Curviloft (Beta) Plugin Tutorial
Share or learn with the Pros
Re: Curviloft (Beta) Plugin Tutorial
Postby charly2008 » Sun Jun 26, 2011 1:12 pm
Hi Curviloft Fans,
some CurviArt variations from a basic form.
Charly
User avatar
charly2008
Postby jose-91 » Wed Nov 23, 2011 7:40 am
very impressive. thanks for posting these examples!
jose-91
Postby brookefox » Thu May 03, 2012 8:03 pm
Thanks, Charly. I hope to tame the powerful beast with the insights you have shared, or at least not be consumed by it.
~ Brooke
User avatar
brookefox
Postby brookefox » Wed May 16, 2012 11:15 pm
When I've got the transitions previewed (in black), I find I am unable to orbit to really inspect the thing (like you do, Rich, in your demo tuts). If I try the operation is cancelled. Is there a secret?
~ Brooke
User avatar
brookefox
Postby lapx » Thu May 17, 2012 6:56 pm
Charly,
I have an irregular column shape I'm trying to make using curviloft. Stitching the circle and the shapes together should have worked but it did not. Do the segments on each shape have to be equal in number?
also the top of the planter is not flat it should be from with a curve in the z plane. Not certain how I would construct this.
How can this be done? See attached skp file.
lapx
Postby TIG » Thu May 17, 2012 10:30 pm
Lapx
Is this the result you seek?
Select the three 'profiles' of edges and run CurviLoft.
The initial result might be somewhat twisted, because the top circle's 'start' is rotated relative the the 'starts' of the other curves... but you can easily relocate that point around the curve in the tool.... before committing to the form...
User avatar
Global Moderator
Postby brookefox » Thu May 17, 2012 11:36 pm
The start point may not matter depending on the Vx setting.
Note the black previews which if I orbit during, causes the whole operation to be discarded.
The first pics show 1,2,3 from the bottom up.
Here from the top down.
~ Brooke
User avatar
brookefox
Postby micione » Sun May 27, 2012 7:37 pm
Hi all,
Watching this tutorial, I found the window (red arrow) in the photo.
Does anybody know tell me the path to find it?
Thanks in advance
User avatar
micione
Postby micione » Sun May 27, 2012 7:38 pm
Sorry,
photo.
User avatar
micione
Postby charly2008 » Sun May 27, 2012 7:46 pm
Hi Roberto,
you will find it in the Tools menu.
Charly
User avatar
charly2008
Postby micione » Sun May 27, 2012 8:04 pm
Charly,
Thank you very much.
(I tried to send a private message, but evidently you have not received).
User avatar
micione
Postby ccs1987 » Fri Jul 20, 2012 12:17 pm
Awesome tutorials
Sketchup 8 pro
Vray
Intel Xeon W3520 2.67Ghz
12Gb Ram
Nvdia Quadro FX 1800
ccs1987
Postby Lana » Mon Sep 23, 2013 8:30 am
Very good . I learned a lot here . Thank you all .
User avatar
Lana
Postby sketchartist023 » Tue Jan 02, 2018 9:33 pm
I have not been able to manipulate the GUI interface with this tool, so I am left with overlapping issues in my model :/ I am not sure what to do, but wow this tool is amazing so far! My concept is taking a plane lettering and then using a half circle guide flow to reform it to a rectangle below the lettering facing the same direction. SO, just a morphed half loop from letter to poly. But always get overlapping and face issues since I cannot use the points on the GUI. I wish I could do this stuff above! Will keep trying :)
User avatar
sketchartist023
Postby Dave R » Wed Jan 03, 2018 11:12 am
If you'd like help, upload an example SKP file so we can see what you are trying to do.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to SketchUp Tutorials
Who is online
Users browsing this forum: No registered users and 2 guests
Visit our sponsors:
