by NeilBlanchard » Thu Sep 01, 2011 9:42 am
This thread was extracted from the CleanUp thread. I separated it in order to make it easier to follow the discussion for this issue.
The issue was initially reported here: viewtopic.php?f=323&t=22920&start=360#p346134
In short summary, when you use .set_html with Safari 5.0.6 local resources, iamges, JS, CSS etc doesn't load. Appear to be new security restrictions.
Related post: viewtopic.php?f=180&t=34714
Workaround Code Snippet viewtopic.php?f=180&t=39842&p=352375#p352375
-ThomThom
I'm seeing this exact same thing. I'm using Snow Leopard and Pro v8.0.4810. I close the tool palette and the gray screen goes away. wrc86 wrote:
it's not working for me, it doesn't show any error when I start SU It just to work with my old OS, now I'm working with OS X LION
I would dearly love this to work -- I am trying to build an electric car, and I'm using a PhlatboyZ PhlatPrinter III, which generates the g-code from SketchUp *faces*. Here's the imported DWG that clearly has pretty crisp edges, but has no faces at all:
I've got about 50 more of these to work through, so if I can use this script to get faces easily, I would be eternally grateful! Edit: I got the faces to work -- most worked by adding one line, and a couple required closing some tiny (> 1/32") gaps. I then was able to use the Phlatboyz Tools (plugin for SU) to generate the outside and inside cutting paths, in preparation for making the g-code. Here's the nearly completed first layout sheet:
Thanks for your excellent plugin -- it has helped a lot. Sincerely, Neil
NeilBlanchard
- Name: Neil
by driven » Thu Sep 01, 2011 11:02 am
NeilBlanchard wrote:I'm seeing this exact same thing. I'm using Snow Leopard and Pro v8.0.4810. I close the tool palette and the gray screen goes away. I've got about 50 more of these to work through, so if I can use this script to get faces easily, I would be eternally grateful!
Sincerely, Neil I was writing when you updated, but here it is anyway...@ Neil, mine does that as well, but if you use the second context menu item 'Clean with last settings' it does actually work. So if you had it set up before the problem it should run... @thomas, this is definitely the Safari 5.0.6 and Safari 5.1 security issue with the file load paths. it's also affecting Fredo's 'images' loading and his updater. however, because you both use convoluted (ruby/js) html creation I can't work out how to specify a simple path. I'll do some more investigations... john
driven
- PluginStore Author
- Name: driven
- Operating system: Mac
- SketchUp version: 2015
- License type: Pro
- SketchUp use: engineering and mechanical design
by thomthom » Thu Sep 01, 2011 11:25 am
driven wrote:however, because you both use convoluted (ruby/js) html creation I can't work out how to specify a simple path.
Because it's not a simple path... it's created dynamically. I'll try to get to the bottom of it.
- Name: Thomas Thomassen
- Operating system: Windows
- SketchUp version: 2019
- License type: Pro
- SketchUp use: other
- Level of SketchUp: Advanced
by thomthom » Thu Sep 01, 2011 11:47 am
driven wrote:I'm still on 10.5.8, but safari 5.0.6 is the pre-release for the next safari and it stops Fredo's updater from checking here for updates, but I haven't had any local file errors from anything else, and sellectionToys works... OSX 10.5.8 + Safari 5.0.png
Any chance you can test something for me: window.zip Replace the old window.html file, and have a look at the error console (in your screenshot) again. It won't fix all loading errors, but it will give me a clue if it reduces some of the errors.
- License type: Pro
by driven » Thu Sep 01, 2011 1:45 pm
driven
- Name: driven
- License type: Pro
by thomthom » Thu Sep 01, 2011 1:48 pm
Cursed!  Just to verify, can you send me the source code of the dialog that opens? (Right click > View Source) ?
- License type: Pro
by driven » Thu Sep 01, 2011 2:14 pm
it's quite small, so here it is... BTW. you can't view source in SU but you can right click on the html tag in Web Inspector and copy as html (the whole file) - Code: Select all
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en-gb" lang="en-gb"><head> <meta http-equiv="X-UA-Compatible" content="IE=8"> <meta http-equiv="content-type" content="text/html; charset=utf-8"> <meta http-equiv="MSThemeCompatible" content="Yes"> <!--<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7" />--> <!--<meta http-equiv="X-UA-Compatible" content="IE=8"/>--> <base href="file:///Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/webdialog/"> <link rel="stylesheet" type="text/css" media="screen" href="css/ui.css"> <link rel="stylesheet" type="text/css" media="screen" href="file:///Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/webdialog/css/inputbox.css"> <style type="text/css">html{overflow:hidden;}</style> <title>%TITLE%</title> <script type="text/javascript" src="js/jquery.js"></script> <script type="text/javascript" src="js/base.js"></script> <script type="text/javascript" src="file:///Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/webdialog/js/inputbox.js"></script> <!-- <script type="text/javascript" src="https://getfirebug.com/firebug-lite.js"></script> --> </head> <body>
<!-- <a href="#">file:///Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/webdialog/</a> -->
</body></html>
driven
- Name: driven
- License type: Pro
by thomthom » Thu Sep 01, 2011 2:27 pm
hmm... Right. This looks like a nasty debug session coming up. I wonder why on earth Safari would prevent loading of resources from file:// ... Is it the file:/// protocol? Surely this would block viewing local webpages?
