"Scaled array"
"Scaled array"
Postby museummaker » Sat Jun 27, 2009 6:53 pm
I was working on a model and found myself drawing (for lack of a better name) a scaled array. Where a component repeats but linearly gets smaller each time it copies.
Attached is a simplified picture, you see this type of construction in cranes, etc.
I ended up doing it manually but I wondered if a ruby existed that could do a copy / scale / array type action?
museummaker
Re: "Scaled array"
Postby mitcorb » Sat Jun 27, 2009 7:07 pm
Check out Grow by TIG. The examples I have seen from Pilou in this forum appear to be similar. However, I do not currently have this plugin, so I don't know if it will "ungrow".
This is based on the premise that you want to keep the data as components.
Don't worry someone else will have your answer directly.
mitcorb
mitcorb
Top SketchUcator
Re: "Scaled array"
Postby pilou » Sat Jun 27, 2009 11:14 pm
Grow by TIG makes maybe not that you want but another thing ;)
Seems you can make something also with Protrude by Jim Foltz
Speedy Galerie
Top SketchUcator
Re: "Scaled array"
Postby pilou » Sun Jun 28, 2009 12:09 am
Grow makes the trick but you must add another plug for align drop objects! Align by Didier Bur
After the Scale
x = 0.8
y = 0.8
z = 0.8
because the Z Spacing don't accept a coefficient but just a value in cm :o
Maybe Tig can make something ;)
Another plug must be created "Drop" on an existing object
Seems Didier Bur has a drop inside Spray tool but... :roll:
:o
Speedy Galerie
Top SketchUcator
Re: "Scaled array"
Postby museummaker » Sun Jun 28, 2009 1:15 am
Thank you for the tips.
I have been experiementing and quite get the perfect results.
It is helpful and faster than doing it by hand but still end up tweaking things.
I will continue to explore what these great rubys can do. Always things to learn. :ugeek:
museummaker
Re: "Scaled array"
Postby TIG » Sun Jun 28, 2009 1:38 pm
Try changing the order of operations - scale then move then rotate, move then scale then rotate etc... This will produce differing results
Global Moderator
Re: "Scaled array"
Postby pilou » Sun Jun 28, 2009 5:32 pm
How change order as all is in the same dialog box???
Sorry but seems impossible or I miss something for the Duh thread :oops:
Seems that the Zspacing accepting a % will be very cool?
I have the 1.0 20070207
Speedy Galerie
Top SketchUcator
Re: "Scaled array" Grow.rb
Postby TIG » Sun Jun 28, 2009 6:39 pm
There is a separate dialog at the end asking for 'order of operations'...
The latest version of 'Grow' is now available for download here viewtopic.php?p=324331#p324331
Global Moderator
Re: "Scaled array"
Postby pilou » Sun Jun 28, 2009 7:04 pm
Indeed that is a big Duhduh :oops: :oops: :oops:
I had a very old version! :lol:
So I must learn your new opus :enlight:
Speedy Galerie
Top SketchUcator
Re: "Scaled array"
Postby pilou » Sun Jun 28, 2009 10:31 pm
Ok that works like a charm :fro:
except that we must find first the "Growth point"!!!
the "bottom point base" of the troncated crossing edges top Pyramid! :o
Maybe this can be automatic because in this case its' easy to find it but in case of complex form?
Or biggest volume?
Mr TIG it's your turn :D
Speedy Galerie
Top SketchUcator
Re: "Scaled array"
Postby utiler » Thu Jul 02, 2009 7:20 am
Gee, I'm glad i stumbled on this; I like Pilou had an old version....TIG, is this only relatively new? I just went to http://www.crai.archi.fr/RubyLibraryDep ... i_page.htm and the old one still downloads.....
TIG, Have you produced a instructions sheet with this latest version? I am having trouble executing what i want to do. I seem to be confused as the the 'X' and 'Y' planes....
I assume 'X' is red direction; left and right,
'Y' is green direction; up and down the screen,
and
'Z' is obvious.
When I rotate a vertical ['Z' plane] object around what i think is the RED direction it actually rotates it around the GREEN...['Y']
Also, TIG, can you give a little detailed explanation of the order of parameters...?
I have been getting an awful lot of Bugspats!!!!
Don't get me wrong, I think once I get the concept of it I will have found my new favourite plugin!!!
utiler
Top SketchUcator
Re: "Scaled array"
Postby pilou » Thu Jul 02, 2009 7:59 am
@Utiler
Z Is not obvious, with it your model goes in the 3D space up & down! ;)
there is a little help text inside the code plug! Open it ;)
It's around the BLUE AXIS ;)
Order gives you the natural order of transformations ;)
About the first problem seems you can't oblige to have 80% for have perfect fit if you don't know the other X,Y,Z measures!
it's depending of the measure of the first start volume!
See my example above! I have 50% for this one (of course with my start measures volume)
My regulates and don't forget the Growth point position (see image above)
nb copy 3
X spacing = 0
Y spacing = 0
Z spacing = 100 cm
Scaling = Yes
Xspacing scaling = 1
Yspacing scaling = 1
Zspacing scaling = 0.5
Xcopy scaling = 0.5
Ycopy scaling = 0.5
Zcopy scaling = 0.5
(all exponential+ by default)
Move Scale Rotate order (or Move Rotate Scale as the is no rotation in this one)
Speedy Galerie
Top SketchUcator
Re: "Scaled array"
Postby utiler » Fri Jul 03, 2009 2:42 am
Thanks Pilou,
I believe Z is always vertical [blue axis in SU]. If the ground plane is the ground then it makes sence to me that Z [blue axis is vertical....
