Sketchup 2018 Pro not showing mapped network drives
General discussion related to SketchUp Pro and Make
Postby Dik Harrison » Thu Mar 26, 2020 10:11 pm
My copy of SketchUp 2018 Pro on my laptop no longer shows my mapped network drives in the window when I select to load a file. I can drill down to the needed shared folder, even though that folder is set up as a mapped drive. This used to work but has changed recently, not sure what update did it. Anybody have his issue or a solution?
Have fun...
Dik
Dik Harrison
PluginStore Author
PluginStore Author
Re: Sketchup 2018 Pro not showing mapped network drives
Postby slbaumgartner » Fri Apr 10, 2020 1:25 pm
There has been no change to SketchUp 2018, so the cause must be an OS or network update.
slbaumgartner
PluginStore Author
PluginStore Author
Postby JD Hill » Fri Apr 17, 2020 2:49 pm
Maybe worth mentioning that if you run a program as admin, it won't see drives you mapped as your user.
Developer - Bella Render
User avatar
JD Hill
Bella Render
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: No registered users and 10 guests
Visit our sponsors:
