Follow me into different radius
General discussion related to SketchUp Pro and Make
Postby Leggy » Sat Dec 21, 2019 2:41 am
Hi I’m trying to make a cover on a 90 angle , but the 2 sides have different radius, how can i blend the 2 together , thinking of follow me some how
Maybe do the longer radius around the 90 angle and then scale down?
Leggy
Re: Follow me into different radius
Postby Leggy » Sat Dec 21, 2019 2:47 am
The longer side radius needs to be twice the size of the shorter one
Leggy
Postby Leggy » Sat Dec 21, 2019 3:07 am
Leggy
Postby Leggy » Sat Dec 21, 2019 3:08 am
Leggy
Postby Leggy » Sat Dec 21, 2019 3:16 am
Sorry, says the file is to large, changed it down and still wont go through
Thanks for your patience
Leggy
Postby Leggy » Sat Dec 21, 2019 3:33 am
Hope this helps
Leggy
Postby Box » Sat Dec 21, 2019 3:49 am
Since you seem to be having problems adding an Image, is it this sort of thing you are after?
Postby Leggy » Sat Dec 21, 2019 2:05 pm
Yes but a radius in the corner where they meet, so it blends through
Thanks for your time
Leggy
Postby Box » Sat Dec 21, 2019 2:52 pm
It can be done manually but it's much easier with Curviloft and Joint Push Pull.
One little note here, By using the center inference and magenta the small radius will be half the large one.
6
Postby Leggy » Sun Dec 22, 2019 7:42 am
Genius !!!!!!
Thanks so much, you make it look so easy
Leggy
Postby Box » Sun Dec 22, 2019 11:09 am
It's only genius if it is clear enough for you to follow, otherwise it is just speed modelling which isn't very helpful. ;)
There are various other ways to do something similar depending on the actual result you need. If needed you can still add an image as there may be a better option.
Postby Leggy » Tue Dec 24, 2019 7:37 pm
No that was perfect
I had curviloft on my old pc and forgot all about it
Thanks alot
Leggy
Postby Leggy » Fri Jan 03, 2020 4:11 pm
hi im getting this message
Leggy
Postby Leggy » Fri Jan 03, 2020 4:12 pm
here's the dwg
Leggy
Postby fredo6 » Fri Jan 03, 2020 9:41 pm
Leggy wrote:hi im getting this message
For Curviloft to operate correctly, you need to select only the external contours, not the inner corner edges. Watch the short video by Box again.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Leggy » Fri Jan 03, 2020 11:19 pm
Aha ok thanks for that ill try again on Monday
Leggy
Postby Box » Sat Jan 04, 2020 2:58 am
For a bit of clarity, in my gif you see me select all of it and show that it doesn't work as it highlights too many edges, then I hold down shift to deselect the corner faces. You could also activate the tool with nothing selected and just click on the edges you need.
Postby Leggy » Thu Jan 09, 2020 7:49 pm
hi I followed your example and got this, any ideas
thanks so much for your time
Leggy
Postby Dave R » Thu Jan 09, 2020 9:44 pm
Why don't you upload the SKP file so we can see what you started with?
Global Moderator
Postby Leggy » Fri Jan 10, 2020 3:53 pm
here you are
Leggy
Postby Dave R » Fri Jan 10, 2020 4:07 pm
Does the white one look more like what you want?
curviloft test.skp
Global Moderator
Postby Leggy » Fri Jan 10, 2020 6:04 pm
exactly, is it to do with the order you pick the lines?
Leggy
Postby Dave R » Fri Jan 10, 2020 6:09 pm
No. The bottom arc has 24 segments so I divided the straight lines on the sides and top so there is a total of 24 segments up each side (including the segments in the arcs at the top.
Global Moderator
Postby Leggy » Mon Jan 13, 2020 4:03 pm
how did you do that?
Leggy
Postby Dave R » Mon Jan 13, 2020 4:08 pm
Do what? Divide the edges? I right clicked on an edge, selected Divide and then entered the correct number.
Global Moderator
Return to SketchUp Pro & Make Discussions
Users browsing this forum: Google Bot, Google Feedfetcher, Maxjanes and 5 guests
