For users of Sketchup versions PRIOR to SU2017
Due to a change of in the Trimble framework for releasing extensions, I am no longer able to create updates of my plugins for SketchUp versions prior to SU2017.
Therefore all my plugins are ONLY maintained for SU2017 and above.
For convenience, I have archived the latest versions of my plugins in the Sketchucation ExtensionStore. They are all prefixed with Prior_2017 keyword.
These legacy versions are
- compatible with SU versions up to SU2016 included
- not compatible with SU2017 and later version
I have also disabled the Check Plugins for Update functionality in these legacy versions.
Here are the link to legacy versions released so far in the ExtensionStore.
Fredo6 plugins - LEGACY versions prior SU2017
• Page 1 of 1
Fredo6 plugins - LEGACY versions prior SU2017Last edited by fredo6 on Sun Oct 25, 2020 9:38 pm, edited 1 time in total.
Re: Fredo6 plugins - LEGACY versions prior SU2017To Whom It May Concern:
The link for archived version of round corner is broken. Clicking on the title for https://sketchucation.com/plugin/2302-p ... oundcorner results in "Plugin not found" message. Thank you. Re: Fredo6 plugins - LEGACY versions prior SU2017
Thanks for signaling. I fixed it. Fredo
Re: Fredo6 plugins - LEGACY versions prior SU2017Hi! I have a problem, when I install LibFredo6, the Prior 2017 version, an error message appears that says: "Wrong installation: Folder Fredo6_!LibFredo6 is missing", and when I go to the path that appears on the message, the folder is there, for some reason SU2016 doesn't recognize it, any suggestions or recommendations? Thanks!
Hi danielfrv7, did you ever get a fix for this? I'm having the same problem on SU16 Pro. Re: Fredo6 plugins - LEGACY versions prior SU2017Hi,
I got the same issue on the 2016 version too. So after trying to figure it out, I ended by installing the last version of LibFredo6 (v11.6a). On restart sketchup complains about this bad version, I then reinstall the prior 2017 version of lib (v9.5k). On next restart, everything runs well (at least TopoShaper which I can now use). Not sure what happens exactely (maybe a missing file in v9.5k of bad folder naming during install), but hope this can help!
• Page 1 of 1
