Writing Ruby Console messages to a text file
Postby Al Hart » Fri Sep 24, 2010 7:53 am
Sketchup.exe has a feature where, if you redirect its standard output to a file, then any messages which would be sent to the ruby console are written to the file. However, Sketchup.exe does not flush this file, so if there is a big splat, or if you want to examine the file while Sketchup.exe is running, it will not contain all of the messages.
I have created a ruby script which overrides the Ruby Console, and write its messages to a file, and flushes each message.
Place this in the plugins folder, and it should create a file called c:\tmp\ruby_trace.txt which contains all of the messages which are sent to the Ruby Console (whether the Ruby Console is open or not).
Give it a try, see what happens, and offer any suggestions you may have:
!trace_console.rb
Code: Select all
# Copyright 2010, Render Plus Systems.
# Permission to use, copy, modify, and distribute this software for
# any purpose and without fee is hereby granted, provided that the above
# copyright notice appear in all copies.
# THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
# IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
# WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
printf("***** Loading: %s\n", File.basename(__FILE__))
# create a class to trap comsole output and send
# it to a file int c:\tmp
class CL_rps_console < Sketchup::Console
attr_accessor :debug_file
attr_accessor :sfile
   def initialize
      # create a folder called c:\tmp
      sdir = "c:\\tmp"
      if (!FileTest.exists?sdir)
          Dir.mkdir(sdir)
      end#if
      @sfile = "c:\\tmp\\ruby_trace.txt"
      @debug_file = File.new(@sfile, "w")
      @debug_file.write(::Time.now.to_s  + "\n")
      @debug_file.write("SketchUp Version: " + Sketchup.version.to_s  + "\n")
   end#def
   def write(smess)
      @debug_file.write(smess)
      @debug_file.flush
      super(smess) # call inherited class write function
   end#def
end#class
# redefine standard output to our new class
$old_stdout = $stdout # in case you want to turn off traces
$stdout = CL_rps_console.new
$stderr = $stdout # trap error displays as well
puts "-----"
puts "Console messages are going to " + $stdout.sfile
puts "-----"
Sample file contents:
    C:\tmp>type ruby_trace.txt
    Fri Sep 24 00:51:28 -0600 2010
    SketchUp Version: 8.0.3117
    Console messages are going to c:\tmp\ruby_trace.txt
[EDIT: changed name to !trace_console.rb and added $stderr = $stdout]
[EDIT: Revised script for mkdir error]
Al Hart
IRender nXt from Render Plus
Al Hart
PluginStore Author
PluginStore Author
Re: Writing Ruby Console messages to a text file
Postby thomthom » Fri Sep 24, 2010 8:10 am
I might have the perfect candidate for testing. I experience crash without bugsplat with a script in some unknown condition.
PluginStore Author
PluginStore Author
Postby honoluludesktop » Fri Sep 24, 2010 10:10 am
Wow, very neat!
honoluludesktop
In Remembrance
Postby Jim » Fri Sep 24, 2010 2:26 pm
Thanks, Al - good idea. You could also log $stderr which might catch some thing additional events.
$stderr = $stdout
Jim
Global Moderator
Postby Al Hart » Fri Sep 24, 2010 4:58 pm
I had place an underscore at the front of the ruby file name, (_trace_ruby.rb), so it would run before other ruby files.
But I was confused. It turns out the _ comes after a-z in sort order, so I changed it to !trace_ruby.rb so it would come first.
I wanted to make sure that it caught printf's and puts's from other .rb files in plugins, so I created !r.rb with prints "!R" and !u.rb which prints "!U", and sure enough, !R did not trace to the file, but !U did.
I have updated the script in the original post, and also added the $stderr stuff as suggested by Jim
    Fri Sep 24 09:53:21 -0600 2010
    !U
Al Hart
Al Hart
PluginStore Author
PluginStore Author
Postby Al Hart » Fri Sep 24, 2010 5:46 pm
thomthom wrote:I might have the perfect candidate for testing. I experience crash without bugsplat with a script in some unknown condition.
Let me know how it goes.
You can add:
Code: Select all
printf("FILE: %s LINE: %s\n", File.basename(__FILE__), __LINE__)
after almost every line in the ruby file to trace down the bug splat.
(Or if someone knows another good way to trace ruby files, let me know)
Al
Al Hart
Al Hart
PluginStore Author
PluginStore Author
Postby dburdick » Thu May 05, 2011 12:52 am
I'm trying to redirect $stderr to a file, but it doesn't work. $stdout works just fine but not $stderr. It appears that when Sketchup generates an error message, it does not call $stderr, but outputs to the console through some other mechanism. Anyone have any ideas on this.
dburdick
e-on software
Postby Al Hart » Thu May 05, 2011 2:17 am
Keep your ese on this thread as well: [Plugin] Trace Ruby messages
Al Hart
Al Hart
PluginStore Author
PluginStore Author
Postby dburdick » Thu May 05, 2011 4:31 am
Hi Al,
Thanks - will do.
dburdick
e-on software
Return to Developers' Forum
Users browsing this forum: No registered users and 14 guests
