New API doc - typos and questions
Re: New API doc - typos and questions
Postby thomthom » Tue Dec 22, 2009 9:29 am
Edge.reversed_in?
http://code.google.com/intl/nb/apis/ske ... eversed_in?
Why is the example using a begin rescue structure? Does it on occasion cause errors?
PluginStore Author
PluginStore Author
class Sketchup::HLR undocumented
Postby Dan Rathbun » Mon Dec 28, 2009 8:51 pm
The class Sketchup::HLR is undocumented in the API.
It's an Entity subclass.
It inherits all the Entity baseclass methods, and adds 2 of it's own:
  • .calculate
  • .num_faces
If you create a HLR object at the console, and call .parent (when it has no parent) a BUG SPLAT! results. See post: http://forums.sketchucation.com/viewtopic.php?f=11&t=24740#p212101
What is this class HLR used for? (.. as there is no .add_HLR method for the Entities collection object.)
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby thomthom » Wed Dec 30, 2009 6:56 pm
    Tool.getExtents
    http://code.google.com/apis/sketchup/do ... getExtents
    The example given isn't a good one. From my observations, clipping occurs only when you draw outside the model boundary. So returning model.bounds is pointless.
    PluginStore Author
    PluginStore Author
    Sketchup.send_action to toggle StatusBar
    Postby Dan Rathbun » Thu Dec 31, 2009 6:01 am
    http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#send_action
    You can toggle the StatusBar on/off in Ruby (PC only?) via:
    Sketchup.send_action(59393)
    The following have no effect on my PC in SU ver 7.1.x:
    Sketchup.send_action(21019) hide Status bar and VCB
    Sketchup.send_action(21020) show Status bar and VCB
    Sketchup.send_action(21022) hide Status bar and VCB?
    ..whereas the above id 59393 does work for just the StatusBar.
    [ NOTE: I've moved my VCB up to the 2nd line of the Top Toolbar Container in 2nd position after the Layers toolbar, so I'd not want the VCB turned off with the StatusBar anyhow. I see them as two different things. ]
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      UI.toolbar_names
      Postby Dan Rathbun » Thu Dec 31, 2009 7:41 am
      UI.toolbar_names
      http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#toolbar_names
      Sketchup Ruby API wrote:The toolbar_names method is used to returns the name of all the available toolbars (this differs between PC and Mac).
      (1) In the above sentence "returns" should be singular.
      (2) I believe punctuation marks are supposed to go at the end of the words, ie: "Mac.)" not "Mac)." ...Language majors, confirm?
      (3) It would nice if we are to do cross-platform scripts, that you list the names for PC and Mac in the API.
      (4) UI.toolbar_names.sort on the PC, ver 7.1 returns:
      ["Camera", "Construction", "DisplayMode", "Drawing", "Edit", "GettingStarted", "Google", "Principle", "Section", "Standard", "StandardViews", "VCB", "Walk"]
      On the [Win32] Sketchup Menu: View > Toolbars (and toolbar captions):
      • Principle is Principal
      • Edit is Modification
      • VCB is Measurements
      • StandardViews is Views
      • Section is Sections
      • DisplayMode is FaceStyle
      • Walk is Walkthrough
      These are on the [Win32] Menu: View > Toolbars but, missing from the UI toolbar methods:
      • LargeToolSet
      • Layers
      • SceneTabs (on View menu )
      • Shadows
      Missing from View Menu and toolbar methods:
      • StatusBar
        (We can toggle it on/off [with send_action on PC], so might as well add it to the toolbar methods so we can test it's visiblilty, and use set_toolbar_visible for cross platform [if it can be toggled on MAC.])
      * If a user has the StatusBar off, a tool might want to instead display a messagebox if it must inform the user of some fact, so it needs to test whether it's on/off.
      (5) This same Toolbar Name Identifier Set is used with the following methods, and have the same problems, missing Identifiers, etc.
      • UI.set_toolbar_visible
      • UI.toolbar_visible?
      So.. we don't mind variation in the toolbar names/symbols, so long as we know what that variation is.
