Look around tool in ruby?
How does the look around tool work in ruby?
The rotate view rotates around a target point
but the look around tool rotates around the position of the "camera".
How is that done in ruby? -
With Camera.direction and Camera.up.
Todd
I tried that and also "camera.set eye, target, up" but can't get camera to rotate.
What's the right syntax? Is there a "camera.set eye, direction, up" ? -
I should have said "with camera.set by changing the direction and tilt", but I think you understood.
You say "why doesn't my code work, because I am doing that".
Now, I have to say, I need to see your code to tell you why your code does not work, intead of trying to guess what you are doing wrong. There are a couple ways to approach this. It's too brain-racking to try and guess.
Todd
Here is some testcode I use.
I get: <ArgumentError: Eye, Target and Up are required> when using camera.set direction
I also tried with: direction.set!(@rx, @ry, @rz); but nothing...# Testing code # Name: jsCameraTool # Author: Jan Sandstrom www.pixero.com # Description: Position and rotate the camera numericly. require 'sketchup.rb' def jsCameraTool model = Sketchup.active_model view = model.active_view camera = view.camera eye = camera.eye direction = camera.direction target = camera.target up = camera.up length = camera.focal_length fov = camera.fov ### Dialog @px = eye.x @py = eye.y @pz = eye.z @rx = direction.x @ry = direction.y @rz = direction.z #@tx = target.x #@ty = target.y #@tz = target.z prompts = ["Position X", "Position Y", "Position Z", "Rotation X", "Rotation Y", "Rotation Z"] values = [@px, @py, @pz, @rx, @ry, @rz] results = inputbox(prompts, values, "JS CameraTool") px, py, pz, rx, ry, rz = results @px, @py, @pz, @rx, @ry, @rz = px, py, pz, rx, ry, rz # New position camera.eye.x = @px; camera.eye.y = @py; camera.eye.z = @pz; camera.direction.x = @rx; camera.direction.y = @ry; camera.direction.z = @rz; #target.x = @tx; #target.y = @ty; #target.z = @tz; #up.set!(0.0, 0.0, 1.0); #camera.set eye, target, up; camera.set direction; end # end of jsCameraTool if( not file_loaded?("jsCameraTool.rb") ) UI.menu("Plugins").add_item("JS CameraTool") { jsCameraTool } end
camera.set takes 3 arguments: the eye (Point3d), the target (Point3d) and the up direction (Vector3d).
camera.set(eye, target, up)
camera.set(eye, target, up)Thats just it.
How do I set the camera.direction? -
You need to use camera.set. The vector from the target to the eye is the direction.
m=Sketchup.active_model view=m.active_view camera=view.camera v1 = (camera.target - camera.eye).normalize v2 = camera.direction.normalize p v1 == v2
