I am sorry to say that some of my scripts were heavy contributors to the problem of menu gray-out which has been reported by many users (see thread http://forums.sketchucation.com/viewtopic.php?f=15&t=27941#p242263. I fixed the faulty code.
WHETHER YOU USE MY SCRIPTS OR NOT, I would strongly advised users to upgrade the following scripts to their latest versions, all dated 6 May 10.
LibFredo6 --> v3.4c (the most critical)
ToolsOnSurface --> 1.6a
RevertCurve --> version 6 May 10
DxfTransformation --> version 6 May 10
MarkVertices --> version 6 May 10
In principle, you don't need to upgrade the other scripts (FredoScale, RoundCorner, HoverSelect, GhostComp, JointPushPull, BezierSpline, etc...).
Again, receive my apologies for the inconvenience.
Fredo
PS: even if you don't use the scripts, you still need to upgrade because the faulty code is executed whenever you do a right click in the SU selection tool (This small code is the one that makes the contextual menu appear for FredoScale and other scripts).
IMPORTANT: critical upgrade to Fredo6 scripts (grayout menu)
• Page 1 of 1
IMPORTANT: critical upgrade to Fredo6 scripts (grayout menu)Last edited by fredo6 on Fri May 07, 2010 6:23 pm, edited 1 time in total.
Re: IMPORTANT: critical upgrade to Fredo6 scripts (grayout mBIG THANKS from the Google Team for getting a fix out so quick!!!
Re: IMPORTANT: critical upgrade to Fredo6 scripts (grayout mAwesome! Thanks so much Fredo! (now to rememeber to go through my scripts and see if any of mine are guilty of it too
![]() Chris
Re: IMPORTANT: critical upgrade to Fredo6 scripts (grayout mNice Job Fredo.
Quick turnaround fix. Simone. Re: IMPORTANT: critical upgrade to Fredo6 scripts (grayout mFredo, Any rules of thumb to guide us lesser scripters?
Apparently there is a limit of how many UI::Command objects one can create; 1000. So the rule of thumb would be to sparse with these. But the big no-no would be to never create UI::Command objects within the context handler. I hope one of the Googlers can add warnings in the API docs about UI:Command objects. Thanks Fredo for this very quick fix. Your plugins are part of my every day productivity, so it's nice to be able to enable them again. ![]() Thomas Thomassen — SketchUp Monkey & Coding addict
Re: IMPORTANT: critical upgrade to Fredo6 scripts (grayout mCheers for the fix
![]() Re: IMPORTANT: critical upgrade to Fredo6 scripts (grayout mSee the date, comming in 4 days?
Re: IMPORTANT: critical upgrade to Fredo6 scripts (grayout mI was reading that a sixth of May 2010...
Re: IMPORTANT: critical upgrade to Fredo6 scripts (grayout mHmmm..... Well, thats more logical. Guess I was trying too hard to figure it out :-)
Last edited by honoluludesktop on Fri May 07, 2010 11:26 am, edited 1 time in total.
RevertCurve is published on SCF. See http://forums.sketchucation.com/viewtopic.php?f=323&t=25710&hilit=plugin The two others are published elsewhere, but I will put them on SCF too. These are small scripts, but they each add +1 in the count of commands when you do a right click. Fredo
Re: IMPORTANT: critical upgrade to Fredo6 scripts (grayout mI have nothing to add but a humble pile of warm, clean compostable thanks
to all afflicted action figures who figured this out and fixed it. ~ Brooke
• Page 1 of 1
