Copying Group Instances in Skp 2019
General discussion related to SketchUp Pro and Make
Postby sexypox69 » Mon Oct 07, 2019 4:57 pm
I notice when making copies of groups in sketchup 2019, each group is a unique instance. I remember in sketchup 2017 when copying a group each new group would be an instance of the original, so if you highlighted one, your entity info would tell you how many exist in the model. Now in sketchup 2019 when I highlight one it only registers as one in the entity info although there are several.
Can anyone share some light on this?
sexypox69
Re: Copying Group Instances in Skp 2019
Postby Dave R » Mon Oct 07, 2019 5:05 pm
How are you copying the groups? When I copy a group in SU2019, it tells me how many there.
Of course that number will change if you edit the group after copying it.
User avatar
Global Moderator
Postby sexypox69 » Mon Oct 07, 2019 7:35 pm
I'm using the native copying method...move tool + ctrl
sexypox69
Postby TIG » Mon Oct 07, 2019 7:51 pm
All copied groups should show as multiple instances of just the one definition, when one is selected in Entity Info - that is at least until you edit one of them, when it automatically becomes unique...
So if you don't see that I suspect an extension loaded that is adding an observer to the model's definitions, which makes any multi-instance groups unique - 'behind the scenes' ?
This is not ideal !
Can you try disabling some of your extensions, and then restart to see if this weird issue persists...
User avatar
Global Moderator
Postby Dave R » Mon Oct 07, 2019 7:58 pm
sexypox69 wrote:move tool + ctrl
That's how I copied the group in my screen shot.
TIG has some good advice.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: GD3Design and 4 guests
Visit our sponsors:
