About 'intersect_with' method
Postby Didier Bur » Fri Nov 28, 2008 9:33 pm
Has anyone ever figured out how this method works? Doc is sparse, no example and I cannot see what are all these entities and transformations parameters for.
Any help anyone ? Please be more clear than SU team ;)
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Re: About 'intersect_with' method
Postby Whaat » Fri Nov 28, 2008 10:14 pm
I have used this method a few times. Look at my Zorro script for an example.
Code: Select all
entities.intersect_with recurse, transformation1, entities1, transformation2, hidden, entites2
Let's say you want to intersect two groups. Assume that group 1 is a cube and group 2 is a sphere.
First get the necessary entities objects:
Code: Select all
cube_entities=group1.entities
sphere_entities=group2.entities
Then, get the transformations of each group:
Code: Select all
cube_trans=group1.transformation
sphere_trans=group2.transformation
Let's ignore recursion.
Code: Select all
recursion=false
To perform the intersection and make the intersection lines appear in the cube group:
Code: Select all
cube_entities.intersect_with(recursion,cube_trans,cube_entities,cube_trans,false,[group2])
The API docs seem to be incorrect. The last argument of this method must be an array of entities, not an entities object. The last argument is the just list of entities that you want intersect with.
To make the intersection lines appear in the sphere group:
Code: Select all
sphere_entities.intersect_with(recursion,sphere_trans,sphere_entities,sphere_trans,false,[group1])
However, the following might also work but I haven't tried it this way:
Code: Select all
cube_entities.intersect_with(recursion,cube_trans,sphere_entities,sphere_trans,false,[group2])
To make the intersection lines appear in some other entities object, I would try this (haven't tested):
Code: Select all
cube_entities.intersect_with(recursion,cube_trans,some_other_entities,some_other_entities_trans,false,[group2])
API Docs wrote:Arguments
recurse - true if you want this entities object to be recursed (intersection lines will be put inside of groups and components within this entities object)
transformation1 - the transformation for this entities object
entities1 - the entities where you want the intersection lines to appear
transformation2 - the transformation for entities1
hidden - true if you want hidden geometry in this entities object to be used in the intersection
entities2 - an entities object, or an array of entity
Hope this works...
Dale
Whaat
PluginStore Author
PluginStore Author
Postby Didier Bur » Fri Nov 28, 2008 11:54 pm
Thanks a lot Dale, very clear. You made my day :fecstatic:
Didier Bur
Didier Bur
Postby TIG » Sun Nov 30, 2008 9:30 pm
Didier Bur wrote:Hi,
Read my scripts like Slicer, ContourMaker, Volume(v1) etc that all use method it - there is a ## part that explains what it's doing within the method - actually that's so I don't forget it later !!!!! - it's all a bit "trial and error"... but it is logical when you 'get' how the parts interact...
Global Moderator
Postby Didier Bur » Sun Nov 30, 2008 9:45 pm
Hi TIG,
Thanks for pointing me to your scripts (I had read them already). I've finally achieved what I was searching for: cropping a terrain mesh with a shape (a face that pushpulls itself, does intersect with terrain, and then erase all that is outside this cropping prism). It's like a 'drape and clean' function. Fun !
Didier Bur
Didier Bur
Postby Edson » Mon Dec 01, 2008 1:44 pm
Didier Bur wrote:Hi TIG,
didier,
this is the method i use for putting roads and stuff onto a terrain. it works much better than the drape tool. it is just more time consuming.
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby Didier Bur » Mon Dec 01, 2008 7:54 pm
Hi Edson,
You would save a lot of time using the script I'm working on (WIP) but it is part of a private contract submission, so I don't know if I can release it to public. I think no :(
Regards,
crop.swf
Didier Bur
Didier Bur
Postby Edson » Mon Dec 01, 2008 8:15 pm
didier,
my mouth was watery after i saw the animation! i wish you find a way of making it public. it would be a success, for sure.
congratulations.
Edson
Global Moderator
Return to Developers' Forum
Users browsing this forum: Nadir143 and 17 guests
