joint push-pull help needed
General discussion related to SketchUp Pro and Make
Postby HornOxx » Fri Aug 10, 2018 7:30 am
Hi All - I need some joint push-pull instructions please
I often use this tool and in most cases everything runs perfectly - but every now and then I get a result like shown below, which is definitely due to my model quality itself - what do I miss?
(model is attached)
never trust a skinny cook
HornOxx
Re: joint push-pull help needed
Postby Dave R » Fri Aug 10, 2018 7:46 am
What happens if you erase those excess edges? Do the faces remain? Running ThomThom's CleanUp3 might take care of it.
These edges might be related to the edges that sometimes appear when Intersect Faces is run.
Global Moderator
Postby HornOxx » Fri Aug 10, 2018 7:55 am
... thanks Dave - yes, the faces remain after manual cleaning but there seem to be some randomly face reversions here and there. Good idea to run ThomThom's CleanUp!
HornOxx
Postby Dave R » Fri Aug 10, 2018 8:03 am
So at least the faces are remaining coplanar. I'm not sure why you would wind up with reversed faces. Maybe Fredo will be along. I can't test your file unfortunately . I'm sat here on a couch far away from my computer.
Global Moderator
Postby HornOxx » Fri Aug 10, 2018 8:33 am
:) thanks! and keep couching
HornOxx
Return to SketchUp Pro & Make Discussions
Users browsing this forum: chillinastya, Derek Edison and 14 guests