      (An alternative... we might create tb_Name constants under the UI module that would be the same for both platforms.)
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Re: UI.toolbar_names
        Postby Dan Rathbun » Thu Dec 31, 2009 9:40 am
        Dan Rathbun wrote:(An alternative... we might create tb_Name constants under the UI module that would be the same for both platforms.)
        Here's an example, call it 'UI_tb_const.rb'
        Code: Select all
        module UI
        # Example ONLY
        case Sketchup::OS
        when :WIN
          tb_CAM = 'Camera'.freeze
          tb_CONS = 'Construction'.freeze
          tb_DISP = 'DisplayMode'.freeze
          tb_DRAW = 'Drawing'.freeze
          tb_EDIT = 'Edit'.freeze
          tb_GETS = 'GettingStarted'.freeze
          tb_GOOG = 'Google'.freeze
          tb_LTS = 'LargeToolSet'.freeze
          tb_LAYR = 'Layers'.freeze
          tb_STD = 'Standard'.freeze
          tb_TABS = 'SceneTabs'.freeze
          tb_PRIN = 'Principle'.freeze # spelling!
          tb_SBAR = 'StatusBar'.freeze
          tb_SECT = 'Section'.freeze
          tb_SHAD = 'Shadows'.freeze
          tb_VIEW = 'StandardViews'.freeze
          tb_VCB = 'VCB'.freeze
          tb_WALK = 'Walk'.freeze
        when :OSX
           #     what are the Mac Strings?
        end # case
        end # module UI extension
          Dan Rathbun
          PluginStore Author
          PluginStore Author
          Postby thomthom » Fri Jan 01, 2010 4:39 pm
          Entities.add_curve
          http://code.google.com/apis/sketchup/do ... #add_curve
          Returns:
          curve a Curve object if successful
          SU7.1M1 PC returns an array of edges. Other versions untested. I'm submitting this as a bug.
          PluginStore Author
          PluginStore Author
          Postby thomthom » Fri Jan 01, 2010 4:42 pm
          Curve.move_vertices
          http://code.google.com/apis/sketchup/do ... e_vertices
          The vertices method retrieves a collection of all vertices in a curve.
          Seem to have copied the text from Curve.vertices.
          Description needs updating along with an example.
          PluginStore Author
          PluginStore Author
          Postby TIG » Fri Jan 01, 2010 7:26 pm
          thomthom wrote:Entities.add_curve
          Returns:
          It's always returned an array of edges - the curve is then array[0].curve
          Global Moderator
          Model.save_thumbnail
          Postby Dan Rathbun » Wed Jan 06, 2010 9:46 am
          BUG: SU ver 7.1.6087 win32
          Model.save_thumbnail (which only works for the current model,) but has a bug, in that if the model has never been saved, the method writes a blank thumbnail image to the %UserProfile% folder [actually to the current working directory,] instead of the Model folder specified in Preferences>Files>Model folderpath.
          If the current model has been saved with a thumbnail, then the thumbnail image is properly saved to the Model path as set in Preferences>Files>Model.
          UPDATE - the API should include a Model.refresh_thumbnail method, similar to (or perhaps using the same internal code as,) the ComponentDefinition.refresh_thumbnail method.
          _
            Dan Rathbun
            PluginStore Author
            PluginStore Author
            Model.title / Model.is_saved?
            Postby Dan Rathbun » Wed Jan 06, 2010 1:00 pm
            _
            Model.title
            Sketchup Ruby API wrote:The tile method retrieves the name of the model. If the model is saved on disk, returns the file name without extension. Otherwise returns an empty string.
            http://code.google.com/apis/sketchup/docs/ourdoc/model.html#title
            Change 'tile' to 'title' in method description.
            We could use Model.is_saved? and Model.is_unsaved? methods, as the Model.title method is the only way (that I can find) to determine if the model has yet been saved or not. We cannot rely upon the word 'Untitled' (in the caption bar) because that may actually be a valid filename.
            Workaround:
            Code: Select all
            class Sketchup::Model
            def is_saved?
              return not title.empty?
            def is_unsaved?
              return title.empty?
            end # class
            _
              Dan Rathbun
              PluginStore Author
              PluginStore Author
              Postby thomthom » Wed Jan 06, 2010 3:29 pm
              Camera.set
              http://code.google.com/intl/nb/apis/ske ... a.html#set
              Code: Select all
              The initialize method is deprecated. It essentially does the same thing as Camera.set.
              Seems that's the description for Camera.new http://code.google.com/intl/nb/apis/ske ... a.html#new
              ...and that Camera.new has the description for Camera.set
              PluginStore Author
              PluginStore Author
              Postby thomthom » Wed Jan 06, 2010 10:35 pm
              View.pickray
              http://code.google.com/apis/sketchup/do ... ml#pickray
              Returns:
              ray
              a ray
              "a ray"? Without testing this I#m guessing either a vector or line.
              PluginStore Author
              PluginStore Author
              Postby Dan Rathbun » Thu Jan 07, 2010 9:45 am
              thomthom wrote:View.pickray
              http://code.google.com/apis/sketchup/docs/ourdoc/view.html#pickray
              Setchup Ruby API wrote:Returns:
              ray a ray
              see this...
              Setchup Ruby API wrote:Model.raytest
              A ray is a two element array containing a point and a vector [Geom::Point3d(), Geom::Vector3d()]. http://code.google.com/apis/sketchup/docs/ourdoc/model.html#raytest
              _
                Dan Rathbun
                PluginStore Author
                PluginStore Author
                Postby thomthom » Thu Jan 07, 2010 9:51 am
                Yea - I tested it later that day. It's what the Geom module describes as a line.
                PluginStore Author
                PluginStore Author
                Re: Line / Ray
                Postby Dan Rathbun » Thu Jan 07, 2010 10:36 am
                thomthom wrote:Yea - I tested it later that day. It's what the Geom module describes as a line.
                Shouldn't the API have a definition for Line and/or Ray as a class (under the Geom module) ?
                something like:
                Code: Select all
                class Geom::Ray < Array
                  def new(*args)
                    Array[Geom::Point3d().new, Geom::Vector3d().new]
                    super()
                  Dan Rathbun
                  PluginStore Author
                  PluginStore Author
                  Postby thomthom » Thu Jan 07, 2010 10:40 am
                  Line and Plane? hm... maybe... thought of that myself. but never really felt the need for it to make a request. works fine as it is.
                  Dealing with them as Arrays works ok. They are simple structures.
                  PluginStore Author
                  PluginStore Author
                  Model.add_note
                  Postby Dan Rathbun » Mon Jan 11, 2010 2:38 pm
                  Model.add_note
                  The note is not displayed unless there are entities in the model. If you add a note first thing in a new model, it is invisible but .visible? on the note object still returns true.
                  As soon as you draw something, the note appears.
                    Dan Rathbun
                    PluginStore Author
                    PluginStore Author
                    Set class
                    Postby Dan Rathbun » Tue Jan 12, 2010 8:22 pm
                    Set class
                    http://code.google.com/apis/sketchup/docs/ourdoc/set.html
                    This class is defined in the Objectspace and should be listed under "Core Ruby Classes" (along with Array, Length, Numeric and String.)
                    Instead it's buried under "App Level Classes" and listed with all those classes that are defined inside the Sketchup module.
                    _
                      Dan Rathbun
                      PluginStore Author
                      PluginStore Author
                      Model.export
                      Postby Dan Rathbun » Tue Jan 12, 2010 11:12 pm
                      Model.export
                      http://code.google.com/apis/sketchup/docs/ourdoc/model.html#export
                      Sketchup Ruby API wrote:options_hash______ A hash containing the COLLADA (.dae) export options.
                      The options listed in the hash example is missing the option for hidden geometry.
                      The Registry Attribute Name is "ExportHiddenGeometry", but what is the options hash key?
                      • hiddengeometry ?
                      • hidden_geometry ?
