Hide Some Lines  Topic is solved
General discussion related to SketchUp Pro and Make
Hide Some Lines
Postby ntxdave » Thu Mar 14, 2019 1:57 am
Is there a way to keep only some lines in a component from showing?
I have a kind of funky situation where I need to keep certain lines in a component from showing. I edited the component and hid those lines. However, here is the problem. If I used the "show hidden geometry" for any reason and then re-hide that geometry, the hidden lines in my component reappear and I have to go in and re-hide those lines.
I need to do this because the component is grill work and when I display the model in LayOut all of those edges make the grating look to dark and I do not want them to show in my render either.
Here is the component
60x28 Grating.skp
The only lines I want to show are the external outline and a typical were this component is used will contain from 10 to 40 copies of the component. I want al of the interior lines to not be visible.
Any suggestions?
ntxdave
Re: Hide Some Lines
Postby tuna1957 » Thu Mar 14, 2019 2:21 am
ntxdave, If this is in context with your post on the Twilight forum I wonder if you could get the effect you need by just using a grating with no thickness.
tuna1957
Premium Member
Premium Member
Re: Hide Some Lines
Postby ntxdave » Thu Mar 14, 2019 2:25 am
Yeah, that might be fine for the render but I use the SU version in layout and it makes the grating show up darker than my sponsor want to see in the overhead view. Would share the PDF if I could but the file is too darn big. The render version is no problem (either way).
ntxdave
Re: Hide Some Lines
Postby Box » Thu Mar 14, 2019 2:39 am
I don't understand, if you hide selected edges, then turn on hidden geometry they show as dotted lines, when you turn off hidden geometry they remain hidden, they don't become hard edges again.
Re: Hide Some Lines
Postby ntxdave » Thu Mar 14, 2019 2:56 am
Thanks for that feedback Box. I will try again in the morning. I must have done something wrong. Maybe I forgot to save the version with the hidden lines to my component library.
ntxdave
Re: Hide Some Lines  Topic is solved
Postby Dave R » Thu Mar 14, 2019 2:59 am
ntxdave wrote:If I used the "show hidden geometry" for any reason and then re-hide that geometry, the hidden lines in my component reappear and I have to go in and re-hide those lines.
Are you using View>Hidden Geometry to show the hidden geometry? If so, that won't make the edges reappear such that you'd have to go through the process of hiding them again. You would just deselect Hidden Geometry in the view menu to make it not show.
ntxdave wrote:I need to do this because the component is grill work and when I display the model in LayOut all of those edges make the grating look to dark and I do not want them to show in my render either.
Depending on how this is grate is used, maybe it would be useful to stack viewports so you could just a thinner line weight for the grate than in the rest of the model.
As for the rendering, what renderer are you using? Most renderers don't display edges and it wouldn't matter if the edges are displayed or not.
ntxdave wrote:Here is the component
60x28 Grating.skp
Any suggestions?
If you still want to hide all the internal edges (and not faces) you can do that. The easiest way is to set the view to the standard Top view and face style to Wireframe. Drag a left to right selection window starting just inside one of the left corners of the frame and extending near to the diagonally opposite right corner. This will select only the edges surround the openings but none of the outer edges. Then choose Edit>Hide to hide them. After you go back tou your normal face-showing style, it should look something like this:
Global Moderator
Re: Hide Some Lines
Postby tuna1957 » Thu Mar 14, 2019 3:13 am
ntxdave , I think I wasn't quite clear about my meaning in my first post. Posting an image saved out of Layout ( pardon me if it's a little crude, the First time I've ever opened layout :shock: ) . For the distance the grating is being viewed from it may not be needed to show a fully modeled grate. The grate with no thickness "shows" a lot clearer.
tuna1957
Premium Member
Premium Member
Re: Hide Some Lines
Postby ntxdave » Thu Mar 14, 2019 3:27 am
Tuna, the problem shows up when you have 100 to 175 ft of grating.
Box & Dave, I think you guys are wright. I will try again in the mornin. As I told Box, I think I might have forgotten to save the version with the hidden lines in my component library. Dave, I did not think about using the wire frame for selecting and hiding the lines. Much faster and accurate. A pure DUH moment for me. I am getting pretty good at that lately. :oops:
ntxdave
Re: Hide Some Lines
Postby ntxdave » Thu Mar 14, 2019 9:08 pm
Just wanted to let you guys know that, yes I did verify that I can show & hide hidden geometry and it does NOT cause a problem. This is really adding something very useful to my equipment layouts and renders. :thumb: :thumb: :thumb: :thumb: :thumb:
And Dave, your method of hiding was far faster and more accurate that the stupid route I as going. What a stupid DUH moment for me. :oops: :oops:
Thanks guys, I am making some progress on getting some things set up for rendering my equipment models.
ntxdave
Re: Hide Some Lines
Postby ntxdave » Thu Mar 14, 2019 11:27 pm
Just to give you guys some feedback about how that piece of equipment is used, I have included both a rendered image of the equipment layout (used Twilight Render - took 2:00 render) and a PDF file that gives you some insight about how the render and model are shared with the customer/potential customer.
Sample 150ft Render.pdf
The PDF was created with LayOut
Again, thanks to all of you for the feedback. Hope the examples give you a better example of what I was trying to achieve. :)
ntxdave
Re: Hide Some Lines
Postby ntxdave » Fri Mar 15, 2019 6:07 pm
After working with the staff at Twilight, I made some more changes.....sharing the latest version below.
ntxdave
Re: Hide Some Lines
Postby Dave R » Fri Mar 15, 2019 6:10 pm
That looks pretty good. Your keepers should be impressed.
Global Moderator
Re: Hide Some Lines
Postby ntxdave » Fri Mar 15, 2019 6:24 pm
Thanks Dave...…..continual learning process.
ntxdave
Return to SketchUp Pro & Make Discussions
Users browsing this forum: Svetlana13 and 12 guests
