Triple click not working with outliner open
General discussion related to SketchUp Pro and Make
Postby Flion » Wed Nov 28, 2018 12:36 pm
I'm working in a file that's less than 1mb in size. It's a model with with 1200 components and 45 groups. At one point I noticed that triple click is not working - not selecting the whole connected geometry. Double click does work. It is worth mentioning that outliner and the contents blink on every mouse click. What's more interesting is that triple click works when I minimize (close) outliner.
I opened a new blank drawing and everything works fine. I assume there's something in the model causing this behavior. Any ideas?
SU Pro 2017
Flion
Re: Triple click not working with outliner open
Postby Flion » Wed Nov 28, 2018 6:21 pm
I just tried to save a model and got this message:
Results of Validity Check.
*** Problems were found that could not be fixed! ***
The entity at address 84c9fc00 has an invalid id (0) destroyed (0)
The model can be saved even without fixing the issue.
Flion
Postby Dave R » Thu Nov 29, 2018 1:56 am
How about sharing the SKP file so we can see what you've got?
Global Moderator
Postby Flion » Sun Dec 02, 2018 5:36 pm
Architecture detail.rar
Here's the file.
Flion
Postby Box » Sun Dec 02, 2018 5:48 pm
Hang on, you said it was less than one meg but you have to compress it to upload, and you have used rar. I guess you don't want help.
Postby slbaumgartner » Mon Dec 03, 2018 3:32 pm
When I opened your file on my Mac, SketchUp wanted to fix issues with a lot of invalid object ids. But regardless of whether I let it fix them or not, the only cases in which triple-click did not select all was when the component contents consisted only of nested components. In that case the third click would select the nested component at the location of the click. Is that what you were referring to? Having outliner open vs closed made no difference for me.
slbaumgartner
PluginStore Author
PluginStore Author
Postby Flion » Wed Dec 05, 2018 4:03 pm
@Box. It was less than 1MB in the middle of the work. Meanwhile I carry on the work and came to around 2MB.
I don't get this?
@slbaumgartner In the meanwhile I saved a model without fixing the issue. When I opened it again it doesn't report any problems but the triple click (and outliner blinking) problem is still present.
Flion
Postby juju » Wed Dec 05, 2018 6:05 pm
Flion wrote:@Box. It was less than 1MB in the middle of the work. Meanwhile I carry on the work and came to around 2MB.
I don't get this?
meaning the file is small enough to upload directly and that RAR isn't a very popular compression format
juju
Premium Member
Premium Member
Postby Flion » Thu Dec 06, 2018 1:06 pm
I'm sorry for my ignorance. What do you suggest? ZIP? 7zip?
Flion
Postby juju » Thu Dec 06, 2018 1:49 pm
Flion wrote:I'm sorry for my ignorance. What do you suggest? ZIP? 7zip?
1MB or 2MB should be small enough to upload directly (without having to compress it in RAR / ZIP / whatever)
juju
Premium Member
Premium Member
Postby sketch3d.de » Thu Dec 06, 2018 1:51 pm
Flion wrote:What do you suggest? ZIP? 7zip?
ZIP is the standard, a 10% better compression of ARJ or 7Z typically irrelevant... besides giant video files maybe.
sketch3d.de
Postby oceanembers » Thu Dec 06, 2018 3:52 pm
Can't replicate here, using 2018.
oceanembers
Return to SketchUp Pro & Make Discussions
Users browsing this forum: jaaple, Probeer18 and 12 guests
