DesignSparkMechanical Vx
A last find some times for test it!
Works very fine! DesignSpark has a new version 2 !
Very similar than SpaceClaim !Can export in OBJ, STL, and...SKP
For Nurbs in Moi3D Thx to Max Smirnov!
Sketchup on Steroรฏds!
Any other trick for simulate the Sketchup PushPull after a fillet ?
here a duplicate face!
Funny thing Design Spark can import SKP file from V3 to 2014! -
I have found!
But not sure that will work more speedy than my first "duplicate"!You must select strictly 3 edges!!! (1, 2, 4 don't work)
(of course in SU it's trivial -
Seems very good. What you imagine can be done with it? I will test it eventually... but
It's "direct modeling" (more than Sketchup) for mechanical modeling
but accept SKetchup file Export Import! 2014
(whithout textures ! Allows set colors for the different colors / textures from SU )
And perfect for something like complex Shells (molding) or Fillets for example!As free it's a true gem!
By Odrik
here the top (gutter) was modified and re-export to SKetchup
Gutter created by Shell
Post adaptation
PS;) thx Burr
Select Edge then Face + Ctrl -
Happy Easter!
DesignSpark permits to make PDF 3D !!!
And allows with a little trick to input Nurbs like STEP format from any progs like Moi for example!
A little trick for the "Only read file STEP imported"!
Import the STEP file
Add a solid to the drawing (cube, cylinder, sphere, whatever).
Right click on the top-most name of the component tree (the name of the whole thing).
Unlock. Everything in the tree is now unlocked.
Have fun modeling!If you want the PDF 3D File, it's here!
some tricks more on my site
For reduce or increase a surfaceFor make a rotation an object must be previous point axe existing :gride is not sufficient!
Measures frame can be hide by click on it for have properties!
Very exotic method for see the volume of an object!
You must have 2 volums minimum
And for see the last of a serial you must copy it!!! -
A trick for have objects from DesignSpark Mechanical in nurbs format inside any Nurbs program!
Use Fusion 360 : it has format SAB !
As the format Rsdoc from DesignSpark Mechanical can give directly SAB format!
(rename myobject.rsdoc in myobject.zip, unzip it you have the file .SAB inside the folder SpaceClaim/geometry !Fusion 360 who is Free for students, enthusiasts, hobbyists, and startups
Full use of Fusion 360 Ultimate for as long as you need it!
I use Design Spark PCB mostly for Electronic design. Played with this a little. Seems very good for mechanical type stuff...enclosures, metal work....
Always alive! Always free
hhttps://www.youtube.com/watch?v=9wDUiWpmfLs
Tested 5.0 works fine : import export SKP (geometry)
For Nurbs : Import Step export SAT (with tricky tinker above but working fine)And can generate a PDF 3D!
