How to display dimensions in render ?
General discussion related to SketchUp Pro and Make
Postby critz1184 » Sat Oct 05, 2019 12:40 am
Just wondering if there's any way for dimensions to appear in renders. I can't figure out how this is done. Note: not in layout mode, in an actual 3d render.
critz1184
Re: How to display dimensions in render ?
Postby Dave R » Sat Oct 05, 2019 11:11 pm
If I need to do this I make an image export from SketchUp showing only the dimensions from the exact same camera position as I use for the render (create a couple of scenes in SU to make this easier) and then overlay the dimension image on the rendered image. In the image editor set the Layer Blending mode to Multiple so the white background in the dimensions image disappears.
What version of SketchUp are you really using? There is no 2019 Make version like your profile indicates.
Global Moderator
Postby Dave R » Sat Oct 05, 2019 11:36 pm
Quick and dirty example made for this thread.
Rendered image:
Dimensions exported directly from SketchUp:
Both images combined into one.
Global Moderator
Postby critz1184 » Sun Oct 06, 2019 1:55 pm
Thanks, that's pretty much what I ended up doing. I was hoping there was an easier way. It would be nice if there was a simple checkbox in the dimension tab for this.
critz1184
Postby Dave R » Sun Oct 06, 2019 2:13 pm
Actually what you need is your rendering application to deal with rendering them.
Global Moderator
Return to SketchUp Pro & Make Discussions
Users browsing this forum: bfnm and 6 guests