                      _
                        Dan Rathbun
                        PluginStore Author
                        PluginStore Author
                        Postby Jim » Tue Jan 12, 2010 11:22 pm
                        Thanks Dan - yet more never-seen-before docs coming to light.
                        Jim
                        Global Moderator
                        Postby thomthom » Tue Jan 12, 2010 11:31 pm
                        I have the mental image of Scott drowning in printouts from this thread... :roll: :lol:
                        PluginStore Author
                        PluginStore Author
                        Postby Jim » Tue Jan 12, 2010 11:36 pm
                        Oh, I think there is a completely undocumented UTM class in there somewhere under Geom.
                        Jim
                        Global Moderator
                        Postby thomthom » Wed Jan 13, 2010 12:03 am
                        Jim wrote:Oh, I think there is a completely undocumented UTM class in there somewhere under Geom.
                        hm.. all I can find out about that one is:
                        Geom::UTM.instance_methods.sort.join("\n")
                        (eval):894: warning: instance_methods: parameter will default to 'true' as of 1.8.1
                        to_a
                        to_latlong
                        to_s
                        x
                        y
                        zone_letter
                        zone_number
                        PluginStore Author
                        PluginStore Author
                        Geom::UTM
                        Postby Dan Rathbun » Wed Jan 13, 2010 4:13 am
                        Geom::UTM.instance_methods.sort.join("\n")... snip ...
                        from Wikipedia search on "UTM":
                        Universal Transverse Mercator coordinate system, a grid-based method of mapping locations on the surface of the Earth.
                        http://en.wikipedia.org/wiki/Universal_Transverse_Mercator_coordinate_system
                        _
                          Dan Rathbun
                          PluginStore Author
                          PluginStore Author
                          Postby Jim » Fri Jan 15, 2010 3:31 pm
                          View.show_frame
                          Documentation for this method contains some poorly-parsed html tags.
                          Jim
                          Global Moderator
                          Model.get_product_family
                          Postby Dan Rathbun » Sun Jan 17, 2010 4:58 pm
                          http://code.google.com/apis/sketchup/docs/ourdoc/model.html#get_product_family
                          Skecthup Ruby API wrote:Returns a constant number which indicates the product family of the installed SketchUp application.
                          This is an Application related attribute, why is it part of the Model class?
                          This should be a method of the Sketchup module as in: Sketchup.get_product_family
                          _
                            Dan Rathbun
                            PluginStore Author
                            PluginStore Author
                            OptionsProviderObserver.onOptionsProviderChanged
                            Postby Dan Rathbun » Sun Jan 17, 2010 6:22 pm
                            http://code.google.com/apis/sketchup/docs/ourdoc/optionsproviderobserver.html#onOptionsProviderChanged
                            Sketchup Ruby API wrote:The onOptionsProviderChanged method is invoked when an element is added to an Pages object.
                            Should read, "The onOptionsProviderChanged method is invoked when an option is changed for an OptionsProvider object."
                            _
                              Dan Rathbun
                              PluginStore Author
                              PluginStore Author
                              Postby thomthom » Fri Jan 22, 2010 12:41 pm
                              Entities.add_curve
                              http://code.google.com/intl/nb/apis/ske ... #add_curve
                              Returns an array of edges - not a Curve object.
                              PluginStore Author
                              PluginStore Author
                              Postby TIG » Fri Jan 22, 2010 1:04 pm
                              Ita's the same as add_circle which returns an array od edges and to find the just made curves curve you use edges=entities.add_curve(array_of_points)
                              curve=edges[0].curve
                              But strangely not with add_arc which returns an ArcCurve ?
                              It would be unadvisable to change what the API does with these add_ methods - rather it we should keep it as is and fix the API's Guide to reflect it properly - too many scripts already get the curve from the edges array and would fail if it were updated to return the curve not the curve's edges...
                              Global Moderator
                              PreviousNext
                              Return to Developers' Forum
                              Users browsing this forum: Dietmar Hammes, Grrr1337, ianieess, RijecnikStranihRijeci, ym1124 and 10 guests
