(TRICK) To re-enable skp file preview
Share or learn with the Pros
Re: (TRICK) To re-enable skp file preview
Postby driven » Mon Nov 19, 2012 1:11 pm
slbaumgartner wrote: It creates an observer that causes SketchUp to save a jpeg image of the current view each time you save a file.
You'll probably get some grief about using the ~/User/Library/ path, but I use both without issue, you just need to be careful that all supporting files/folders are in the same Folder for other plugins.
however, I had to run from console the first time, for some reason, now it just works it.
Second, I wrote a little QuickLook generator, also attached,
Steve
nice works well, but I'm also on ML...
I'll have a play and see if there are any issues, other than moving the .skp without the .pv.jpg, maybe a support folder with the plugin?
cheers
john
driven
PluginStore Author
PluginStore Author
Postby slbaumgartner » Mon Nov 19, 2012 1:58 pm
Steve
cheers
john
Hello,
I have a habit of putting things into ~/Library born of times when I shared a system with others and I didn't want my tweakings to mess up theirs. Other than that, there is no reason you can't put these files into the /Library folders instead.
You may have needed the console action to get the system to notice the generator. Other than qlmanage -r, I don't know what events cause it to check for new QuickLook generators.
If you move the skp without the .pv.jpg you will lose the thumbnail and get a Trimble logo instead (nothing I did, it just happens) until you copy the image too or save the file again. Not sure I understand what you mean about the support folder - create some separate, fixed place where all the thumbnail images go instead of the same folder as the skp?
Steve
slbaumgartner
PluginStore Author
PluginStore Author
Postby driven » Mon Nov 19, 2012 2:54 pm
slbaumgartner wrote: Not sure I understand what you mean about the support folder - create some separate, fixed place where all the thumbnail images go instead of the same folder as the skp?
Steve
yes, could even be a dot files so it's hidden, point the QL generator at that... now I think of it some of my other QL have support folders with them, so you could install both at same time and place. completely separate from the ruby and the .skp
john
driven
PluginStore Author
PluginStore Author
Postby slbaumgartner » Mon Nov 19, 2012 3:31 pm
Steve
john
I get it now. I'll look into this. It will require revision of both the ruby and the QL plugin so that they look at the same folder, which will have to be in a well-known location so that it doesn't depend on how someone installed the generator (esp ~/Library vs /Library). Maybe a hidden folder in your home directory?
Steve
slbaumgartner
PluginStore Author
PluginStore Author
Postby driven » Mon Nov 19, 2012 4:35 pm
~/.QL_SU/*.pv.png would be my first choice, that's probably best, no permision issues if I want to add titles etc... to the image or even add the image as the file icon with applescript.
john
driven
PluginStore Author
PluginStore Author
Postby slbaumgartner » Mon Nov 19, 2012 5:14 pm
driven wrote:~/.QL_SU/*.pv.png would be my first choice, that's probably best, no permision issues if I want to add titles etc... to the image or even add the image as the file icon with applescript.
john
Of course, there is a tradeoff: if the thumbnails are placed there, you can forget to delete one when you delete the associated skp file, causing abandoned thumbnails to accumulate in a hidden place that Finder doesn't normally show you.
I'm trying this out. The Ruby part was easy, but I confess that the Objective-C part is forcing me to learn more about the Cocoa framework suite than I expected. It may take me a while ;)
Steve
slbaumgartner
PluginStore Author
PluginStore Author
Postby slbaumgartner » Mon Nov 19, 2012 7:54 pm
john
OK, try the attached instead of the previous versions. :enlight: I used ~/.QL_SketchUp just to be more explicit. Using these, your skp files can be scattered anywhere and the QuickLook should still work. Just remember. per my previous post, to delete the thumbnail if you delete the skp!
Steve
slbaumgartner
PluginStore Author
PluginStore Author
Postby Efrado » Tue Jan 22, 2013 7:16 am
Aerilius wrote:Great!
Now we have work-arounds for everyone (and it's up to Trimble to raise their product).
You can get nice transparent previews (as in this video) if you temporarily disable ground and sky
and set the option :transparent => true.
