Ultimate Sketchup to 3ds Max bridge
General discussion related to SketchUp Pro and Make
Postby rv1974 » Sun May 17, 2020 7:32 pm
http://www.scriptspot.com/3ds-max/scripts/miauus-manage-links
If you take the best out of of both worlds (model in Sketchup and render in Max) then this fresh max plugin is absolutely must have tool. This plugin is simply dream came true:
*) Millions of faces get processed within seconds
*) Skp model, being inserted into Max get split by material (meshes named by its material);
*) Mirrored geometry get fixed (could be a huge headache with normals)
*) Original smoothing, UV mapping is preserved
*) Cherry on the cake: the model is linked, so no need to re-assign materials, re-apply modifiers and rebuild forests\multiscatters.
Highly recommended!
3
rv1974
Re: Ultimate Sketchup to 3ds Max bridge
Postby GD3Design » Mon May 18, 2020 7:15 pm
:o :o :o :o :o :o
Thanks for the headsup! This looks fantastic....going to check it out now. :)
GD3Design
Postby rv1974 » Tue May 19, 2020 8:47 am
Believe me it's a life saver. Gonna preserve you tons of mental health.
The price is super friendly plus no bloody subscription
-1
rv1974
Postby Mike Amos » Tue May 19, 2020 4:47 pm
Got it but not helping mental health. Seriously need simple steps to install and run this thing without the high speed videos's.
Premium Member
Premium Member
Postby rv1974 » Wed May 20, 2020 11:09 am
On youtube, click gear icon for video slow down.
I'd agree that I've seen more intuitive UIs :) , but let me explain a bit. Essentially, you need 2 simple things:
1. Run the script, hit 'select and attach' to initially select and insert linked skp file. Make sure 'Revit-combile by material' preset is on. Don't touch nothing 'till it's finished.
2. Now, If you made some changes in SU, and you'd like to reload the updated skp model then click 'convert and reload' and select the same skp* file. Make sure 2 reload options are ON (see attached picture). That's it. The updated model will be reloaded while all corona\vray materials will stay**.
*- It's preferable to save in older skp file format (say v8- v2013)
**- Don't change material names (inside SU)
rv1974
Postby Mike Amos » Thu May 21, 2020 9:36 am
The script will not run.
Premium Member
Premium Member
Postby rv1974 » Fri May 22, 2020 12:53 pm
"will not run".. what exactly do you mean by that?
The mpz file you've received is intended to install this plugin;
Run mpz, then go to Customize-> Customize User Interface,
find miauu's Manage Links in MiauuManageLinks category, put it in quad\toolbar. Start to use it.
rv1974
Postby Mike Amos » Sat May 23, 2020 9:05 am
Sounds good right up to the ..."and use it" bit. Not operating to the hype.
I got a bit further than last time but example attached.
Premium Member
Premium Member
Postby rv1974 » Sat May 23, 2020 3:52 pm
this is because your skp file is newer than your max can handle. save your skp as v8-13 (I mentioned it above). BTW it's max's error message, not script one.
rv1974
Postby Mike Amos » Mon May 25, 2020 8:48 am
You said "Preferable", not that it was essential. Is this your script? Have you self promoted?
Premium Member
Premium Member
Postby rv1974 » Mon May 25, 2020 5:42 pm
Mike Amos wrote:You said "Preferable", not that it was essential. Is this your script? Have you self promoted?
It's preferable because max 2020(21) came with a new skp importer which in some aspects was worse than the old one. However, I just can't predict all PEBCAK scenarios. How often do you use SU\Max combo? It's odd you are not familiar with this error (could be easily googled BTW).
The plugin is it's not mine of course- I'm too dumb for scripting. I'm just extremely appreciated to the author of the tool which solves astronomical quantities of problems.
rv1974
Return to SketchUp Pro & Make Discussions
Users browsing this forum: Google Bot, unlimuni and 14 guests
