Creating Partial / Selective Cutaway-Section?
General discussion related to SketchUp Pro and Make
Postby davewong » Sat Dec 21, 2019 4:01 pm
Hi all,
Is there a way to create sections / cutaway views which isn't the conventional full box / linear section? I mean something like a section that is a mixture of different section planes? Something which has a different section depth, not the entire model having a section. To make things clear, an example like these:
davewong
Re: Creating Partial / Selective Cutaway-Section?
Postby Box » Sat Dec 21, 2019 4:06 pm
You can have multiple active section if you put them inside groups.
Postby davewong » Sat Dec 21, 2019 4:33 pm
Box wrote:You can have multiple active section if you put them inside groups.
Thank you, I have some concerns:
1) By groups as in, if I were to group my models in separate groups, I can then double click and go into the individual group and add individual unique section planes to only THAT group without interfering other models in the same file?
2) How do I create slanted section plane like you did?
Thank you so much and I hope u can help me with the above :)
davewong
Postby Box » Sat Dec 21, 2019 4:36 pm
1) Yes
2) Section planes are like any other object and can be moved or rotated with the relevant tools.
Postby Dave R » Sat Dec 21, 2019 4:42 pm
How do you plan to use the results with the section cuts? Just as images? If so, I would probably manage this mostly with separate scenes showing different section cuts and exporting those scenes to combine into one in an image editor.
Global Moderator
Postby davewong » Sat Dec 21, 2019 7:25 pm
Box wrote:1) Yes
Thank you so much. :D
davewong
Postby davewong » Sat Dec 21, 2019 7:28 pm
Dave R wrote:How do you plan to use the results with the section cuts? Just as images? If so, I would probably manage this mostly with separate scenes showing different section cuts and exporting those scenes to combine into one in an image editor.
That seems like a good idea! :D Thanks!
davewong
Return to SketchUp Pro & Make Discussions
Users browsing this forum: No registered users and 5 guests
