Vray Animation of Scenes  Topic is solved
General discussion related to SketchUp Pro and Make
Postby blueman2 » Fri Jun 12, 2020 10:17 pm
I'm looking for an extension or plugin that will help me create an animated movie from scene transitions that can be saved as an mp4. I have vray and I have Fredo's Animator but it seems, from what I can tell, that it only works to animate objects within the scene rather than the scene transitions. Any help would be appreciated. I just want to animate the scene transitions I already have set up.
blueman2
Re: Vray Animation of Scenes
Postby fredo6 » Fri Jun 26, 2020 8:33 pm
blueman2 wrote:I have vray and I have Fredo's Animator but it seems, from what I can tell, that it only works to animate objects within the scene rather than the scene transitions.
With Animator, you can easily place scenes along the timeline and choose the transition between them, with options for easing if needed.
fredo6
PluginStore Author
PluginStore Author
Postby blueman2 » Fri Jun 26, 2020 9:46 pm
Thanks Fredo, I will try that a little later and see if I can figure it out. Is there any documentation anywhere that describes animating the scenes?
blueman2
Postby fredo6 » Sat Jun 27, 2020 8:11 pm
You can insert cameras taken from scenes
fredo6
PluginStore Author
PluginStore Author
Postby blueman2 » Sat Jun 27, 2020 11:23 pm
Thanks Fredo,
I was able to get the scenes in the time line and adjust the duration but unable to see the transition between the two scenes as a slow smooth camera movement as you can see when you are in sketchup and click from scene one to scene 2. I think I'm still missing something.
blueman2
Re: Vray Animation of Scenes  Topic is solved
Postby fredo6 » Sun Jun 28, 2020 11:20 am
blueman2 wrote:Thanks Fredo,
Just put the all durations to 0, so that you have a succession of small diamond in the timeline.
If you configure a positive duration, the camera will keep the scene view for the specified duration.
fredo6
PluginStore Author
PluginStore Author
Postby blueman2 » Tue Jun 30, 2020 8:25 pm
That took care of it. Thank you.
blueman2
Postby alaindesrosiers » Wed Jul 01, 2020 8:48 pm
Does anyone know why fredo animator doesn't work with V-Ray 4.2
alaindesrosiers
Postby fredo6 » Thu Jul 02, 2020 2:37 pm
alaindesrosiers wrote:Does anyone know why fredo animator doesn't work with V-Ray 4.2
It was a problem with VRay.
It's now fixed. Just install LibFredo6 v10.9a, just released.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Dave R » Thu Jul 02, 2020 6:14 pm
fredo6 wrote:It was a problem with VRay.
Does this mean you had to make an accommodation for the faulty Vray?
Global Moderator
Postby blueman2 » Thu Jul 02, 2020 7:55 pm
Fredo
I'm still having an issue and wondering if this comment about Vray has something to do with it. I am able to get the scenes loaded in Animator and they show the camera transitions perfectly. However, when I go to make a movie, the result of a vray rendered movie shows the wrong camera position or angle as you can see in these images that show it during the beginning of the scene transition and after the transition.
This is the position before transition
During the scene transition the camera jumps to what should be the proper transition here:
However, when I animate as "Natural", outside of Vray, it is correct
I installed LibFredo6 v10.9a to see if that was the problem but it did not correct it. The normal scene transition in Sketchup is fine. I can see now change in camera angle. I'm not sure where the problem is?
blueman2
Postby fredo6 » Fri Jul 03, 2020 9:04 am
Dave R wrote:Does this mean you had to make an accommodation for the faulty Vray?
Not faulty. VRay Next introduced a new way to track the movement of objects for optimization, whereas Animator handles the movement of objects in its own way (also for optimization).
The VRay Sketchup team gave me a workaround to resolve the issue.
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Fri Jul 03, 2020 9:07 am
@blueman2
Difficult to tell without seeing the model.
Could you post it or PM it to me so that I can have a look.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby blueman2 » Sat Jul 04, 2020 1:45 pm
fredo6 wrote:@blueman2
Fredo
Thanks Fredo! I will PM you
blueman2
Return to SketchUp Pro & Make Discussions
Users browsing this forum: Google Bot and 8 guests
