Component definition has TWO names ???
Postby Didier Bur » Thu Jul 18, 2019 8:14 am
Anyone ever noticed that a component definition has TWO names ?
Just like materials, it seems to me that there is a definition "real" name AND some sort of "display name".
Look at the picture below: internally the component definition is named "Plant_Umbrella" and it appears in the infos palette under "Plante_parapluie" ("parapluie" is the french word for "umbrella")
The ComponentDefinition class doesn't have a "display_name" method like the Material class do.
So the question is: is there a way to retrieve the display name ?
Help TIG, Dan, Thomthom and all ruby gurus ;-)
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
User avatar
Didier Bur
Re: Component definition has TWO names ???
Postby Gábor » Thu Jul 18, 2019 10:42 am
I don't have the answer as I'm not a SketchUp guru. But I have a layman's question: How did you achieve this "double name"? Could you please attach an .skp with such a component definition in it or describe how to create one?
Gábor
Postby TIG » Thu Jul 18, 2019 2:35 pm
A SKP uploaded which shows this would be helpful...
I haven't ever seen this.
But you can have a component that starts off being 'external' and is renamed after insertion.
Let's say its external SKP is named "XXX.skp".
You import it...
Sketchup.active_model.selection[0].definition.name >>> "XXX"
File.basename(Sketchup.active_model.selection[0].definition.path, ".*") >>> "XXX"
Rename the component as "ZZZ"
Sketchup.active_model.selection[0].definition.name >>> "ZZZ"
But I see no equivalent of name / display_name, as with materials...
User avatar
Global Moderator
Postby Didier Bur » Sun Jul 21, 2019 11:27 am
Thanks TIG for the explanation. I also noticed the "path" and "rename definition" tricks.
BUT what I discovered is the following:
If a component was imported from a path that doesn't exist anymore on you system, even if you rename its definition, Sketchup.active_model.selection[0].definition.name will output the imported SKP file name, and you cannot retrieve the new definition name.
Strange behavior, isn't it...
In fact:
The component definition name is NOT ALWAYS the name of the SKP you imported to use that component:
- import a component, say A.skp, containing a red cube
- select it and type Sketchup.active_model.selection[0].definition.path, you'll get, say c:\Users\TIG\DeskTop\A.skp
- BUT Sketchup.active_model.selection[0].definition.name will output, say: Red cube
- open the A.skp file in Sketchup
- Sketchup.active_model.name will output, say: Red Cube
Sketchup.active_model.name is NOT (always) the same as the SKP file name...
Didier Bur
User avatar
Didier Bur
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: kaspars and 3 guests
Visit our sponsors:
