[Tutorial] Rounded Rectangle
Share or learn with the Pros
Re: Rounded Rectangle
Postby dolphus » Sun Apr 20, 2008 7:38 am
thanx Coen i have done this the HARD way so often ...... :ecstatic:
dolphus
Postby Edson » Sun Apr 20, 2008 11:05 am
great tut, coen. thanks.
btw, what app do you use to make your tuts?
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby pilou » Sun Apr 20, 2008 3:51 pm
...perpendicular to the starting edge :?:
I am perplex :shock:
Is not more "at the egal distance from the external commune vertex"? ;)
Now it is 45°(or 135°) to the starting edge so not perpendicular! ;)
Speedy Galerie
Top SketchUcator
Postby caddict » Thu Apr 24, 2008 4:26 am
Thanks for a new trick Coen :D
with the rotation tool, pick the centre of rotation and then control the axis of rotation by holding down lmb and sliding in the required direction. Great! I've always rotated the model to get a different axis, which can be annoying.
caddict
Postby el.antuan » Sat Apr 26, 2008 10:05 am
I agree: Great tut!!
cheers.
"En las fiestas no te sientes jamás; puede sentarse a tu lado alguien que no te guste." Groucho Marx
el.antuan
Postby August » Tue May 20, 2008 9:44 am
Edson wrote:btw, what app do you use to make your tuts?
Yes, please, a tutorial on how to make that tutorial would be nice!
August
August
Postby philem » Tue May 20, 2008 11:08 am
August
Great Tut.
Yes please, A tutorial on how to make the tutorials and how to upload them to this forum would be great..
Just do it, it might be fun.
philem
Postby August » Mon Feb 16, 2009 5:17 am
Hi Coen,
Did this ever get covered anywhere else? To have it interactive right there in the forum post is really sweet. Pointers, tips, tricks, etc. would all be appreciated.
Thanks,
August
“An idea, like a ghost, must be spoken to a little before it will explain itself.”
-- Charles Dickens
August
Re: [Tutorial] Rounded Rectangle
Postby boofredlay » Mon Feb 16, 2009 8:36 pm
I will send Coen a PM, I would like to know as well :D
boofredlay
Global Moderator
Postby boofredlay » Tue Feb 17, 2009 2:52 am
He used Instant Demo.
http://www.instant-demo.com/
boofredlay
Global Moderator
Postby Gaieus » Tue Feb 17, 2009 11:47 am
Was it not Wink? I have always though it was.
Postby boofredlay » Wed Feb 18, 2009 8:17 pm
It was not Wink. ;)
boofredlay
Global Moderator
Postby agpig » Mon Mar 16, 2009 12:35 pm
thanks, it is quite helpful
agpig
Postby pilou » Mon Mar 16, 2009 1:37 pm
It was not Wink
but result is quasi the same :)
Speedy Galerie
Top SketchUcator
Postby zzzSPUDzzz » Tue Mar 24, 2009 1:15 pm
Hey Coen Nice tutorial mate but can't you get the same result using fillet ...... just highlight your rectangle and click on fillet and type in your radius.............
zzzSPUDzzz
Postby caddict » Tue Mar 24, 2009 8:20 pm
I would guess the fillet ruby wasn't around when Coen made the tutorial
caddict
Postby zzzSPUDzzz » Wed Mar 25, 2009 12:02 pm
caddict wrote:I would guess the fillet ruby wasn't around when Coen made the tutorial
Yeah just looked at the date of the tutorial it's been a while, just shows how much easier SketchUp is when you throw in a
few good rubys.............
zzzSPUDzzz
Postby Gaieus » Thu Mar 26, 2009 3:28 am
It's not always about being able to do it easier with rubies. You should actually learn to do these things by hand, with native SU tools so that you model safely and with self confidence. Then can the rubies come to speed up your workflow...
Postby simon le bon » Thu Mar 26, 2009 6:01 pm
Hey Coen,
I was reflecting myself on a way to make this simple figure (rounded rectangle) easy to do in SU, and i am fallen up on your tut :thumb:
Using the Rotate Tool along the proper axis to reverse the first two corners, was what i was still missing. ;)
Here is, using your way, a little more quick solution:
PS to Gaieus: no use here of any ruby :|
simon
simon le bon
Postby Gaieus » Thu Mar 26, 2009 6:47 pm
simon le bon wrote:PS to Gaieus: no use here of any ruby :|
simon
:thumb: ;)
Postby zzzSPUDzzz » Fri Mar 27, 2009 11:41 am
simon
:thumb: ;)
I'm not saying the use of a ruby is always the best way to go, but isn't the idea of a tutorial forum all about teaching people different ways to do things, then at least they have a choice..........
zzzSPUDzzz
Postby simon le bon » Fri Mar 27, 2009 12:24 pm
Dear zzzSPUDzzz
zzzSPUDzzz wrote:I'm not saying the use of a ruby is always the best way to go, but isn't the idea of a tutorial forum all about teaching people different ways to do things, then at least they have a choice..........
Gaieus wrote:It's not always about being able to do it easier with rubies. You should actually learn to do these things by hand, with native SU tools so that you model safely and with self confidence. Then can the rubies come to speed up your workflow...
I agree with Gaieus in the idea learning SketchUp the most completely using it's native tools is a necessary step, beside take advantage of using our mugnificient ruby scripts. I can add it is often a spiritual pleasure to find out the way of an elegant solution for complex duty with simple native tools.
Then you are right about ruby. But you know well we can find in this place many threads which take intensive advantage of them. But you are also right in the way for specific tuts on each complex ruby are missing. (It is something I'm thinking about for a while...)
:-)simonlebon
simon le bon
Postby Gaieus » Sat Mar 28, 2009 2:39 pm
Yes, that's what I also meant. Most of the (modelling) ruby plugins "only" automate ways SU can do and you could also do by hand - although admittedly very slowly and painstakingly. There's nothing wrong in using plugins of course, I was just going to say that in order to fully "master" SU, you have to be able to do most things by hand also and this way understand how things (and even plugins) work.
Then of course there is definitely a kind of "shortage" in good tutorial examples about using ruby scripts and good demonstrations about how different plugins help you with speeding up modelling would really be cool.
Return to SketchUp Tutorials
cron