- License type: Pro
by driven » Thu Sep 01, 2011 4:07 pm
it seems to be something to do with the dynamic loading... selection toys image paths work... selectionToys_path.png
driven
- Name: driven
- License type: Pro
by thomthom » Thu Sep 01, 2011 4:20 pm
driven wrote:it seems to be something to do with the dynamic loading... selection toys image paths work... selectionToys_path.png
This is so odd. I use webdialog.set_html to send it generated HTML. SU then makes a temp file out of that and loads it. So in theory it should not really make a difference... arrrgh... I'm getting flashbacks of IE-hell....
- License type: Pro
by thomthom » Thu Sep 01, 2011 4:37 pm
How do you enable the debug panel in Webdialogs under OSX?
- License type: Pro
by fredo6 » Thu Sep 01, 2011 4:47 pm
This is rather good news! At least we may have a first clue that it can work and try identifying a possible workaround. As Thomthom said, there should be some Html files in the /tmp directory of your Mac (at least while the dialog box is opened). That would be great to get one for Selection Toys and one for a plugin which does not show images. Alternatively, we could design a small dialog box test plugin showing only one image, so that the code is easier to debug. Fredo PS: I guess Safari 5.1 only comes with Lion. Is it correct?
fredo6
- Name: Fredo6
- SketchUp version: 2021
- License type: Pro
- SketchUp use: interior design
by thomthom » Thu Sep 01, 2011 5:08 pm
Fredo, you have similar problems? With dialogs that use .set_html instead of .set_file ?
- License type: Pro
by thomthom » Thu Sep 01, 2011 5:39 pm
I just did a test, where instead of using my generated HTML with .set_html I wrote it to a temp file and used .set_file - everything worked fine again.
I really do not understand why it makes a difference, because what I just did as a workaround is exactly what SketchUp does internally with .set_html ...
- License type: Pro
by fredo6 » Thu Sep 01, 2011 6:00 pm
thomthom wrote:Fredo, you have similar problems? With dialogs that use .set_html instead of .set_file ?
I don't have Safari at hand (and anyway not Safari 5), so it is difficult to say anything. While it is easy to write the HTML to a temp file and load it via set_file, the problem I see is for the refresh (I use set_html when the web dialog is opened). Maybe it will work as well. Fredo
fredo6
- Name: Fredo6
- License type: Pro
by thomthom » Thu Sep 01, 2011 6:12 pm
Fredo6 wrote:While it is easy to write the HTML to a temp file and load it via set_file, the problem I see is for the refresh (I use set_html when the web dialog is opened). Maybe it will work as well.
So you also use .set_html ? I'll be looking into it closer to see if I can make it work with that method, otherwise I have to switch to making a temp file. As you mention, if you delete the temp file while the window is open you break Refresh. If you observe the tmep folder when you use .set_html you'll see that SU keeps the temp HTML file around until you call .set_html again for that window object or until SU closes, where it cleans up all tmep files. Making a cleanup operation from Ruby won't be so easy I think...
- License type: Pro
by thomthom » Thu Sep 01, 2011 6:17 pm
I tried this: - Code: Select all
w=UI::WebDialog.new "Hello" #<UI::WebDialog:0x5ff2fa8>
w.set_html "Hello" nil
GC.start nil
w=nil nil
GC.start nil
When I invoke CG.start the temp file is erased. I wonder if it's possible to be notified in Ruby when an object is garbage collected...
- License type: Pro
by thomthom » Thu Sep 01, 2011 6:20 pm
- License type: Pro
by fredo6 » Thu Sep 01, 2011 6:30 pm
Before going too far and change the method of building web dialogs, let's try to find out why images cannot be loaded on Safari 5, whereas - it works fine on previous versions of Safari (but we need the file:// prefix) - it works fine on IE, any version (prefix file:// not required).
So far, the problem seems to be related to the security of Safari or Lion, since the message is that access to local resources is not allowed. And what we just found out is that Safari would react differently is the web dialog is loaded via set_html vs. set_file.
The question is why? By the way, did you try with loading a HTML file from the /tmp directory with set_file?
