Selected entity question
Postby Pixero » Wed May 15, 2019 9:29 am
Short question.
Is:
Code: Select all
Sketchup.active_model.active_entities[0]
the selected entity?
User avatar
Pixero
Re: Selected entity question
Postby jiminy-billy-bob » Wed May 15, 2019 8:26 pm
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Pixero » Wed May 15, 2019 10:02 pm
Thanks. That was what I suspected.
Now I need to find a way to do what I want to do from the selection.
A side question. What about getting the selected material?
Sketchup.active_model.materials[0] won’t do it then either I guess?
User avatar
Pixero
Postby jiminy-billy-bob » Sat May 18, 2019 10:23 pm
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby TIG » Sun May 19, 2019 6:28 pm
That method gives you the current 'active' material in the model.
But... if you want to get a material from the currently selected entity, then you use:
Code: Select all
mat = Sketchup.active_model.selection[0].material
However, you might be better off filtering the selection, until you get an entity of the kind you want... e.g.
Code: Select all
face = Sketchup.active_model.selection.grep(Sketchup::Face)[0]
mat = nil
mat = face.material if face
Where the first face in the selection returns its material, or nil...
User avatar
Global Moderator
Postby Pixero » Sun May 19, 2019 7:30 pm
Thanks, I read in a older post somewhere, and I think it was by Thomthom, that there was a bug that could Bugsplat SU when using materials.current if there wasn't any materials in SU. Do you know if that still is an issue or if it has been fixed?
User avatar
Pixero
Postby TIG » Sun May 19, 2019 7:45 pm
Why do you need to get the model.materials.current ?
You could pre-set it using model.materials.current = a_material
Having previously set a_material = model.materials["A_Name"]
You haven't really explained the full context......
User avatar
Global Moderator
Postby Pixero » Sun May 19, 2019 7:54 pm
They are just for two small snippets that I will need some advise from Thomasz (Thea settings) to make them properly.
I'm just preparing for when he will have some time to look into it...
User avatar
Pixero
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: No registered users and 8 guests
Visit our sponsors:
