right-click causes 'bong' error sound on mac
Postby troyhome » Wed May 06, 2009 11:26 pm
Whenever I right-click while using SU, i get a "bong" sound- the error sound made by my Mac. There are no problems with the right-click functioning- i just have to turn my sound off to get any work done.
Any ideas why?
It just started happening.
IOviz.com
SU Pro 2017 PC
Thea: latest
vray4SU latest
User avatar
troyhome
Re: right-click causes 'bong' error sound on mac
Postby jeff hammond » Wed May 06, 2009 11:31 pm
so you can't bring up the context menu?
what happens if you push control and left click?
User avatar
Global Moderator
Postby solo » Wed May 06, 2009 11:33 pm
I get the same issue on one of my XP machines, I turned the sound off. :?
I'm better with polys than words
User avatar
Global Moderator
Postby troyhome » Wed May 06, 2009 11:42 pm
Jeff Hammond wrote:so you can't bring up the context menu?
The context menu comes up just fine- in fact everything works just fine... except the annoying beep.
I see it's not just a mac issue...
mysterious.
IOviz.com
SU Pro 2017 PC
Thea: latest
vray4SU latest
User avatar
troyhome
Postby Chris Fullmer » Wed May 06, 2009 11:45 pm
It could definitely be a script doing it. If you can figure out which script it is, I can help you remove the annonying boing from the code.
User avatar
SketchUp Team
SketchUp Team
Postby Gaieus » Thu May 07, 2009 11:03 am
You might be on the right track, Chris. AS IF I'd remembered something like this.
User avatar
Postby Anssi » Thu May 07, 2009 6:00 pm
Gaieus wrote:You might be on the right track, Chris. AS IF I'd remembered something like this.
You might be remembering the HouseBuilder script...
Anssi
User avatar
Anssi
Postby troyhome » Fri May 08, 2009 2:07 am
Chris Fullmer wrote:It could definitely be a script doing it. If you can figure out which script it is, I can help you remove the annonying boing from the code.
It could be the housebuilder script- i loaded that just around the time i upgraded the Fredolib and Freescale scripts... ??
IOviz.com
SU Pro 2017 PC
Thea: latest
vray4SU latest
User avatar
troyhome
Postby Chris Fullmer » Fri May 08, 2009 2:36 am
I can confirm that housebuilder has a few beeps in it and once I installed it, it makes my right click beep all the time. I can't fix it and host the file here - against forum policy. So here's how to fix it on your own.
Open the file Plugins\HouseBuilder\HouseBuilderTool.rb in a text editor.
Search for the word "beep". There should be 7 of them, and they all are on a line like this:
UI.beep
Just add a # sign in front of that line. So it should look like:
#UI.beep
That will silence all beeps from the script. Again, there are 7 places that beep in the script. To be precise, I think it is the 4th one that is causing the right click beeps. It is on line 800 in my version of the script I just downloaded.
Hope that helps silence your beeps,
User avatar
SketchUp Team
SketchUp Team
Postby Gaieus » Fri May 08, 2009 11:39 am
Thanks Ansi and Chris - yes, I can now remember. :thumb:
User avatar
Postby Phil Rader, AIA » Fri May 08, 2009 3:14 pm
>>>off topic<<<
Csaba what exactly is your avatar?
Phil Rader, AIA
Premium Member
Premium Member
Postby TIG » Fri May 08, 2009 4:04 pm
I think Gaieus's avatar is a calm spined puffer-fish [blowfish] - or something equally ugly... Better than that ugly horse anyway... ;)
User avatar
Global Moderator
Postby troyhome » Fri May 08, 2009 9:51 pm
Chris,
Thanks so much! this totally worked! I feel uneasy when things are not working as they should, so now i can relax :)
IOviz.com
SU Pro 2017 PC
Thea: latest
vray4SU latest
User avatar
troyhome
Postby Chris Fullmer » Fri May 08, 2009 11:16 pm
Good, glad it worked!
User avatar
SketchUp Team
SketchUp Team
Postby paulofukuta » Mon Dec 02, 2019 1:46 pm
Hi!
First of all, I would like to say that I know absolutely nothing about programming. But I still tried to correct this error :lol: . And my english is not very good. Then ignore possible grammar errors.
I tried to do the walkthrough explained by Chris Fullmer, but couldn't find "UI.beep". When I open the HouseBuilderTool.rb file in a text editor, it appears as the posted image.
If you can give me another tip, my ears would appreciate it! :D
User avatar
paulofukuta
Postby TIG » Mon Dec 02, 2019 4:15 pm
Where did you get the HouseBuilder RBZ from ?
