, of course, by testing the same entity generation within only 1 group and then exploding it AFTER the loop.
              I only speculated that Sketchup's writing to the Undo stack (and Undo Log file,) might slow things down.
              There is a registry entry on PC for "MaxUndo" (under the "Preferences" key,) which is set to 100 by default. There is no UI control to change this "on-the-fly." (And likely Sketchup would not see any change to the attribute while running.) But I wonder if setting it to 0 before startup would it disable the undo feature all together ?? (I don't know what it's called in the Mac plist.)
              But, regardless, ThomThom believes that it's not the undo stack, but instead the way the app seems to resort the model database, during add groups and explodes.
              What if all the temp groups, were first added to a master group (to separate them from the rest of the model, and then after the loop, the master group was exploded ?)
                Dan Rathbun
                PluginStore Author
                PluginStore Author
                Postby Dan Rathbun » Fri Jan 20, 2012 2:22 pm
                Dan Rathbun wrote:There is a registry entry on PC for "MaxUndo" (under the "Preferences" key,) which is set to 100 by default. There is no UI control to change this "on-the-fly." (And likely Sketchup would not see any change to the attribute while running.) But I wonder if setting it to 0 before startup would it disable the undo feature all together ?? (I don't know what it's called in the Mac plist.)
                I just tried this.. set "MaxUndo" to 0 before SU start.
                The undo operations do NOT appear on the Edit menu.
                Sketchup still writes to the undo log, but after each tool operation, it writes a "Commit(0)" line.
                Changing the attribute back to 100 while Sketchup is running has no effect (as I suspected.) And Sketchup will rewrite it's "live" "MaxUndo" value of 0, back to the registry attribute. So you must change it back to whatever limit you wish, while Sketchup is closed, in order to turn the Undo feature back on.
                  Dan Rathbun
                  PluginStore Author
                  PluginStore Author
                  Postby Dan Rathbun » Fri Jan 20, 2012 2:25 pm
                  Also, note. When "MaxUndo" is 0, calling Sketchup.send_action("editUndo:") still returns true, but nothing happens. (At least it does not BugSplat, which I did fear.)
                    Dan Rathbun
                    PluginStore Author
                    PluginStore Author
                    Postby driven » Fri Jan 20, 2012 2:44 pm
                    Dan Rathbun wrote:Well, John, you've proved that disable_ui is much faster that not.
                    It appears to here, I can see a cursor image refresh as each group is created
                    There is a registry entry on PC for "MaxUndo" (under the "Preferences" key,) which is set to 100 by default.There is no UI control to change this "on-the-fly." (And likely Sketchup would not see any change to the attribute while running.) But I wonder if setting it to 0 before startup would it disable the undo feature all together ?? (I don't know what it's called in the Mac plist.)
                    macSU .plist <key>SketchUp.Preferences.MaxUndo</key><string>100</string>
                    I think if you write to, then touch, then read SU uses the update, but I need to check if it works for SU prefs, it does for 'user' ruby ones.
                    making a 1000 groups adds 2000 undoes, which is much slower than putting it in the langhandler (which I thought would have a big overhead) with only 1 undo +1 for the explode outside.
                    I'll try and work out a script to do a test, unless you want to...
                    I wasn't really doing this to post back, it's just an exercise in me understanding SU ruby (on mac), but the results seemed to be relevant to the OP's mac/group inquiry. Yell at me if it's not.
                    john
                    driven
                    PluginStore Author
                    PluginStore Author
                    Postby driven » Fri Jan 20, 2012 2:54 pm
                    Dan Rathbun wrote:Also, note. When "MaxUndo" is 0, calling Sketchup.send_action("editUndo:") still returns true, but nothing happens. (At least it does not BugSplat, which I did fear.)
                    One thing I have found when modifying NIB files, is you often need to save, open/close SU then re-save 'manual' preference list changes, to clear SU's cache. Not sure if it's the same with coded writes and maybe it's only the SU ones that are cached?
                    john
                    driven
                    PluginStore Author
                    PluginStore Author
                    Postby Dan Rathbun » Fri Jan 20, 2012 3:29 pm
                    driven wrote:... which is much slower than putting it in the langhandler (which I thought would have a big overhead) ...
                    The LanguageHandler class has nothing to do with this subject (speed & groups.) It's just a wrapper for a Hash, that has English (the keys,) strings translated to the user's local language.
                    Read the "langhandler.rb" file in the "Tools" dir, and you'll see it's quite simple. (I don't use this class, since it defaults to using the "Resources" path, and it's much simplier to just use plain old Hash of my own (which can be loaded from a UTF-8 encoded file.)
                      Dan Rathbun
                      PluginStore Author
                      PluginStore Author
                      Postby Dan Rathbun » Sat Jan 28, 2012 4:54 am
                        For version 8.0M2,
                        Sketchup Release Notes wrote:SketchUp Writer C++ API: In earlier versions, ISketchUpGroup::CreateGroup became slower each time it was called. This shouldn't slow down any longer.
                        I would think that this fix was added into the application code as well.
                        @Guy: Is your friend's Mac running Sketchup version 8.0M2 ??
                          Dan Rathbun
                          PluginStore Author
                          PluginStore Author
                          Postby GWD » Sat Jan 28, 2012 1:42 pm
                          Dan Rathbun wrote:
                            For version 8.0M2,
                            We use on Mac and PC the latest version from google's website. (PC 8.0.11752/MAC 8.0.11.751)
                            I did some more testing:
                            Code: Select all
                            puts '- Start test1 add_group bug on MAC -'
                            start = Time.now
                            for n in 1..1000 do #changed this setting for the testing
                               g.name = n.to_s
                            puts 'Total time: ' + (start - Time.now).to_s
                            Results:
                            At this moment we use a workaround. Place the groups in a new model (use the multiple documents on MAC), make a component of all the groups. Save this component and insert it in the model and explode it. The biggest problem of this workaround is that it's impossible to close the new temporary model with ruby. A other problem is that is still a lot slower than on PC.
                            Anybody a solution?
                            GWD
                            PluginStore Author
                            PluginStore Author
                            Postby Dan Rathbun » Sat Jan 28, 2012 9:30 pm
                            WoW! Excellent test report. Shows that the Mac still has a problem.
                            I wonder if the difference has to do with Ruby.? The Mac is still running the initial release of v1.8.5, and the PC was updated to v1.8.6-p287.
                            There is a thread on how to point the symbolic references for Sketchup Ruby to a "normal" full Ruby install elesewhere on the Mac's harddrive. (You need to backup the current links, so you can switch back if necessary. Perhaps a shell script?)
                            I'd be interested in seeing the comparison for the Mac, running v1.8.5-p0 and v1.8.6-p287, ... (and perhaps even the latest patchlevel for v1.8.7)
                              Dan Rathbun
                              PluginStore Author
                              PluginStore Author
                              Postby GWD » Sun Jan 29, 2012 12:22 pm
                              Dan Rathbun wrote:WoW! Excellent test report. Shows that the Mac still has a problem.
                              And here are the results for ruby 1.8.7 on mac:
                              100 - 0.58 sec
                              200 - 1.69 sec
                              400 - 10.55 sec
                              600 - 33.39 sec
                              1000 - 147 sec
                              Almost no difference with ruby 1.8.5 :-(
                              GWD
                              PluginStore Author
                              PluginStore Author
                              Next
                              Return to Developers' Forum
                              Users browsing this forum: No registered users and 11 guests
