[REQ] manipulate camera by something like mover2 ?
Postby bagatelo » Sun Dec 20, 2009 3:00 pm
One more of the series "Alex and their crazy ideas.... " :roflmao:
Would it be possible to control the camera of Sketchup using something similar to the tool "Mover2?"
http://sketchuptips.blogspot.com/2007/0 ... ver-2.html
Set camera offset for rotation and translation numericly:
http://www.pixero.com/downloads_sketchup.html
http://www.smustard.com/script/CameraControls
I think something like move camera "up/down", "front/behind", "right/left" by typed numeric values.
Please, visit my blog: http://cg-alex.blogspot.com/
bagatelo
Re: [REQ] manipulate camera by something like mover2 ?
Postby Jim » Mon Dec 21, 2009 4:34 pm
I will look into adding the Camera as a movable target using the mover2 controls. Give me a couple days..
Jim
Global Moderator
Postby driven » Fri Dec 24, 2010 3:41 pm
Jim wrote:I will look into adding the Camera as a movable target using the mover2 controls. Give me a couple days..
hi Jim,
if your revisiting Mover2, could you add .show_modal for us mac users, I can't figure out how to (I'm sure I added it before)
cheers
john
driven
PluginStore Author
PluginStore Author
Postby Dan Rathbun » Fri Dec 24, 2010 11:12 pm
Code: Select all
if RUBY_PLATFORM.include?('darwin')
  dialog.show_modal()
else
  dialog.show()
You can get fancier with a global like $MAC_SHOW_MODAL_DIALOGS=true
So the user can change their preference on the fly.
Code: Select all
  if $MAC_SHOW_MODAL_DIALOGS
    dialog.show_modal()
  else
    dialog.show()
else
  dialog.show()
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby Dan Rathbun » Fri Dec 24, 2010 11:23 pm
    Hey John it occurs to me that YOU can override your UI::WebDialog class and force any call to show() to actually call show_modal(). You would use method aliaising, based on the global var.
    That way way you would not need to badger every plugin coder to modify their plugins.
    Something like this: EDITED
    Code: Select all
    class UI::WebDialog
      @@ALWAYS_SHOW_MODAL=false
      def self.always_show_modal?
        @@ALWAYS_SHOW_MODAL
      def self.always_show_modal=(arg)
        @@ALWAYS_SHOW_MODAL=arg
      alias_method( :old_show, :show )
      def show(&block)
          if @@ALWAYS_SHOW_MODAL
            show_modal(block)
          else
            old_show(block)
        else
          old_show(block)
      end # show() override
    end # class override
      UI.menu("View").add_separator()
      UI.menu("View").add_item('Show WebDialogs as Modal') {
        if UI::WebDialog.always_show_modal?
          UI::WebDialog.always_show_modal=(true)
        else
          UI::WebDialog.always_show_modal=(false)
    Made control var a class var, instead of a global.
    Added menu option under View menu.
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby driven » Fri Dec 24, 2010 11:38 pm
      Dan Rathbun wrote: ....That way way you would not need to badger every plugin coder to modify their plugins.
      cheers Dan, I'll give it a try, I usually just change them myself, but sometimes can't figure out 'where' to when people use super instead of UI::WedDialog
      I don't understand what super is... or where it comes from...
      john
      btw. merry xmas to all
      driven
      PluginStore Author
      PluginStore Author
      Postby Dan Rathbun » Fri Dec 24, 2010 11:53 pm
      Actually it would be "more proper" to have the control var as a class varible rather than yet another in the multitude of globals.
      I'll edit the code posting above.
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Postby Dan Rathbun » Sat Dec 25, 2010 3:56 am
        driven wrote:I don't understand what super is... or where it comes from...
        super is a Ruby keyword that acts similar to a method, but has a quirk.
        super
        calls the same method in the ancestor PASSING UP the parameters that the child method received.
        super()
        calls the same method in the ancestor BUT PASSES AN EMPTY parameter list.
        super(arg1, arg2, ...)
        calls the same method in the ancestor BUT PASSES ONLY the parameters listed.
          Dan Rathbun
          PluginStore Author
          PluginStore Author
          Return to Plugins
          Users browsing this forum: che, fk0002, Google Bot and 21 guests