I guess it's the metric one, as that is obfuscated...
The latest version of it has the wayward UI.beep code removed...
There are links to the posts where you can download the very latest versions' RBZ files - see this post for those links:
viewtopic.php?p=564448#p564448
User avatar
Global Moderator
Postby paulofukuta » Mon Dec 02, 2019 9:25 pm
Hi!
The last time I downloaded, yesterday, was from here:
viewtopic.php?p=519210
But I've downloaded it so many times that I'm pretty lost ... So I have no idea which of the downloaded files I'm currently using. I believe I also converted rb to RBZ by changing the extension to ZIP. I don't know if this could have caused this "problem" of finding UI.beep.
I will try for this link you indicated! :)
User avatar
paulofukuta
Postby paulofukuta » Mon Dec 02, 2019 9:41 pm
Hi!
I accessed the link and downloaded the plugin again.
This time I downloaded the ZIP file instead of RZB. But still the same thing ... With the beep and opening the file RB also can not find the Ui.beep.
If you have one more tip, thank you for your help! :)
User avatar
paulofukuta
Postby TIG » Tue Dec 03, 2019 7:11 pm
Why haven't you downloaded the latest in RBZ format from one of the two links, that were given in the post that I linked to earlier ??
If you try any earlier versions you WILL have problems !
User avatar
Global Moderator
Postby paulofukuta » Tue Dec 03, 2019 11:15 pm
I tested both versions, RB and RZB, of this link you are pointing to. Both versions have beep.
User avatar
paulofukuta
Postby TIG » Tue Dec 03, 2019 11:45 pm
I have just retested both versions and there are only 'beeps' when you make an incorrect choice in one of the tools...
Can you explain the exact circumstances under which you hear the 'beeps'...
There are NO RB files in the links - just RBZ files.
When you download these RBZ files how are you 'installing' them ??
The definitive versions of both units versions of the [old] tool have been linked for almost 5 years !
They work for everyone else, so maybe you have some really old file versions clogging up your system, and therefore you need to delete manually them before attempting a 'good' install... ???
User avatar
Global Moderator
Postby paulofukuta » Wed Dec 04, 2019 3:51 am
This link that you posted in one of the messages above leads us a post there are the following links:
Metric:
http://sketchucation.com/forums/viewtop ... 10#p519210
Imperial:
http://sketchucation.com/forums/viewtop ... 63#p556663
I use the metric system ... Clicking on the metric system link, we go to a third post that shows two files:
HouseBuilder_metric_12 [TIG] .zip
HouseBuilder_metric_12 [TIG] .rbz
As I said earlier, I have already tested these two files and both files are beeping. The RBZ file, I install by opening SketchUp 2019> Windows> Extension Manager.
Already the ZIP file, I always unzipped and installed manually, copying and pasting in the plugin folder:
C: \ Users \ ... \ AppData \ Roaming \ SketchUp \ SketchUp 2019 \ SketchUp \ Plugins
The beep happens every time I right click on any object. So, for example, if I want to right-click to create a group / component or work with dynamic components, the beep will sound. Something that does not happen when the plugin is not installed. The beep also happened when I moved the mouse arrow over the Edit button. But it seems that it is no longer happening now. I do not know is because of the installation of another version of the plugin. When I right-click on any name inside the Outliner window the beep sounds too. So, I believe that for everything that the right button has a function, there will be the beep sound.
I use SketchUp 2019 in Portuguese, I don't know if this can interfere with the plugin's operation. And also tested in Portuguese version 2016, but the same thing happens.
Maybe this beep is like that, as you said, "when you make an incorrect choice". And I'm interpreting it as something nonstandard.
Thank you for your help! :)
User avatar
paulofukuta
Postby TIG » Wed Dec 04, 2019 11:40 am
I apologize !
I have managed to replicate an odd beep on a right-click selection...
Relating to metric HouseBuilder
:shock:
I'll look at it again...
Its code is obfuscated, so it's not so easy to see...
User avatar
Global Moderator
Postby TIG » Wed Dec 04, 2019 3:36 pm
I've updated the metric version's RBZ here: http://sketchucation.com/forums/viewtop ... 10#p519210
It is now 'bong' free - I hope !
I've also deleted the ZIP version to avoid confusion...
User avatar
Global Moderator
Postby paulofukuta » Wed Dec 04, 2019 4:23 pm
Beep never more !!!
Thank you so much! :D :D :D
User avatar
paulofukuta
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Developers' Forum
cron
Who is online
Users browsing this forum: No registered users and 5 guests
Visit our sponsors:
