[Obsolete] BZ__Chamfer for BezierSpline 1.2
Postby fredo6 » Mon Aug 31, 2009 10:47 pm
This extension is now included in BezierSpline 1.4
BZ__Chamfer is an extension of BezierSpline which will draw a Polyline with chamfered corners, which you can specify the offset (distance to the corners). Note that the chamfer is drawn only if there is enough space on the segments.
This comes from a request by elcorto (see http://forums.sketchucation.com/viewtopic.php?f=180&t=21550#p181292)
As the polylines remains parametric as long as it is a curve, you can later change the parameters, and move, add or remove vertices.
Finally, as for other extensions of Bezierspline, you can convert any Sketchup curve into a Polyline with Chamfered corners.
To install, drop the BZ__Chamfer.rb file into the BZ_Dir_12 folder, and the png files attached into the subfolders IMAGES_STANDARD and IMAGES_CadFather.
This extension is integrated in the main release of BezierSpline 1.4. See this this post for download
Fredo
fredo6
Premium Member
Premium Member
Re: [Plugin] BZ__Chamfer for BezierSpline 1.2
Postby pilou » Mon Aug 31, 2009 10:54 pm
More and more possibilities :)
Top SketchUcator
Postby agrazdi » Tue Sep 01, 2009 12:55 am
There are no PNG files to download.
agrazdi
Postby Dave R » Tue Sep 01, 2009 1:01 am
Thanks Fredo.
agrazdi, yes, the PNG files are there. Just right click on the images and choose Save Image As...
Global Moderator
Postby agrazdi » Tue Sep 01, 2009 1:35 am
agrazdi
agrazdi
Postby daniel s » Tue Sep 01, 2009 2:43 am
Thank you Fredo!!! Another great tool!!! :sketchstatic: :sketchstatic: :sketchstatic:
A question...
I always see different and separate tools for round corners in 2D and round corners in 3D. Can be possible a single all-purpose round corner plugin?
For example your RoundCorner plugin... if you try to round lines or faces (In 2D) it says invalid. Can your RoundCorner plugin incorporate your polyline arc corners and polyline chamfer for these invalid cases?
It´s difficult to me to explain this in english but the idea would be that if you take the orange icon and you try to round lines or faces (In 2D) will make a fillet (polyline arc corners) and if you take the green one and you take a 2d face will make a chamfer.
Daniel S
daniel s
Return to Plugins
Users browsing this forum: 4BIMM, Bing [Bot], Joni_Kinnarps, Khyla, thonguyen11729, zanuarrp and 13 guests
