Face and Shape of Specific Area
General discussion related to SketchUp Pro and Make
Postby Ben Ritter » Tue Mar 24, 2020 4:07 pm
Is there a way to create a face with a specific area? I'd like to draw circles or polygons with a specific area.
Thanks.
Ben Ritter
Re: Face and Shape of Specific Area
Postby TIG » Tue Mar 24, 2020 4:17 pm
https://sketchucation.com/pluginstore?p ... scale_face
Draw a the desired face shape [it can be any size], select that face and then activate the tool.
The face's initial area is reported in a dialog, type in the desired target area, then OK - the face is then rescaled to have the desired target area...
Global Moderator
Postby Ben Ritter » Tue Mar 24, 2020 4:41 pm
TIG, thanks so much.
Ben Ritter
Postby Ben Ritter » Tue Mar 24, 2020 4:49 pm
TIG, tried it and it doesn't scale properly. Working in sq. ft. units.
Thanks. Ben
Ben Ritter
Postby TIG » Tue Mar 24, 2020 4:50 pm
Bum !
I'll look at it asap...
Global Moderator
Postby TIG » Tue Mar 24, 2020 4:55 pm
I just checked it out... and in m² and ft² it works just fine for me ??
What units/precision do you have set for your Model Info > Units > Area ?
Can you attach a simple SKP that's causing you issues ?
Global Moderator
Postby Ben Ritter » Tue Mar 24, 2020 5:04 pm
Architectural Units, accuracy at 1/16".
Attached is the file. Original circle about 78sf. Larger Circle was supposed to be 100 sf.
Ben Ritter
Postby Ben Ritter » Tue Mar 24, 2020 5:05 pm
Perhaps it's the way the units are entered?
Ben Ritter
Postby TIG » Tue Mar 24, 2020 5:26 pm
When I try your SKP I get the wrong result too !
When I test it myself it was OK...
BUT now if I test it with a circle around the face it does scale oddly.
If I explode the circle first it works OK...
So something is adrift...
It's because the scaling transformation affects the face's vertices, and when it's a simple outline they get process individually, but when it's a circle they get processed repeatedly and so the scaling is then way off !
Leave it with me for a while why I invent another transformation method !!
:shock:
Global Moderator
Postby Ben Ritter » Tue Mar 24, 2020 5:35 pm
TIG,
OK, thanks.
I get the same result if I explode the curve or polygon. Simple non-curve lines around a face work fine.
Ben Ritter
Postby TIG » Tue Mar 24, 2020 7:31 pm
Here's v2.0
Download
I've fixed it to cope with all face perimeters - i.e. circles etc...
Download the RBZ and install...
Please test it and report back...
Global Moderator
Postby Ben Ritter » Tue Mar 24, 2020 9:26 pm
TIG, Great. No problems. Thanks so much for your work on the extension. :thumb: :thumb:
Ben Ritter
Return to SketchUp Pro & Make Discussions
Users browsing this forum: Bing [Bot], rafaelmichael and 4 guests