AERILIUS,how and where do i have to place the "UnityPreviews"to get the results showed in the video? :?
I am on macbook pro.
Thanks.
Efrado
Postby filipeefilipe » Fri Aug 23, 2013 2:02 am
Guys,
I have the same problem. I haven't the preview of sketchup files. Do you find the definitive solution? My computer: Win 7 - 64bits - SU8. I don´t want install mysticthumbs. Plese help me. Thank you.
filipeefilipe
Postby kalu » Fri Sep 20, 2013 10:35 pm
I have Sketchup Pro Mac osx and I have not preview of the files, all the files look the same and drive me crazy, can someone explain If exist any walk around? Thanks.
THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
kalu
Postby whiterabbit » Mon Jan 27, 2014 7:31 pm
If anyone is using adobe software (I suspect many of you are) it is possible to see previews of .skp files in Adobe BRIDGE.
whiterabbit
Premium Member
Premium Member
Postby Bob James » Tue Mar 11, 2014 2:07 am
whiterabbit wrote:If anyone is using adobe software (I suspect many of you are) it is possible to see previews of .skp files in Adobe BRIDGE.
CS6 Bridge. And you can just drag and drop from Bridge into SU 2013 or 2014.
Bob James
Premium Member
Premium Member
Postby charly2008 » Tue Mar 11, 2014 1:31 pm
On my Mac, only icons in the Bridge are displayed. I am a beginner with the Mac. Do I need to adjust anything?
charly2008
Postby MarkoAntonije » Wed Jun 04, 2014 10:34 pm
Havent read through all the posts, but one solution to see previews is to run Sketchup, go to : File -> Import. Change "type of file" to .skp and preview all your files by selecting your file in that window.
MarkoAntonije
Postby baz » Thu Jun 05, 2014 12:26 am
Now here is a curious thing... in my mail client- Thunderbird- if I browse to attach an image to an email, voila! all my skps are displayed as thumbs!
How does that work?
BTW Marko, thanks for the inadvertant tip, I hadn't realized that one could import a model that way. I usually open a new instance of SU and copy/paste from there.
I am both an early bird and a night owl, I am some form of permanently energized dragon.
baz
Postby Aerilius » Thu Jun 05, 2014 9:58 am
Sorry to reveal it, but actually there is no magic about the thumbnails. One does not "need" SketchUp or other special software to generate thumbnails, but every file saved by SketchUp already includes a ready-made thumbnail.
The only obstacle for displaying the thumbnail is that you have to know at which position in the binary skp the thumbnail starts. Windows Explorer and many other programs don't know the position, and doesn't search for the thumbnail.
Software that shows thumbnails either has a compiled list for how to get the thumbnail for specific filetypes (Mystic Thumbs) or maybe seeks through the file to detect if there is somewhere an image that it could display.
For Explorer32bit SketchUp ships already an extension that tells Explorer at what position an skp file contains a thumbnail. I have no idea what holds SketchUp back from doing this for Explorer64bit, I doubt it requires porting the full SketchUp and its 3d engine to 64bit.
Aerilius
PluginStore Author
PluginStore Author
Postby thevzitor » Sat Aug 16, 2014 1:55 pm
CaniViz have just released a new version of their CaniVIZ 3D_Preview which allows mac users to see previews direct in the Finder ! The software is not cheap but... when you have thousands of files it can be worth it.
Otherwise I discovered that Clawmenu can also read the previews on skup files on Mac. It is free on the Mac Appstore.
Best to all
thevzitor
Premium Member
Premium Member
Postby sketch3d.de » Wed Aug 27, 2014 12:59 pm
thomthom wrote:
BorgMan wrote:I have tried the Seperate command with Windows 7, but alas, it doesn't work. Has anyone come up with a solution for this rather annoying problem already?
Nope. They changed something between the Beta and the RC so explorer.exe always spawn the 64bit version.
Code: Select all
%Systemroot%\SysWOW64\explorer.exe /separate /e, {20D04FE0-3AEA-1069-A2D8-08002B30309D}
should do the trick under W7 x64.
