Explode groups  Topic is solved
General discussion related to SketchUp Pro and Make
Explode groups
Postby koliboti » Fri Nov 10, 2017 7:30 am
Hi SketchUPers ;)
I am looking for a plugin that can explode groups inside groups.
For example: I am want to expload all groups (A,B,C) inside groups X1,X2,X3,...
koliboti
Re: Explode groups
Postby Dave R » Fri Nov 10, 2017 2:50 pm
Did you try searching the Plugin Store? TIG's Group Exploder would probably do what you need.
Global Moderator
Re: Explode groups
Postby koliboti » Mon Nov 13, 2017 7:58 am
Thank you Dave R! But this plugin explodes all the groups... and I want to explode only groups A,B,C and keep X1, X2, ...
koliboti
Re: Explode groups
Postby TIG » Mon Nov 13, 2017 1:00 pm
To explode all groups found inside another group, but ignore those groups located in the model itself or inside components, you can use this one-liner copy+pasted in the Ruby Console + enter...
Code: Select all
m=Sketchup.active_model;m.start_operation('ex',true);m.definitions.find_all{|d|d.group?}.each{|g|next unless g.valid?;g.entities.grep(Sketchup::Group).each{|e|e.explode}};m.commit_operation
3
Global Moderator
Re: Explode groups
Postby koliboti » Mon Nov 13, 2017 8:06 pm
Woow TIG, it is working perfect! :) Thank You Very Much!
It is hard to explode Components also?
koliboti
Re: Explode groups  Topic is solved
Postby TIG » Mon Nov 13, 2017 9:05 pm
koliboti wrote:Woow TIG, it is working perfect! :) Thank You Very Much!
No.
If you want to ALSO explode components you could make this adjustment ??
Code: Select all
m=Sketchup.active_model;m.start_operation('ex',true);m.definitions.find_all{|d|d.group?}.each{|g|next unless g.valid?;(g.entities.grep(Sketchup::Group)+(g.entities.grep(Sketchup::ComponentInstance)).each{|e|e.explode}};m.commit_operation
Global Moderator
Re: Explode groups
Postby koliboti » Tue Nov 14, 2017 6:07 pm
Thank You Very Much TIG! :)
koliboti
Return to SketchUp Pro & Make Discussions
Users browsing this forum: No registered users and 4 guests
