My Apple Keyboard VK_KEYS
Postby Jim » Thu Jan 06, 2011 6:15 pm
Here's a shot of the keyboard I have with the VK_ keys labeled. Just want to compare notes.
My version of Key Tool (prints keycodes including VK_ constants.)
(Menu: Plugins/Key Codes)
Small Map
Jim
Global Moderator
Re: My Apple Keyboard VK_KEYS
Postby Jim » Thu Jan 06, 2011 6:17 pm
Just noticed the Numpad 'enter' key reports different values on Down and Up - (13 and 3)
TIG noted the onKeyDown method of a Tool class does not indicate the tab key being pushed.
Jim
Global Moderator
Postby Dan Rathbun » Thu Jan 06, 2011 7:01 pm
When you hold down SHIFT and hit the option key... do you get VK_ALT ?
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby Dan Rathbun » Thu Jan 06, 2011 7:07 pm
    I tried that on my PC. When I press ALT it says VK_MENU.
    Is this little tool cross-platfrom ?
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby Jim » Thu Jan 06, 2011 7:10 pm
      No, I get 2 actions one for each keypress in the order I press them. I haven't been able to trigger a VK_ALT on either system.
      I might add the constraint, copy, and alt masks to the key tool.
      Jim
      Global Moderator
      Postby Dan Rathbun » Thu Jan 06, 2011 7:23 pm
      It needs work...
      1) a class var KeyTool.@@instance to hold the handle.
      2) a use() class method that conditionally either calls new() or gets the instance if the tool is already loaded.
      3) the menu item needs to call the JF::KeyTool.use() method.
      4) a menu validation proc that properly checks the menuitem activate and deactivate
      Currently clicking the menu item, does not really stop the tool.
      EDIT: (It actually creates a new instance.) PM'd you an updated file with the changes above.
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Postby Jim » Thu Jan 06, 2011 8:48 pm
        VK_ALT == VK_MENU == VK_COMMAND == 18
        It's just that VK_MENU won out in the Hash conflict. (so a problem in my keytool.)
        Jim
        Global Moderator
        Postby driven » Thu Jan 06, 2011 9:52 pm
        hi Jim,
        I've got an apple wireless keyboard, and just tested the keycodes, can't find home yet but will do a mock up of all the variants, that require using the fn() key...
        cheers
        john
        driven
        PluginStore Author
        PluginStore Author
        Postby Jim » Thu Jan 06, 2011 10:06 pm
        Thanks John.
        fn() key?
        On Windows, using VK_DELETE, VK_PRIOR, and VK_NEXT, I am only getting results from onKeyUp. Nothing at all from onKeyDown.
        Jim
        Global Moderator
        Postby driven » Fri Jan 07, 2011 12:33 am
        only onKeyUp for prior and next...
        driven
        PluginStore Author
        PluginStore Author
        Postby driven » Fri Jan 07, 2011 1:04 am
        you can also change to other languages layouts and try them...
        driven
        PluginStore Author
        PluginStore Author
        Postby Dan Rathbun » Fri Jan 07, 2011 1:06 am
        This is kinda weird. While the KeyTool was active, I had a face selected (prior to activating the tool,) and when I pressed the DELETE key, the face was deleted.
        Perhaps the tool should clear the selection ?
        Wonder what other things might happen via Shortcuts when the tool is active ?
          Dan Rathbun
          PluginStore Author
          PluginStore Author
          Postby driven » Fri Jan 07, 2011 1:15 am
          all the shortcut keys, SU and system just carry on working and don't register in the console at all, here at least
          driven
          PluginStore Author
          PluginStore Author
          Postby driven » Fri Jan 07, 2011 1:24 am
          onKeyUp : Key code: 127 using standard apple back-delete
          onKeyUp : Key code: 63272 ( VK_DELETE ) using fn(key)+standard apple back-delete
          NO onKeyDown for delete
          driven
          PluginStore Author
          PluginStore Author
          Postby Dan Rathbun » Fri Jan 07, 2011 1:49 am
          driven wrote:all the shortcut keys, SU and system just carry on working and don't register in the console at all, here at least
          The DELETE key registered "onKeyUp : Key code: 46 ( VK_DELETE )" in the Console (on my PC,) and deleted the selected face.
          It seems weird that keys would bubble up from a Tool instance keytrap callback. I can see having a bubble method that allows passing the key up to Sketchup, but to do it all the time?
            Dan Rathbun
            PluginStore Author
            PluginStore Author
            Return to Developers' Forum
            Users browsing this forum: No registered users and 7 guests
