Layers - tags - THE METHOD to avoid tag or layer errors
Display the subtitles to watch the tutorialI explain how to best use the tags (layers) while avoiding errors. No more entities that are not in the correct tag (layer).
I do not explain everything here. If you want to know everything about tags: create them, change tag entities (drawing, groups ...), tag colors ... see the additional options from version 2020 then I invite you to view the tutorial below.
WARNING: when you break up a group, the entities of this group will remain in the group tag and not in Without Tag (or Layer 0) as we are asked to do !!!
I added the chapters in the tutorial, this allows you to directly access the parts you want to see or review.
