[Plugin] SmartPushPull v0.26 (05 nov)
• Page 1 of 3 • 1, 2, 3
[Plugin] SmartPushPull v0.26 (05 nov)I have always wanted this feature, and since it didn't appear as of now, I have decided to dedicate few hours to it. It is far from perfect but works in many cases.
v0.26 (05 nov) 5. Tab key toggles between normal Push/Pull and Smart Push/Pull behavior v0.25 (05 nov) ADDED: 2.vcb (aka "Measurements") shows the offset distance and typing custom value sets the offset 6.easier to set the distance with the mouse 7.single click confirmation 8.works inside unopen groups v0.11 (05 nov) very minor update - it makes the push/pull in more cases then 0.1 but still fails to create non planar side faces in those v0.1 problematic scenarios v0.1 (04 nov) Available/In-progress/Missing functionality LIST: 0.Push/Pull faces in their natural shape and mesh context 1.ability to toggle between additive push-pull (similar to sketchup push/pull + ctrl), normal push-pull and target face only (great for solid subdivision) 2.ability to control offset via the VCB 3.nicer and better algorithm (to clean unnecessary original lines, to correctly offset all scenarios) 4.toolbar with icon and cursor icon 5.ability to toggle the standard push/pull behavior 6.better dynamic offset interface - at the moment it doesn't work right and you have to change camera position to allow for setting the offset (ecuadorian) 7.simple click to confirm the action instead of the doubleclick (thomthom) 8.work inside unopen groups 9.code cleanup!!! and commenting any help with the above is appreciated HUGE THANKS TO FREDO6 for leaving his code unencrypted, most of the dynamic offset code is from him Last edited by a4chitect on Thu Nov 05, 2009 10:28 pm, edited 12 times in total.
Re: [Plugin] SmartPushPull v0.1 (04 nov)That's great, I'll try to check it out later. Thanks!
Re: [Plugin] SmartPushPull v0.1 (04 nov)incredible. excellent tool, thank you very much for sharing
Re: [Plugin] SmartPushPull v0.1 (04 nov)Getting rid of the extra material is a lot easier than trying to do this manually, thank you!
![]() -Miguel Lescano
Subscribe to my house plans YouTube channel! (30K+ subs) Re: [Plugin] SmartPushPull v0.1 (04 nov)WOW!!! I can't wait to try this.....!
![]() love it mate, very cool!!!!! ![]() ![]() purpose/expression/purpose/....
Re: [Plugin] SmartPushPull v0.1 (04 nov)Thanks a4chitect for the script also for the very clear explanatory graphic.
Mike
Re: [Plugin] SmartPushPull v0.1 (04 nov)Sweet!
![]() Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] SmartPushPull v0.1 (04 nov)nice and smarty. thank you.
hire me @ http://www.publied.it !
Re: [Plugin] SmartPushPull v0.1 (04 nov)Finally! Shiny!
Dear ruby coders please help arc4tect to refine this tool (long awaited and really usefull- a real pearl in the ruby slag) Re: [Plugin] SmartPushPull v0.1 (04 nov)Hi Everyone,
How can i use this plugin? i already download it. Thanks Re: [Plugin] SmartPushPull v0.1 (04 nov)
Tools->SmartPP Extrude the face and doubleclick to finish. btw, a4chitect: why do you have to doubleclick? Why not normal click like the regular PP? Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] SmartPushPull v0.1 (04 nov)I really like this plugin. Really looking forward to see how it develops.
I tried it on some simple shape and it worked most of the time. But occasionally it doesn't - not sure why, can't tell the different between what works and what doesn't.
I've attached a sample model which caused the error. I was trying to SPP the face I highlighted orange. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] SmartPushPull v0.1 (04 nov)thanks for all the cheers! will look into all the requests but please be patient. I'm not abandoning the development
![]() thomthom: I'm aware of this bug - it is all due to almost no exception-catching code
Re: [Plugin] SmartPushPull v0.11 (05 nov)Wow, thank you a4chitect.
![]() You know, I never use the default scale tool anymore as Fredo's scale (and taper) tool is much better. Your 'smart push pull' concept has the same potential to knock the old default Sketchup PushPull out of business. Wonderful concept man! I hope you will keep on working on it as this can become a life saving gem. Thanks again. Re: [Plugin] SmartPushPull v0.11 (05 nov)
1+ absolutely fabulous tool, a4chitect. thanks a lot. Re: [Plugin] SmartPushPull v0.11 (05 nov)Great tool. Just one idea maybe, when you select the face you want to extrude, you get the option of deleting the original lines to clean it up. Would be a nice addition. but still a great plugin nether the less.
I thought the same thing, TT. purpose/expression/purpose/....
Re: [Plugin] SmartPushPull v0.11 (05 nov)Hi ar4itect I think your 'to do' list misses multiple adjasent\non adjacent faces push-pull.
It'd be special case of Fredo's JPP. BTW While ago I asked him to implement it but unfortunatly it didn't happen. Re: [Plugin] SmartPushPull v0.11 (05 nov)oh, and to make it the almighty super tool, you could enalbe push/pull of more than one selected face simulaneously, making it a lot faster to do extrude several faces with the sam distance (something that I always wanted the push/pull tool to be capable of)
![]() Re: [Plugin] SmartPushPull v0.11 (05 nov)a4chitect,
very usefull ruby, well done ! For me the possibilty to control the offset by means of the VCB is the one thing that is missing to make it a true replacement for the 'standard' push pull tool. (But it is already in the to do list !! ![]() Thanks for sharing, erikB Re: [Plugin] SmartPushPull v0.11 (05 nov)okay . .this is total awesomenicity. Any possible way it could be written to be accessed from a right-click like JPP? That would just be cherry.
THx, D If I make it look easy...It is probably easy
Re: [Plugin] SmartPushPull v0.11 (05 nov)Yeee! Thanks a lot for this plugin
![]() MALAISE La Connaissance n'a de valeur que partagée
Re: [Plugin] SmartPushPull v0.26 (05 nov)oooh!
“The one fact about the future of which we can be certain is that it will be utterly fantastic” – Arthur C Clarke “The one fact about ruby coders of which we can be certain is that next ruby plugin will be utterly fantastic” – Matteo Bignozzi thank you a lot arc4tect hire me: http://www.nonsolo3d.it/ !
Re: [Plugin] SmartPushPull v0.26 (05 nov)Fantastic tool. I've been wishing for something like this for a while.
Nice job, I'm looking forward to any improvements you make.
Re: [Plugin] SmartPushPull v0.26 (05 nov)Very nice,
I noticed the original lines remain, hahe you though of using smething like "remove cplanar edges" to eliminate thos elines after the push/pull operation? Great job anyways!
Who is online
Users browsing this forum: Bing [Bot], emrecukur2121, Jessica1986, Kondybas, ligustavo, ngoc_diem_arch, spe1, venuaravind and 17 guests
