Autosave location
General discussion related to SketchUp
Autosave location
Postby L i am » Mon Sep 27, 2021 10:14 am
Hi all, I have been working on a model which I thought I saved. Long story short, I can not now find the file. I looked in my preferences and auto save was set to save every 5 mins and checked. Where is it autosaved to? (Windows 10)
Premium Member
Premium Member
Re: Autosave location
Postby TIG » Mon Sep 27, 2021 10:50 am
If you have exited SketchUp cleanly any AutoSaved files are to-deleted.
They only exist if SketchUp has crashed.
They are made unless the model has been saved at least once...
AutoSave doesn't replace saving the model regularly, with an SKB backup version set one save behind...
With newer SketchUp versions any AutoSaved files are found in a special subfolder...
C:\Users\YOURUSERNAME\AppData\Local\SketchUp\SketchUp 2021\SketchUp\working\SKETCHUP\RecoveredFiles
It's a hidden folder, so either set folder-options to show such files/folders or use the whole path pasted into a Windows Explorer window to go there directly...
Global Moderator
Postby L i am » Mon Sep 27, 2021 12:07 pm
Thanks Tig, I have attached an image of how far I got following that file path. I have only had windows 10 for a week or so, and we are not getting along. Any ideas?
Premium Member
Premium Member
Postby TIG » Mon Sep 27, 2021 1:31 pm
You don't see AppData because it's 'hidden' - to stop you messing with it !
However, you can change your 'folder-options' to see it...
In the screenshot you showed there should be an option to 'View' in the unseen top part of the dialog ?
To the right-hand side of that top-bar there's a check-box entitled 'Hidden items' - tick that and AppData should appear in your User's list of available folders...
Global Moderator
Postby L i am » Tue Sep 28, 2021 10:33 am
TIG wrote:You don't see AppData because it's 'hidden' - to stop you messing with it !
Thanks, I found a copy of the recovered file in documents so that was handy. Is there a way to change file location of the autsave files?
I had a look in sketchup preference/general/saving and there does not seem to have the facility to change it.
Premium Member
Premium Member
Postby TIG » Tue Sep 28, 2021 4:12 pm
The AutoSave location is hard-coded...
Just save a link to it somewhere ?
Global Moderator
Postby L i am » Sat Oct 02, 2021 7:24 am
Thanks for the help :thumb:
Premium Member
Premium Member
Return to SketchUp Discussions
Users browsing this forum: iiliiilil, pablomanuel and 7 guests
