sun/shadow study animation export -> time????
General discussion related to SketchUp
Postby bsfranza » Mon Aug 22, 2016 3:48 pm
hi there,
i really love the geolocation feature of sketchup and the possibility to make short animations with scenes that show the daylight cycles etc.. also one can export animations
now, is it possible to have some kind of clock or timer in the animation that shows the actual time???
if not inside sketchup how would you go to add that to the finished animation?
thanks for your help
bsfranza
Re: sun/shadow study animation eport -> time????
Postby Dave R » Mon Aug 22, 2016 3:50 pm
There was a plugin made some years ago that would display the time and date on screen. I used it in a shadow study animation I did for a client back then. I'll have to hunt for it because I don't remember where I got it or the name of it.
Global Moderator
Postby juju » Mon Aug 22, 2016 4:05 pm
Dave R wrote:There was a plugin made some years ago that would display the time and date on screen. I used it in a shadow study animation I did for a client back then. I'll have to hunt for it because I don't remember where I got it or the name of it.
If I recall correctly this is "time" available from Smustard.
juju
Premium Member
Premium Member
Postby bsfranza » Mon Aug 22, 2016 4:12 pm
thanks guys, unfortunately i cant find anything over at smustard but a animated clock but this does not help.. i dont need the actual time but the time of the animation... that is day and daytime of sun...
hope anyone else has a tipp availeable
bsfranza
Re: sun/shadow study animation export -> time????
Postby TIG » Mon Aug 22, 2016 4:36 pm
Time would do what you want.
Unfortunately it's no longer available.
I will PM you an alternative 'private' script...
3
Global Moderator
Postby bsfranza » Tue Aug 23, 2016 6:31 am
thanks tig - awesome script!!
awesome forum =)
bsfranza
Postby nohatman » Fri Apr 21, 2017 2:11 pm
TIG wrote:Time would do what you want.
Is this something that is available now as part of SketchUp? Or otherwise...
I have a need for the same to produce a shadow study. It would be great to have something accurate within SketchUp and actually linked to SU's shadow times - rather than adding a timer in After Effects which is what I have done, but this is a very cumbersome solution.
nohatman
Postby TIG » Mon Apr 24, 2017 12:20 pm
I'll PM you some alternative Ruby code...
Global Moderator
Postby bewilder » Thu May 10, 2018 3:49 am
I have been looking everywhere for an extension that would show the shadow time in an animation. I hate bugging TIG for a PM with private code. Is it available anywhere else?
bewilder
Postby juju » Thu May 10, 2018 3:41 pm
What do you mean by shadow time?
- The amount of sun / shadow an area would receive?
or
- The date & time on screen when viewing an area with sun/shadows enabled?
juju
Premium Member
Premium Member
Postby TIG » Fri May 11, 2018 2:54 pm
bewilder wrote:I have been looking everywhere for an extension that would show the shadow time in an animation. I hate bugging TIG for a PM with private code. Is it available anywhere else?
Look in your PMs...
Global Moderator
Postby bewilder » Sat May 12, 2018 12:07 am
That is perfect! Thank you for taking the time.
bewilder
Postby Triangle_head » Fri Aug 24, 2018 7:10 pm
TIG wrote:I'll PM you some alternative Ruby code...
Hello! Can You send a code for me too?
Triangle_head
Postby TIG » Mon Aug 27, 2018 8:31 pm
See yesterday's PM...
Global Moderator
Postby xeroball » Tue Aug 28, 2018 8:32 am
Hello, Can You send a code for me also?
xeroball
Postby luesak » Tue Aug 28, 2018 8:34 am
TIG, could you please share your time script? I am new here so I cannot send PMs!
Kim
luesak
Postby TIG » Tue Aug 28, 2018 12:04 pm
Will you all check your PMs for an attachment...
Global Moderator
Postby luesak » Wed Aug 29, 2018 1:44 am
Thank you TIG!
luesak
Postby TacSU » Tue Feb 05, 2019 5:47 pm
Tig,
Do you still have this alternate code, or in the last few years are you aware of a newer method?
TacSU
Postby TIG » Tue Feb 05, 2019 11:33 pm
Look at your PMs...
Global Moderator
Postby vandyck » Sun Feb 24, 2019 3:47 pm
Look in your PMs...
Hello TIG !
thank you in advance
vandyck
Postby virtexultra » Sun Apr 07, 2019 5:37 pm
Hello TIG
would you be so kind and would also send me the script?
Alexander
virtexultra
Postby mateua » Thu Feb 06, 2020 10:07 am
TIG !
Could You share a code with me too?
thank you
Mateusz
mateua
Postby frankthetank86 » Thu Apr 30, 2020 7:36 am
Hello TIG,
you are my last hope to get my problem done. I need to have a time stamp on my exported video that shows day and time of the current shadow. I tried some ruby code but that does not work on exported animated videos.
Thank you very much in advance!
Frankthetank86
frankthetank86
Postby jaythakkar » Fri May 15, 2020 9:37 pm
Hello TIG
Can you please share the code.
jaythakkar
Postby Miramonte » Wed Jun 10, 2020 2:54 pm
Hi TIG !
thank you
Miramonte
Postby wgamborski » Mon Jun 22, 2020 5:32 pm
TIG, looking for same script/solution please.
TIA
wgamborski
Postby MVrmn » Mon Jul 06, 2020 10:21 am
Hey TIG,
Have a nice shade animation but no time indication
Mike
MVrmn
Postby Okr » Thu Sep 17, 2020 9:51 am
Hi Tig,
Could you, please, send me the script.
I´m stuck with this issue.
Thank you in advance.
Okr
Postby IrisvV » Thu Sep 17, 2020 4:09 pm
Hello TIG,
Could you send me a PM with the code also?
Thank you in advance!
IrisvV
Next
Return to SketchUp Discussions
Users browsing this forum: Google Bot and 8 guests
