CNC milling machine
General discussion related to SketchUp Pro and Make
CNC milling machine
Postby deanlegg » Tue Jun 21, 2011 4:46 pm
Hi All
Does anyone know if SU can be exported into a CNC directly
I have a project to do for a friend, but have no idea what format of file these machines use
Cheers Dean
deanlegg
Re: CNC milling machine
Postby TIG » Tue Jun 21, 2011 6:03 pm
They usually take formats like DXF or DWG - check what the machine is and what it'll take... they can vary.
Global Moderator
Postby deanlegg » Tue Jun 21, 2011 6:08 pm
Thanks TIG
I thought it was possible, I'll check on the machine
deanlegg
Postby kyyu » Wed Jun 22, 2011 3:01 am
Usually cnc machines run a gcode file. So you need a CAM program to mark up and convert your model to the proper tool paths. If you are doing 2D/2.5D stuff, there is a sketchup plugin called "Phlatscript" (they just changed it to "SketchUCam")that can generate the gcode directly from sketchup. You can download it at phlatforum.com (need to register to get on the forum). I have a video on youtube showing how it is used: http://www.youtube.com/watch?v=Z9f-bC3hpHQ
kyyu
Postby TIG » Wed Jun 22, 2011 9:59 am
As has been said... a CNC machine uses special code ['gcode'] BUT there are converters in its software to allow certain file types like DXF to be converted to that special code... so you need to find out what types of file this specific CNC machine can take in and translate... Converting the SKP to 'gcode' direct is an option, but most machines include translators for some file-types [not SKP unfortunately]
Global Moderator
Return to SketchUp Pro & Make Discussions
Users browsing this forum: ihsanrahim, Malyuga and 7 guests
