Slicer-excellent ruby
Postby tomislavm » Thu Jun 12, 2008 8:32 am
today I have found this excellent ruby and this site, http://www.rcgroups.com/forums/showthread.php?t=826409
tomislavm
Re: Slicer-excellent ruby
Postby HFM » Thu Jun 12, 2008 8:37 am
Great! I've been waiting for this one ever since 'Slicer2' !!!
No seriously what does it do,... info ? :D
HFM
Postby plot-paris » Thu Jun 12, 2008 8:38 am
what is it doing? sounds a bit like Zorro... ;)
plot-paris
Postby pilou » Thu Jun 12, 2008 8:47 am
Copyright 2005-2007, TIG
Zorro is Whaat ;)
And not exactly the same :roll:
Speedy Galerie
Top SketchUcator
Postby tomislavm » Thu Jun 12, 2008 8:57 am
sketchup model slice in parts by x or z or y.
tomislavm
Postby tomislavm » Thu Jun 12, 2008 9:10 am
another one
tomislavm
Postby HFM » Thu Jun 12, 2008 10:28 am
That's pretty fance :thumb:
good for creating abstract models :D
HFM
Postby Didier Bur » Thu Jun 12, 2008 12:36 pm
This one is one my site since October 2007...
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Postby plot-paris » Thu Jun 12, 2008 3:12 pm
oh my god, this is really great! and thanks for the demonstration
just imagine how easy it is to create a terrain model now. simply print out the sliced outlines and cut them out of a foamboard...
thanks a lot. I will definitely find it very useful!
plot-paris
Postby xrok1 » Mon Aug 03, 2009 6:38 pm
bump! ;)
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby trock2957 » Thu Dec 03, 2009 4:19 am
I can't believe what is capable with a free 3D program like sketchup and the amazing scripts people are giving away!
Several years ago I bought Rhino just to do some slice modeling. Wow!
Thanks so much for this great plugin.
trock2957
Postby lapx » Sun Mar 06, 2011 5:48 pm
Why is slicer not finishing some of the slices? The shape was made with bezier curve and fredo's cuviloft function then slicer.
lapx
Postby TIG » Sun Mar 06, 2011 5:59 pm
lapx wrote:Why is slicer not finishing some of the slices? The shape was made with bezier curve and fredo's cuviloft function then slicer.
I can't be sure without having the SKP itself.
Can you please purge and then post the SKP in question, so I can run some tests on it pre/post Slicing...
If it's 'confidential' then attach it to a PM to me... ;)
Global Moderator
Postby lapx » Sun Mar 06, 2011 7:20 pm
Thanks Tig! Here ya go.
lapx
Postby TIG » Sun Mar 06, 2011 8:20 pm
My initial look through this finds no issues with the SKP OR with Slicer itself... BUT it DOES miss out vital edges in some random slices whatever settings I try too - which [at the moment is inexplicable, and] I am looking at :? :? :?
I'll continue looking and report back... any one else who wants to chip in please do... I am currently at a loss............
Global Moderator
Postby TIG » Sun Mar 06, 2011 11:46 pm
The problem seems to be that the built-in AND API's 'intersect' method fail to intersect a seemingly coplanar face with a cutting plane.
Try this by hand to see that you cannot cut an intersected loop through some faces... the error occurs at a few non-triangulated faces as I show in the image... IF you triangulate the problem facet then the problem doesn't occur :roll:
Similarly IF you use my triangulate tool on ALL of the faces [selected inside the object], THEN when using Slice it works fine... therefore it seems a weirdness in the 'intersect' method not taking a quad face as cutting as it is perhaps not quite coplanar in its 4 edges... BUT it is thought coplanar enough to be considered one face when it's NOT triangulated and so it exists and display OK ??????
Global Moderator
Postby lapx » Sun Mar 06, 2011 11:57 pm
Tig your are a genuis! I'm not familiar with your triagulation tool but I'll look into it.
I hope its as simple as selecting all faces and executing the command ;)
Thanks for the help Tig!
lapx
Postby lapx » Mon Mar 07, 2011 12:05 am
Tig again, I must thank you! It worked like a charm.
lapx
Postby TIG » Mon Mar 07, 2011 12:07 am
I have reported the weirdness to the powers that be at Google - it is certainly reproducible although I had never seen it before... Meanwhile the temp fix 'Triangulate Faces' is here viewtopic.php?p=175613#p175613 for the rest of you...
Global Moderator
Return to Developers' Forum
Users browsing this forum: Ayaniku, iandefazio and 10 guests
