LEICA DISTO S910 3D REAL TIME MEASUREMENTS WITH MAC/SKETCHUP
PLEASE HELP!
Currently you can take real time 3d measurements in AutoCad for a Windows computer and create 3d points, not just 2d, but 3d as well.
I can't find any app that will allow someone with a Disto S910 to do the same thing for Mac and or a plugin to do this in Sketchup.
I don't care if I have to make a real time 3d plan from my iphone, which I doubt is even possible or even from Mac and than have to export that entire file to Sketchup, that would be fine, but currently I can't find anything that will work with Mac or with Sketchup.
It's very important to be able to do this for Mac and or Sketchup because the only other alternative is to take 30 point files and sometimes your room that you map out in 3d is going to be a lot larger than 30 points. This is very frustrating that it's so hard to find something for this device. The DISTO S910 is a couple years old now and it's 2018. Apps still suck in some cases, we are really behind in some regards with apps and technology and we shouldn't be!
Hoping to hear some kind of workaround from someone. Thanks!!
Kubit/Faro PhotoToPlan?
https://www.faro.com/en-gb/products/construction-bim-cim/faro-photoplan/ -
Hi there,
Well it's been a while. Did you find a workaround in SketchUp to gather data from the Leica 910?
I tried this years ago but without succes.
