Can't open skp 2021 file directly
General discussion related to SketchUp Pro and Make
Postby studio43 » Sun Jan 24, 2021 6:04 pm
If i try to open a file created in SU 2021 pro I get an error message
"this file was created in a newer version...."
I have to open SU 2021 then open file thru it What is the fix for this
I have reinstalled 2021 as Admin still no good
studio43
Re: Can't open skp 2021 file directly
Postby TIG » Sun Jan 24, 2021 7:03 pm
When you say you 'installed as admin it's not 100% clear'...
Here's how it needs to be done/redone...
Log into Windows as your normal user-account.
Ensure that SketchUp, Layout etc are closed.
Find the SketchUp v2021 installer's exe file - usually in your Downloads folder ?
Select its icon, right-click > context-menu > "Run as administrator"
When prompted choose "Repair" [or, for a completely new installation, choose "Install"]
When it completes restart SketchUp...
Any improvement ?
Perhaps restart your PC to ensure everything syncs...
Your user-account having admin-powers is not enough.
Using 'Run' on a installer's exe file, or double-clicking it is also not the same thing...
-1
Global Moderator
Postby studio43 » Tue Feb 16, 2021 10:55 pm
I can open SU from the desktop shortcut. I create and save the file in the project folder but I can only open that file if I open SU from the desktop shortcut then choose the that file.
Yes I have tried reinstalling as admin. I am on subscription and have the most up to date version
This same thing happened with the 2020 version, I searched for a solution to the problem back then a luckily found a post someone had a file to download to correct this exact issue. Which they said was a bug with SU2020
studio43
Postby TIG » Tue Feb 16, 2021 11:25 pm
If you open v2021 from its shortcut or from its Program-Files exe, I assume you can open any selected SKP files from within its 'Open' menu item ?
If you select a SKP file in Windows Explorer and double-click it to open it, then I assume it's trying to use v2020 ??
If you select a SKP in Windows Explorer and right-click > context-menu do you see a list of possible SketchUp versions to open it ?
Is v2021 there on the list ?
And if so, if you select option that does the SKP open OK ??
PS:
Please update your profile version from 2013 !
Global Moderator
Postby studio43 » Wed Feb 17, 2021 7:06 pm
I can only open a file created in V2021 if I open the program first. If I right click on the v2021 file there is no option in the list to open with v2021. This is exactly the same problem I had with v2020.
The v2021 file I have created also has the older red SU icon no the new blue icon
studio43
Postby mogren » Thu Feb 18, 2021 1:30 pm
studio43 wrote:I can only open a file created in V2021 if I open the program first. If I right click on the v2021 file there is no option in the list to open with v2021. This is exactly the same problem I had with v2020.
Same to me and no 2021 it was also same problem on 2020
No 2021 in contextual menu
I might have moved my installer so I cannot repair
mogren
Postby mogren » Thu Feb 18, 2021 2:02 pm
I found a solution:
download SU 2021
open the exe
CLICK ON OPTION REPAIR
wait until the beast has finished install
now you can open normally your 2021 ;)
All my plugins&co are still there
mogren
Postby studio43 » Tue Feb 23, 2021 5:55 pm
Still no luck. I have tried running the repair as admin. No v2021 in right click contextual.
I tried deleting v2020 then running repair again. Still can not open a file creating in v2021
unless I open the v2021 first via the desktop icon/ shortcut and use "open file"
studio43
Postby Dave R » Tue Feb 23, 2021 6:38 pm
Have you tried associating .skp files with SketchUp 2021?
https://www.computerhope.com/issues/ch000572.htm
Global Moderator
Return to SketchUp Pro & Make Discussions
Users browsing this forum: No registered users and 8 guests
