Printing a 1 : 1 template from Sketchup
Share or learn with the Pros
Postby Endgrain » Mon Oct 05, 2020 3:49 pm
Hi everyone,
I am a woodworker and I am trying to print a real size template directly from Sketchup.
I did my research and followed a couple of tutorials, but it did not work.
The piece is 25 x 14 inches.
I am on a Mac, camera is set to parallel projections and top view.
In document setup, I uncheck the "fit to page" box in the print menu and then set both the "In drawing" and "In model" to 1 ", before clicking OK. Unfortunately, those settings do not stay that way. If I reopen the Document Setup, I see that the scale has switched back to the original one.
I can not find the solution to this problem. Can anyone help ?
Thanks !
Endgrain
Re: Printing a 1 : 1 template from Sketchup
Postby nlipovac » Tue Oct 06, 2020 8:05 am
Endgrain wrote:Hi everyone,
Thanks !
I see you use SU2020 so use Layout to produce 1:1 drawing and print it.
nlipovac
Premium Member
Premium Member
Postby Dave R » Sun Oct 11, 2020 4:51 pm
As nlipovac says, your profile indicates you are using 2020 so it would be easiest to do this in LayOut. Your profile also says you are using Free/Make which does not exist for SketchUp 2020. Please correct your profile. That will make it easier to give you accurate instruction.
Global Moderator
Return to SketchUp Tutorials
