[Code] Win32 - Get SketchUp Window Handle (WIP)
Re: [Code] Win32 - Get SketchUp Window Handle
Postby Dan Rathbun » Wed Dec 29, 2010 4:30 am
thomthom wrote:I think one can get lots of useful info if one can get the thread id of the SketchUp process. Any ideas of how one can do this.
How about?
Process.pid()
Thread.main.object_id
thomthom wrote:I've been scanning the Win32 API a bit today looking for relevant functions.
Well all the API functions for: Processes and Threads
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby thomthom » Wed Dec 29, 2010 12:46 pm
    Ah - there we go, that might help.
    GetCurrentProcessId looks promising.
    PluginStore Author
    PluginStore Author
    Postby thomthom » Wed Dec 29, 2010 12:49 pm
    pid = GetCurrentProcessId.call
    4684
    Process.pid()
    4684
    It seem to return the same thing.
    PluginStore Author
    PluginStore Author
    Postby Dan Rathbun » Wed Dec 29, 2010 2:14 pm
    thomthom wrote:pid = GetCurrentProcessId.call
    4684
    Process.pid()
    4684
    Yes and it's the same as you'll see in the Task Manager, or using tlist.exe from the command line (for that Sketchup instance.)
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby Dan Rathbun » Wed Dec 29, 2010 2:34 pm
      Dan Rathbun wrote: It looks as though the DL library supports callbacks. Maybe we should use it ??
      My bad.. :oops:
      Callbacks were added in 1.9.x, both 1.8.6 and 1.8.7 DL libs don't have the callback.rb file.
      sorry Thom
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Postby thomthom » Wed Dec 29, 2010 2:56 pm
        GetCurrentThreadId I think this one is what we can use to get associated window handles. Just need to get callbacks working so we can use EnumThreadWindows to get the windows for the calling thread.
        PluginStore Author
        PluginStore Author
        Postby thomthom » Wed Dec 29, 2010 3:45 pm
        Jim wrote:
        thomthom wrote:Where is the win32-api found - the one that supports callbacks?
        http://win32utils.rubyforge.org/
        I'm not sure if this can co-exist with Win32API or not.
        require 'win32/api'
        win32.zip
        I just tried it, works fine with Win32API.
        Here's a bastardised proof of concept snippet where I found the SketchUp window regardless if it had focus or not.
        Code: Select all
        # http://stackoverflow.com/questions/3327666/win32s-findwindow-can-find-a-particular-window-with-the-exact-title-but-what
        EnumWindows       = Win32::API.new('EnumWindows', 'KP', 'L', 'user32')
        EnumThreadWindows = Win32::API.new('EnumThreadWindows', 'LKP', 'I', 'user32')
        GetCurrentThreadId = Win32API.new("kernel32.dll", "GetCurrentThreadId", '', 'L')
        # Detect the toolwindows even if Hide Dialogs is active.
        def enum_sketchup_windows
          threadId = GetCurrentThreadId.call
          enumWindowsProc = Win32::API::Callback.new('LP', 'I'){ |handle, param|
            #puts "EnumWindows - Callback"
            #puts "> handle: #{handle}"
            #puts "> param: #{param.inspect}"
            window_text = get_window_text(handle)
            window_text.strip! # Remove trailing NULL character
            p window_text unless window_text.empty?
            if !window_text.index(param).nil?
              puts "window was found: handle #{handle}"
              0 # FALSE - stop looking after we find it
              1 # TRUE
            else
              1 # TRUE
          EnumThreadWindows.call(threadId, enumWindowsProc, 'SketchUp')
        # Takes the first enumerated window for the calling SketchUp thread and fetches
        # the root owner which should be the SketchUp window. (Not tested against wxSU)
        # Is the enum required to get just one window? Any other function to get an
        # arbitrary window from the SketchUp thread?
        def find_sketchup_window
          hwnd = 0
            hwnd = GetAncestor.call(handle, GA_ROOTOWNER)
          hwnd
        Remaining issues:
        • Migrate Win32API to Win32::API for all function calls.
        • While testing I eventually got an exception that said there was too many callbacks initiated. Seems there might be a limit. I have not looked into this further, but I think once might have to make one callback proc, and then delegate to the appropriate handling method based on param.
        PluginStore Author
        PluginStore Author
        Postby thomthom » Wed Dec 29, 2010 3:56 pm
        = Documentation
        The source file contains inline RDoc documentation. If you installed
        this file as a gem, then you have the docs.
        Where do you get the source code?
        I tried to install the gem, but got this error:
        PluginStore Author
        PluginStore Author
        Postby Jim » Wed Dec 29, 2010 4:18 pm
        It is a c-language based extension, and apparently isn't available already compiled for your platform. So you would need to compile it.
        This is the advantage of using the mingw32 Ruby Installer with devkit - it automatically builds native libraries.
        http://rubyinstaller.org/downloads/
        Jim
        Global Moderator
        Postby thomthom » Wed Dec 29, 2010 4:33 pm
        But where is the source code - since it's suppose to contain the documentation?
