Normals map generator
Postby L i am » Sat Sep 10, 2022 12:31 pm
I have never created my own normals maps and the thought or creating then intimidated me. This generator looks like it is worth a look https://cpetry.github.io/NormalMap-Online/
Premium Member
Premium Member
Re: Normals map generator
Postby tuna1957 » Sat Sep 10, 2022 4:56 pm
L i am , F.Y.I. you can also create normal maps in Gimp. Watched a few tutorials and it seems to do a good job for me. :thumb:
tuna1957
Premium Member
Premium Member
Postby Rich O Brien » Sat Sep 10, 2022 5:12 pm
Just be aware of the normal format these export to. OpenGL and DirectX normals Green channel are opposite. So if you see stuff raised at render time that should be indented its usually the normal map.
Rich O Brien
Administrator
Postby L i am » Sat Sep 10, 2022 5:23 pm
I feel sick now :?
Premium Member
Premium Member
Postby tuna1957 » Sat Sep 10, 2022 7:40 pm
Rich O Brien wrote:Just be aware of the normal format these export to. OpenGL and DirectX normals Green channel are opposite. So if you see stuff raised at render time that should be indented its usually the normal map.
Rich is correct about this. The Gimp tutorials I watched showed how to correct the map if it looks “inside out” as Rich mentions. I’ve had good results with using these Gimp created maps in Twilight Render…
tuna1957
Premium Member
Premium Member
Postby Rich O Brien » Sat Sep 10, 2022 8:18 pm
L i am wrote:I feel sick now :?
It reads harder than it is to fix. Majority of archviz engines use openGL format. Just something to be aware of.
Rich O Brien
Administrator
Return to Corner Bar
cron
