Ruby File Auto-Reloader code
Postby Jim » Sat Oct 02, 2010 7:17 pm
I got tired of reloading files I was editing, so made this up real quick. It uses a timer to check the last modification time on a file, and loads if updated. It handles errors gracefully by only trying to reload a file once per update. If packaged up with a nice user interface, it might make a nice dev tool.
Stop the timer in the Ruby Console: UI.stop_timer $t
Note - It's only good for one file at a time and needs improved if loading multiple files is needed. I just wanted something for "right now," and will try to make it better later.
Code: Select all
def autoreload(name)
    pf = Sketchup.find_support_file('plugins')
    file = File.join(pf, name)
    $t = UI.start_timer(2, true) do
        mt = Kernel.test(?M, file)
        if mt.to_i > $mt.to_i
            puts "Loading: #{File.basename(file)}"
            begin
                load file
            rescue Exception => e
                puts e.message
                puts e.backtrace
            $mt = mt
Jim
Global Moderator
Re: Ruby File Auto-Reloader code
Postby Morgan74 » Tue Oct 05, 2010 4:45 pm
Thank-you for this great Plugin !!! :thumb:
It's so boring to always close and re-open SU to update my plugins files !! :twisted:
Morgan74
Postby Jim » Wed Oct 06, 2010 3:32 pm
I'm glad you found it useful.
But there are times when it is good to close SketchUp; when you change the name of a method, for example. Closing SketchUp is the only way to get rid of the old method name. Sometimes you have a bug where a part of your code is still using the old method name until you remember you changed it. I've done this numerous times.
Jim
Global Moderator
Return to Developers' Forum
cron
Users browsing this forum: No registered users and 12 guests