        PluginStore Author
        PluginStore Author
        Postby Jim » Wed Dec 29, 2010 4:36 pm
        For me, it is here:
        C:\Ruby186\lib\ruby\gems\1.8\gems\win32-api-1.4.7-x86-mingw32\ext\win32
        Jim
        Global Moderator
        Postby thomthom » Wed Dec 29, 2010 5:05 pm
        hm... guess I have to look into that ming-thing...
        Anyway - I have produced a code which appear to return the handle for the SketchUp window of the calling thread. I created a EnumWindowsProc to delegate enumeration messages in order to avoid Error: #<Win32::API::Error: too many callbacks are defined.>. I really want to know what this limit is. This is the first draft, I expect there is a better way to deal with this.
        But, we do get a reliable window for the SketchUp window we want - as far as I have been able to test.
        PluginStore Author
        PluginStore Author
        Postby thomthom » Wed Dec 29, 2010 5:08 pm
        Maybe we can handle drag and drop by callbacks. Or intercept window messages so we can simulate the roll-up/down of toolwindows.
        Still, OSX users are out of luck here...
        PluginStore Author
        PluginStore Author
        Re: [Code] Win32 - Get SketchUp Window Handle (WIP)
        Postby Dan Rathbun » Thu Dec 30, 2010 3:41 am
        Here's some interesting info:
        Code: Select all
        #  some Sketchup window properties:
        #  AutomationId  =  ""
        #  CLASS   =  "Afx:00400000:b:00010011:00000006:00790557"
        #  *** the last octet changes each time Sketchup is run,
        #  examples:  "Afx:00400000:b:00010011:00000006:0012077F"
        #             "Afx:00400000:b:00010011:00000006:000E0699"
        #  ControlType           =  "ControlType.Window"
        #  LocalizedControlType  =  "window"
        The main application window is the only one with a classname like this, and also the only one with a LocalizedControlType that equals "window".
        ALL dialogs including WebDialogs, are:
        Code: Select all
        #  ClassName             =  "#32770"
        #  LocalizedControlType  =  "Dialog"
          Dan Rathbun
          PluginStore Author
          PluginStore Author
          Postby Dan Rathbun » Thu Dec 30, 2010 4:14 am
          thomthom wrote:I have produced a code which appear to return the handle for the SketchUp window of the calling thread.
          Are you planning on distibuting a pre-compiled win-api as part of TT_Lib2 ??
          I have a few issues with this.
          (1) It's not in the correct folder. What if a person already has it (and possibly a newer version,) installed ?
          require will not recognize the path string you have in that example, and would load the older version down under your TT_Lib2 folder. That would overwrite the newer classes that might be loaded, if they were loaded first.
          OR.. since "T" comes before "W" your version would get loaded first, and when a normal version gets loaded after... your code might get broken. (I say "might" as newer versions are usually better.)
          So? I like the idea of someone precompiling Berger's WinUtils, and zipping them for manual install by the community (and/or creating a one-click-installer for dummies.) But they should be in the proper folder ... and likely a path to them appended to the $LOAD_PATH array.
          How much of Berger's suite would the distro have? the bare bones min or the whole thing?
            Dan Rathbun
            PluginStore Author
            PluginStore Author
            Postby thomthom » Thu Dec 30, 2010 11:18 am
            Dan Rathbun wrote:Here's some interesting info:
            I get Afx:00A50000:b:00010005:00000006:0A7C0E3B during one session,
            and the next I get Afx:00ED0000:b:00010005:00000006:5CCC0D4F - seems to be more than just the last bit that changes...
            SU8 - Win7...
            I don't understand where that name is from - other apps, like Notepad++ has a fixed classname.
            PluginStore Author
            PluginStore Author
            Postby thomthom » Thu Dec 30, 2010 11:28 am
            Dan Rathbun wrote:Are you planning on distibuting a pre-compiled win-api as part of TT_Lib2 ??
            I'm looking into it. If license allows it.
            Dan Rathbun wrote:(1) It's not in the correct folder. What if a person already has it (and possibly a newer version,) installed ?
            That is a thing that was on my to-look-into list. What if I placed it into a folder, say: TT_Lib2/win32api/win32/api.so - and then added the TT_Lib2/win32api/ path to $LOAD_PATH so one load it as the examples says require 'win32/api'?
            Dan Rathbun wrote:OR.. since "T" comes before "W" your version would get loaded first, and when a normal version gets loaded after... your code might get broken. (I say "might" as newer versions are usually better.)
            We have that potential issue with Win32API already, though it often lies in the root of the plugins folder, you can't be sure what version was copied into there last.
            Dan Rathbun wrote:How much of Berger's suite would the distro have? the bare bones min or the whole thing?
            Atm I only have use of api.so - but there was some interesting stuff he had.
            PluginStore Author
            PluginStore Author
            Postby Dan Rathbun » Thu Dec 30, 2010 1:33 pm
            SU8 - Win7...
            Wikipedia on Microsoft Foundation Class Library wrote:One interesting quirk of MFC is the use of "Afx" as the prefix for many functions, macros and the standard precompiled header name "stdafx.h". During early development what became MFC was called "Application Framework Extensions" and abbreviated "Afx". The name Microsoft Foundation Classes (MFC) was adopted too late in the release cycle to change these references.
