Non-solid objects (Plugin: Solid inspector)
General discussion related to SketchUp Pro and Make
Postby ozgesuvari » Thu Jul 12, 2018 4:48 pm
Hi, i'm trying to use slicer 5 plugin which is this one; https://sketchucation.com/plugin/781-tig_slicer
And for using this plugin i need a solid object. In spite of i'm using "solid inspector" for checking if it is solid or not, it's still not solid.However, solid inspector says everything is ok, objects is still manifold.
How can i convert it to solid and find out which part of the model i was mistaken.
ozgesuvari
Re: Non-solid objects (Plugin: Solid inspector)
Postby pilou » Thu Jul 12, 2018 6:07 pm
Try also Solid Solver by TIG!
You can also export as OBJ Format Tig has also an Import Export OBJ format if you have not the SU Pro
Then run the free Mesh Mixer
Menu Analysis / Inspector / auto repair all :)
Speedy Galerie
Top SketchUcator
Postby Dave R » Thu Jul 12, 2018 9:00 pm
Is face orientation correct? Do you have exposed back faces?
Global Moderator
Postby Box » Fri Jul 13, 2018 3:11 am
We're all guessing, add the model and we can check it.
Return to SketchUp Pro & Make Discussions
Users browsing this forum: archlib1, GraphiPerso, shanashukoor and 10 guests
