Seeing the thumbnails  Topic is solved
General discussion related to SketchUp Pro and Make
Postby Joe Wood » Tue Mar 17, 2020 9:44 pm
What is that app / whatever, I need to see the SUp t nails? Just had win 10 installed on my system and lost whatever that was.
Joe Wood
Re: Seeing the thumbnails  Topic is solved
Postby Dave R » Tue Mar 17, 2020 9:57 pm
Doesn't changing the View to Large Icons show the thumbnails? It does for me.
Global Moderator
Postby Joe Wood » Tue Mar 17, 2020 10:22 pm
Right on Dave that works!
Joe Wood
Postby Joe Wood » Sat Mar 21, 2020 5:55 pm
Is there a setting to make all folders open up with large icons instead of needing to select View > large icons?
Joe Wood
Postby Dave R » Sat Mar 21, 2020 6:00 pm
Once you set them in the explorer window, they should open that way in the future. At least they do for me.
Global Moderator
Postby Joe Wood » Sat Mar 21, 2020 6:11 pm
Do you mean once you set one folder to large, the others will also be large? That's not the case for me, I keep needing to change the new folders I open.
Joe Wood
Postby Dave R » Sat Mar 21, 2020 6:19 pm
No. That's not what I mean. When I set a folder to display thumbnails it does that when I open it again.
Global Moderator
Postby Joe Wood » Sat Mar 21, 2020 6:50 pm
could you explain how to do it thru windows explorer Dave?
Joe Wood
Postby Dave R » Sat Mar 21, 2020 7:06 pm
I just open the folder and set it to show the thumbnails. When I open the Explorer window the next time, the thumbnails are displayed. If I want the details instead, I change it to show them. The next time I go to that folder it shows details. If that's not happening for you maybe you need a Windows expert to help.
Global Moderator
Postby Box » Sun Mar 22, 2020 1:07 am
Under File you have Change Folder and Search options. You can set the view there and apply it to all folder.
Postby Joe Wood » Sun Mar 22, 2020 1:58 am
Right on Box, thanks for that,
one less aggravation!
Joe Wood
Postby Joe Wood » Fri May 08, 2020 5:22 pm
That View> large icons fix didn't stick, so I asked on the MS support forum
The tutorial below can help show you how to set a default folder template for all folders, change the layout to large icons for how you want, and then apply to all folders.
https://www.tenforums.com/tutorials/351 ... -10-a.html
Joe Wood
Return to SketchUp Pro & Make Discussions
Users browsing this forum: PillePalle88 and 3 guests