            A guy on Experts Exchange wrote:Just few words about AFX:XXXXX:XXX like windows..... Dont confuse with this type of class names, these are just class names and actually MFC generates class names for its windows this way. Some of those numbers are an HINSTANCE and a process ID (to make sure the class name is unique). I'm not sure what the others are - if you really want to know, you can probably find it in 'MFC source code. -MAHESH
            In the AutoHotKey Forum post 633, Chris, in his reply, wrote:Below are quotes from the only relevant link discovered on Google at:
            http://visualbasicforum.com/showthread.php?t=149804 (dead link) wrote:Those Afx window classes were custom classes distributed with early versions of MFC, before the "Common Controls" concept was introduced.
            Many people have tried to "read" text from them but you CAN'T, not with messages anyway!
            They're almost certainly owner-drawn - the text is not delivered by messages, it's "hand-drawn" into the window's DC
            Apparently legacy from the early days ... there are many things I see (about Sketchup UI objects,) poking about with MS Tools that don't look quite right.
              Dan Rathbun
              PluginStore Author
              PluginStore Author
              Postby thomthom » Thu Dec 30, 2010 1:45 pm
              So, many of what looks like system UI elemens is not drawn by the system - but emulated by the AFX/MFC framework?
              PluginStore Author
              PluginStore Author
              Postby Dan Rathbun » Thu Dec 30, 2010 1:51 pm
              There are several GUI frameworks a coder can choose to use ... WTL sounds very interesting.
              http://en.wikipedia.org/wiki/Windows_Template_Library
                Dan Rathbun
                PluginStore Author
                PluginStore Author
                Postby Dan Rathbun » Tue Jan 04, 2011 10:41 am
                Dan Rathbun wrote: I've also read that the DL library is 'on the outs', and they are planning to deprecate it and replace it with something else.
                OK.. now I remember what the next generation (after DL,) was supposed to move to, (the Foriegn Function Interface):
                Wikipedia: libffi
                and the github site for Ruby FFI is:
                https://github.com/ffi/ffi
                It is not yet included with Ruby as of v1.9.1-p429
                  Dan Rathbun
                  PluginStore Author
                  PluginStore Author
                  Postby Anton_S » Fri Jun 22, 2012 8:13 pm
                  Here is my way to find sketchup window.
                  I used it in SU Window Settings plugin.
                  Parts of ClassName change After restarting SU
                  ~sample: "Afx:00400000:b:00010011:00000006:0574025D"
                  From my testing:
                  • On windows XP, the last set of values, separated by ":" change.
                  • On windows 7, all even parts, separated by ":" change. The odd parts are always the same, including on both 32 and 64 -bit processors.
                  So, the only parts of class that are reliable to locate main SU window are, Afx, b and 00000006. Plus to get the current sketchup window, you could add the Process.pid. The code below does all of that work :)
                  Code: Select all
                  @main_window = Hash.new
                  @find_main_window = Win32::API::Callback.new('IP', 'I'){|hwnd, lParam|
                    p = 0.chr*4
                    threadID = GetWindowThreadProcessId.call(hwnd, p)
                    pid = p.unpack('l')[0]
                    next true if (pid != Process.pid)
                    cname = 0.chr*50
                    GetClassName.call(hwnd, cname, cname.size)
                    cname = cname.strip
                    if (cname[0,3] == "Afx") and (cname[13,1] == "b") and (cname[24,8] == "00000006")
                      @threadID = threadID
                      @main_window["hwnd"] = hwnd
                      next false
                    true
                  EnumWindows.call(@find_main_window, nil)
                  Note, this example was only tested on Windows XP and On Win7.
                  What vous think?
                  Anton_S
                  PluginStore Author
                  PluginStore Author
                  Postby Dan Rathbun » Fri Jun 22, 2012 10:49 pm
                  You neglect to show the require() staement that loads Dan Berger's win32-api extensions. (This example does not use the Win32API.so file, that comes "out-of-the-box" with Ruby.)
                    Dan Rathbun
                    PluginStore Author
                    PluginStore Author
                    Postby Dan Rathbun » Fri Jun 22, 2012 10:54 pm
                    I find it much simplier.. to use a KNOWN child window (sometimes I use the Console window, sometimes I create a hidden child window with a caption that is unique, like perhaps I insert a time-stamp and the current Sketchup pid, returned with $$, into my child window caption.)
                    Then find the handle to that unique window, and get it's owner.
                      Dan Rathbun
                      PluginStore Author
                      PluginStore Author
                      Postby Anton_S » Sat Jun 23, 2012 1:54 am
                      Dan Rathbun wrote:You neglect to show the require() staement that loads Dan Berger's win32-api extensions. (This example does not use the Win32API.so file, that comes "out-of-the-box" with Ruby.)
                      Thanks for pointing that out. Yep, the code above requires win32-api
                      Anton_S
                      PluginStore Author
                      PluginStore Author
                      Next
                      Return to Developers' Forum
                      Users browsing this forum: Bing [Bot] and 12 guests