See the simple Palm tree attached.
Say I want to rotate copy and move the palm fron as noted on the attached image. Still getting weird outcomes when I try to do so...
thanks in advance.
utiler
Top SketchUcator
Re: "Scaled array"
Postby pilou » Fri Jul 03, 2009 9:40 am
Something like this?
Speedy Galerie
Top SketchUcator
Re: "Scaled array"
Postby utiler » Sat Jul 04, 2009 4:48 am
No, Pilou. As a Palm fron grows [pardon the pun], it faces the sky with it's flat side facing up. Sometimes, slightly rotated but for the purpose of the exersice, lets keep it simple....
This is what i mean.
Then copy and rotate various frons to thicken up the folage...
Then do a little 'Fredo' bending....
So thats what i want to do with grow, however I just did this example manually...
Skippy attached FYI...
Thanks for your help with this idea, Pilou, much appreciated!! :thumb:
utiler
Top SketchUcator
Re: "Scaled array"
Postby pilou » Sat Jul 04, 2009 1:03 pm
Ok I see :)
Maybe monday a result :)
Speedy Galerie
Top SketchUcator
Re: "Scaled array"
Postby utiler » Sun Jul 05, 2009 1:04 am
Thanks Pilou, look forward to your reply..
:thumb: :thumb: :thumb:
utiler
Top SketchUcator
Re: "Scaled array"
Postby pilou » Sun Jul 05, 2009 2:06 am
Maybe this :)
But in fact all gives cool results just try different little variations
Palm's pull up is given by negative value ;)
Here with these regulates (click image)
Speedy Galerie
Top SketchUcator
Re: "Scaled array"
Postby utiler » Mon Jul 06, 2009 1:52 am
Pilou, My Grow dialouge Box looks a little different.... older or newer?
utiler
Top SketchUcator
Re: "Scaled array"
Postby utiler » Mon Jul 06, 2009 2:23 am
Still not working.... :evil:
Not getting the same result as you even though I am imputting the same data...
Ready to un-install.
utiler
Top SketchUcator
Re: "Scaled array"
Postby pilou » Mon Jul 06, 2009 3:15 am
You have an older version! ;)
The last version were in this same thread always by TIG ;)
Speedy Galerie
Top SketchUcator
Re: "Scaled array"
Postby utiler » Mon Jul 06, 2009 4:55 am
Damn!
I hate it when i feel amateurish... :oops:
Thanks Pilou, I think I am on the right track now. I will post some updates later.
Thank you kindly for your persistence.
:ecstatic:
utiler
Top SketchUcator
Re: "Scaled array"
Postby utiler » Mon Jul 06, 2009 5:52 am
Ok, I have loaded the new 2.1 version...
Did a little axis directions text [see attached.] It eems that the X axis directions are back to front. I would have thought that the postive directions would have been forward and the negative direction would be backwards....
Also, rotations around the Z axis are anti-clockwise. I thought it makes sense to have postive rotations clockwise and negative rotations anticlockwise.... [see also attached]
TIG, is there any reason for this?
Eitherway, I think i have it worked out. :thumb:
utiler
Top SketchUcator
Re: "Scaled array"
Postby hsjzyangbin » Fri Dec 18, 2009 10:22 am
HI,TIG,i wish the picture just like show
hsjzyangbin
Re: "Scaled array"
Postby TIG » Fri Dec 18, 2009 10:37 am
hsjzyangbin wrote:HI,TIG,i wish the picture just like show
You need to experiment with the 'Growth Point' origin in different places ? :?
Global Moderator
Re: "Scaled array"
Postby thomthom » Fri Dec 18, 2009 10:59 am
hm... I wonder if there is a copy+rotate plugin out here already...
PluginStore Author
PluginStore Author
Re: "Scaled array"
Postby TIG » Fri Dec 18, 2009 11:06 am
My Grow.rb already does this - there is an example of how to make a helical staircase in its threads...
Global Moderator
Re: "Scaled array"
Postby thomthom » Fri Dec 18, 2009 11:10 am
TIG wrote:My Grow.rb already does this - there is an example of how to make a helical staircase in its thread...
I'm not finding it easy to find it - is it this? viewtopic.php?f=180&t=20195&p=168380&hilit=+grow#p168380
It'd be best if it was in a thread by itself and not buried inside another thread.
PluginStore Author
PluginStore Author
Re: "Scaled array"
Postby TIG » Fri Dec 18, 2009 11:15 am
Grow.rb is a pretty old thing - probably predates the Forum !
It's available from Didier's Depot and if you search by author [TIG] and 'Grow' there are several threads about it where I uploaded a version for convenience, there are also examples in some threads...
Perhaps we could start a new thread to resurrect it - next week ?
Global Moderator
Re: "Scaled array"
Postby thomthom » Fri Dec 18, 2009 11:26 am
TIG wrote:Perhaps we could start a new thread to resurrect it - next week ?
That would be good.
Didier and Fredo had/has some old versions laying around as well. I noticed the last week several users seemed to have been downloading them instead of the new versions - despite noticed about newer versions. So I wanted to do a sweep of the plugin section and remove old versions and lock old obsolete threads. With the permission of the authors - in case they deliberately left them out there for legacy reasons.
PluginStore Author
PluginStore Author
Next
Return to Developers' Forum
Users browsing this forum: No registered users and 12 guests