Norbert
sketch3d.de
Postby Aroundthebend » Sat Oct 04, 2014 12:22 pm
charly2008 wrote:Hi,
Charly,
to create a file thumbnail in SU you have to 'Save As' and tick the 'Custom Icon' and then save; over writing your original file. This icon is a snap shot of the view you have on screen at the time of 'saving as', so choose your view first! To update the icon you need to 'save as' again! This works on SU 8 on Mac OS 10 and Windows XP & 7.
Aroundthebend
Postby Aroundthebend » Sat Oct 04, 2014 2:30 pm
john
Steve
Thanks Steve...it works for me. :D
I put the .rb in 'Macintoch HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins' and the .qlgenerator file in 'Macintoch HD/Library/QuickLook' folder.
The 'Cover Flow' and 'Icon View' images now look great. Nice and clear. The icon view images have a 'turned down page corner' which distinguishes from other file types. The 'Quick Look' image matches the 'Icon View' image but small in size with its File Name, Size (MB) and Last modified date.
I found I had to re-save my Sketchup files i.e.: 'Save As' and remove the tick for 'Custom Icon' so the new preview image would be shown. If I didn't it would shows the original (duff) SU icon in all views except 'Quick Look'
thanks
Andy
Aroundthebend
Postby Aroundthebend » Sun Oct 05, 2014 1:10 am
I’ve attached a animated gif showing 4 screen shots to demonstrate slbaumgartner’s MAC thumbnail_saver.rb + QL generator file installed. Both posted on 19-11-12.
All images show Finder viewed in Cover Flow mode with Quick Look opened (B.Right ).
The top 2 files were saved in Sketchup with no .rb installed; the top one with no 'Custom Icon' ticked when ‘Saved As’. The 2nd file had 'Custom Icon' ticked.
3rd file was saved with the .rb + QL generator installed (with 'Custom Icon' ticked when Saved As).
4th file was saved with the .rb + QL generator installed (but withOUT 'Custom Icon' ticked when Saved As).
Aroundthebend
Postby Aroundthebend » Sun Oct 05, 2014 1:19 am
Here is one other screen shot with Finder viewed in Icon mode. The 4th file looks great in this mode. Thanks again slbaumgartner for his Ruby script and QL file for the Mac OS :thumb: .
P.S. I've just spotted my typo in the file names :!:
Aroundthebend
Postby slbaumgartner » Mon Oct 06, 2014 12:31 am
Aroundthebend wrote:Here is one other screen shot with Finder viewed in Icon mode. The 4th file looks great in this mode. Thanks again slbaumgartner for his Ruby script and QL file for the Mac OS :thumb: .
You are welcome! I notice that the checkbox to save a custom icon disappeared some time after SU version 8. But my stuff still works through SU 2014.
Steve
slbaumgartner
PluginStore Author
PluginStore Author
Postby hh_berlin » Mon Oct 13, 2014 4:36 pm
Just installed it - you did a great job... thank you so much.
can't believe, that sketchup does not handle that...
scrolling and zooming is disgusting since sketchup 8 on apple...
hh_berlin
Postby moghamdi » Tue Nov 04, 2014 6:07 pm
I have installed it, but it is not working.
I have Sketchup 2014/ OS 10.9.5.
I attached pictures to show you the location that I put the them in.
moghamdi
Postby driven » Tue Nov 04, 2014 6:18 pm
you probably need to reset qlmanage and Finder...
Code: Select all
qlmanage -r && killall Finder
copy paste into Terminal.app
driven
PluginStore Author
PluginStore Author
Postby moghamdi » Tue Nov 04, 2014 7:33 pm
it is working now.
Thank you guys for your support.
moghamdi
Postby Krisidious » Tue Nov 04, 2014 7:56 pm
2015 Sketchup re-enables thumbnails.
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby driven » Tue Nov 04, 2014 8:05 pm
Krisidious wrote:2015 Sketchup re-enables thumbnails.
not on a mac, it doesn't...
driven
PluginStore Author
PluginStore Author
Postby Krisidious » Tue Nov 04, 2014 8:26 pm
Sorry, time to get a PC I guess...
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
PreviousNext
Return to SketchUp Tutorials