Fredo
PS: It is true that the browser designers primarily think about 'connected' web pages, with a real web servers, not using HTML and JS as a simple way to build GUI locally on the PC, without any remote connection and web site. Added to that Apple is known to pay relatively little attention to backward compatibility.
Fredo
fredo6
- Name: Fredo6
- License type: Pro
by thomthom » Thu Sep 01, 2011 7:22 pm
Fredo6 wrote:So far, the problem seems to be related to the security of Safari or Lion, since the message is that access to local resources is not allowed. And what we just found out is that Safari would react differently is the web dialog is loaded via set_html vs. set_file.
Strange new find: w.set_html '<script>alert( window.location )</script>'Under Windows: This presents a messagebox with a string to a temp file. Under OSX with Safari 5.0.6 the messagebox yields "about:blank" I wonder if that was the case in previous version. Now I can't test...  Fredo6 wrote:The question is why? By the way, did you try with loading a HTML file from the /tmp directory with set_file?
That's the thing - I can't find what temp location SU writes to now as window.location reports nothing... ENV['TMPDIR'] yields /var/folders/jw/jwKHMuVxGEi4OILNAxFfgU+++TI/-Tmp-/ I can't even find that on the disk...
- License type: Pro
by thomthom » Thu Sep 01, 2011 7:40 pm
Found one of my older posts - I'd forgotten about. viewtopic.php?f=180&p=306204#p306122Similar, expect that I made it work with file:// - now that seems to have been closed down as well.
- License type: Pro
by driven » Thu Sep 01, 2011 10:04 pm
thomthom wrote:ENV['TMPDIR'] yields /var/folders/jw/jwKHMuVxGEi4OILNAxFfgU+++TI/-Tmp-/ :? I can't even find that on the disk...
the path to the -Tmp- Macintosh HD/private/var/etc... private is a hidden folder the easiest way to expose hidden folders is HiddenFiles widget softpedia has it I've got both versions of Safari if you want me to test things.. @fredo, I'll pm you after I test on 5.0.6
driven
- Name: driven
- License type: Pro
by driven » Fri Sep 02, 2011 2:24 am
thomthom wrote:Similar, expect that I made it work with file:// - now that seems to have been closed down as well.
I think a load or reload button may be required or a least help debug, sort of got Fredo's working now.
driven
- Name: driven
- License type: Pro
by thomthom » Fri Sep 02, 2011 8:20 am
driven wrote:thomthom wrote:Similar, expect that I made it work with file:// - now that seems to have been closed down as well.
- License type: Pro
by driven » Fri Sep 02, 2011 11:38 am
sorry, it was late and I didn't explain anything... Fredo made some tweeks and I was doing the mac testing. when either fredo's LibFredo6 settings dialog or Cleanup3 dialog are first opened they show in WebInpector Resources as (about:blank) cleanup3_about_blank-1.png (about:blank) pages can't be reloaded using normal right-click reload, however with fredo's if you make a selection that forces a content reload like changing the parramaters, (about:blank) is replaced by the proper page, the errors disappear and everything works. cleanup3_about_blank-2.png with Cleanup3 there is nothing to click that will force a change, to see if it would then reload properly. sorry if my logic is flawed, but hopefully this explains what I mean. john
driven
- Name: driven
- License type: Pro
by thomthom » Fri Sep 02, 2011 11:52 am
I split of the discussion for this particular issue as it's a problem with the WebDialog class itself and not the plugin in itself.
- License type: Pro
by Dan Rathbun » Fri Sep 02, 2011 12:22 pm
Didn't John do some testing awhile back where he had to use " file://localhost/" or similar ? What if the resources were in the user's path.. " ~/Library/Application Support/...etc."
I'm not here much anymore. But a PM will fire email notifications.
Dan Rathbun
- Name: Dan Rathbun
- License type: Pro
- SketchUp use: education
by thomthom » Fri Sep 02, 2011 12:24 pm
Dan Rathbun wrote:Didn't John do some testing awhile back where he had to use " file://localhost/" or similar ?
Yes, but now even that fails.
- License type: Pro
by Dan Rathbun » Fri Sep 02, 2011 12:25 pm
thomthom wrote:Making a cleanup operation from Ruby won't be so easy I think...
Don't overlook the Standard Library... " tmpdir.rb" and " tempfile.rb"
Dan Rathbun
- Name: Dan Rathbun
- License type: Pro
by Dan Rathbun » Fri Sep 02, 2011 12:29 pm
Been having similar problems trying to run a local copy of firebug... looks like it's time to set up a simple server. I think Dan Berger has one in the win32-api package.
Dan Rathbun
- Name: Dan Rathbun
- License type: Pro
- Robot
Return to Developers' Forum
