Mass Material Importer
General discussion related to SketchUp Pro and Make
Postby dillow » Wed Jun 07, 2017 11:17 pm
My old computer (the one with all my materials libraries on them) took a dump. I now need to recreate the materials folders. I seem to be having trouble getting the old Mass Material Importer plug-in to work. It loads and asks for a file location, I enter that, and then nothing.
Is there a way to batch do this outside of the old plug-in? It is way too tedious doing this one at a time. I find it hard to believe there's nothing in the warehouse that accomplishes this. It's got to be one of the most basic plug-ins.
Thanks!
dillow
Re: Mass Material Importer
Postby Rich O Brien » Thu Jun 08, 2017 9:49 am
Do you need to add .skm files back to SketchUp as collections?
If you have your original .skm files then is is relatively quick to setup new collection in SketchUp.
PS...
What concerns me more is that your old PC took a dump. :shock:
Rich O Brien
Administrator
Postby dillow » Thu Jun 08, 2017 1:39 pm
I do not have the skm collections. I do have old Sketchup files with materials in them but I thought it'd be just easier to download the jpgs (mostly from manufacturer tileable images). But converting hundreds of jpgs to skms isn't fun.
dillow
Postby sdmitch » Thu Jun 08, 2017 3:30 pm
dillow wrote:I do not have the skm collections. I do have old Sketchup files with materials in them but I thought it'd be just easier to download the jpgs (mostly from manufacturer tileable images). But converting hundreds of jpgs to skis isn't fun.
Here is a version of the method I use to load materials into a model.
Code: Select all
module DILLOW
      def self.materials_from_file
         @mod = Sketchup.active_model
         @textures_from_file = []; @images = []; @image_path ||= File.dirname(__FILE__)+"/*.*"
         @image_path = UI.openpanel("Texture Files",@image_path)
         unless @image_path==nil
            image_folder = File.dirname(@image_path.gsub('\\','/'));
            @images = Dir[image_folder+"/*.{jpg,png,tif,bmp,gif,tga,epx}"]
            @images.each{|i| @textures_from_file<<File.basename(i,'.*')};
            if @textures_from_file[0]
               @textures_from_file.each_with_index{|name,i|
                  unless @mod.materials[name]
                     mat = @mod.materials.add(name)
                     mat.texture = @images[i]
DILLOW.materials_from_file
Copy and paste into Ruby Console and press Enter to execute. Select any image file and click Open.
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Postby ronaldoluidi » Wed Jun 06, 2018 6:05 am
sdmitch your code is awesome, thank you!
ronaldoluidi
Return to SketchUp Pro & Make Discussions
Users browsing this forum: No registered users and 10 guests
