How to cut hole in log wall?
General discussion related to SketchUp
Postby ntxdave » Mon Sep 18, 2023 6:56 pm
I know this is a really dumb question but I am having trouble cutting a whole for a door or window in a log wall. Here is an rough image of the wall type I want to cut holes into for doors or windows. When I try to do it, I have the wall as a group which is made up of a number of groups which are the logs. I am getting messages about the number of groups. Advice on how to do this correctly would be appreciated. Yes, I know this is a dumb question..........
Here is the simple skp file......
LogWall.skp
User avatar
ntxdave
Re: How to cut hole in log wall?
Postby Gus R » Mon Sep 18, 2023 10:29 pm
I usually subtract (solid tools) each group one by one while repeatedly pasting in place what I'm subtracting. If what's being subtracted is just repeating you can use a component instead of a group and then you only have to do it once and then make the component unique say for the header where it may not need to subtract the entire log. I see you also have a solid there which I'm assuming is a door and that has to extend beyond the front of the door. I always like to extend the solid beyond the limits of what I'm subtracting since if it's right on the edge it will result in a mess.
User avatar
Gus R
Postby ntxdave » Mon Sep 18, 2023 11:21 pm
Thanks for the reply Gus. I did not realize the object was hidden behind the wall. Here is an updated image that (I think) does a better job of showing what I am trying to do and what the results are.
I am not 100% sure I understand what you were telling me to do. :?
User avatar
ntxdave
Postby Gus R » Mon Sep 18, 2023 11:23 pm
If you open the attached example you can see how I created unique components for each log that's have identical openings. The white ones are unique. If you create a component you only have to cut that log once wherever there's an opening. With a group you have to cut them one by one.
Log Cabin Cutout Sample.skp
User avatar
Gus R
Postby Gus R » Mon Sep 18, 2023 11:24 pm
ntxdave wrote:I am not 100% sure I understand what you were telling me to do. :?
See attached example. It's in version 8 for anyone else to take a look.
User avatar
Gus R
Postby ntxdave » Tue Sep 19, 2023 12:04 am
Gus, I am feeling really stupid. I open your model and do not understand how you cut the holes/sections for the logs. I tried doing it with only one log at a time and got the same message I showed in my last post. What the heck tool did you use to cut the logs?
I have used SU for several years now and have not had this problem before. :? :?
User avatar
ntxdave
Postby Gus R » Tue Sep 19, 2023 12:16 am
I'm using the native solid tools. Should be the fourth icon that says "subtract" on mouse over.
User avatar
Gus R
Postby Gus R » Tue Sep 19, 2023 12:19 am
First you select the solid you want to subtract. Then click on the subtract icon and then click on one of the logs.
User avatar
Gus R
Postby Box » Tue Sep 19, 2023 12:38 am
Nested groups are not solids, so your group of groups cannot work with solid tools. You must either explode the log groups into the parent group or explode the parent group and do multiple subtractions, one log at a time.
You also have an extra couple of misaligned logs at the bottom.
So here in this gif, I delete the extra log, explode the log groups creating a single solid then subtract the 'hole'. You could regroup your logs after, loose to groups would do it in a click or two.
User avatar
Postby ntxdave » Tue Sep 19, 2023 1:13 am
Ooooh how dumb am I, I was using the subtract wrong. Now, another dumb one: if I want to subtract from multiple logs, do I have to recreate the subtract object for each log one at a time? Is there a way to subtract from multiple logs at once?
User avatar
ntxdave
Postby Box » Tue Sep 19, 2023 1:17 am
Use Trim.
User avatar
Postby ntxdave » Tue Sep 19, 2023 1:24 am
Ooooooooouch - Box that is to simple! I am feeling dumber by the hour. :roll:
User avatar
ntxdave
Postby Box » Tue Sep 19, 2023 1:27 am
It's worth noting that this Trim function is broken in 2023, you have to reselect the tool each time.
But I suspect you aren't working with 2023 anyway.
User avatar
Postby ntxdave » Tue Sep 19, 2023 1:59 am
Box wrote:It's worth noting that this Trim function is broken in 2023, you have to reselect the tool each time.
You are right. I am using 2020. :thumb:
User avatar
ntxdave
Postby Gus R » Tue Sep 19, 2023 2:33 am
Don't worry. I was stumped with the subtract tool at first since I was using Bool Tools for a long time.
User avatar
Gus R
Postby ntxdave » Tue Sep 19, 2023 3:04 am
Box, what is the tool on your toolbar next to the eraser (the one you clicked on to delete the object you used for the trim and subtract functions)?
I was going to try to modify my main toolbar to include that tool but I cannot seem to get to the option to modify a toolbar. I cannot get the ability to edit a toolbar to show up.
BTW: I tried both of the options that you showed in your videos and got them both to work. :thumb: :thumb: :thumb: :thumb:
User avatar
ntxdave
Postby Box » Tue Sep 19, 2023 3:22 am
That Icon is Delete from the 'Standard' toolbar.
This thread has a gif showing how to make a custom toolbar from about 9 years ago.
viewtopic.php?f=15&t=59701&hilit=+toolbar#p543863
User avatar
Postby numerobis » Sun Sep 24, 2023 11:50 am
You could also use Eneroth Solid Tools which support preselection of multiple objects...
https://extensions.sketchup.com/extensi ... olid-tools
numerobis
Postby ntxdave » Sun Sep 24, 2023 3:52 pm
Box wrote:That Icon is Delete from the 'Standard' toolbar.
Thanks for the link but I could not find a toolbar that had the delete icon.
numerobis wrote:You could also use Eneroth Solid Tools which support preselection of multiple objects...
Thanks for the link. That plugin is not available via the Sketchucatiob Plugin store.
User avatar
ntxdave
Postby Gus R » Sun Sep 24, 2023 5:07 pm
Thanks Box. I finally expanded my use of Sketchup's solid tools. Got stuck in a routine.
User avatar
Gus R
Postby numerobis » Mon Sep 25, 2023 1:12 am
ntxdave wrote:Thanks for the link. That plugin is not available via the Sketchucatiob Plugin store.
https://github.com/Eneroth3/Eneroth-Sol ... s/releases
numerobis
Postby Box » Mon Sep 25, 2023 1:32 am
ntxdave wrote:Thanks for the link but I could not find a toolbar that had the delete icon.
User avatar
Postby ntxdave » Mon Sep 25, 2023 1:42 am
Thanks Box, I will have a look.
BTW, is there a way to add the bottom view to a toolbar?
User avatar
ntxdave
Postby Box » Mon Sep 25, 2023 1:47 am
Not in the older versions, but you can make a keyboard shortcut.
User avatar
Postby ntxdave » Mon Sep 25, 2023 2:16 am
Again, thank you very much. I make a new small toolbar that has the Erase, Undo, Redo and Model Info icons. I wanted to place it along the side bar. I also tried to set it do double wide but it would not allow me to do it in that position. Am I missing something?
I will also add a shortcut for the Bottom view. :)
User avatar
ntxdave
Postby Box » Mon Sep 25, 2023 2:21 am
ntxdave wrote: I also tried to set it do double wide but it would not allow me to do it in that position. Am I missing something?
No you aren't missing something, the toolbar won't do double wide when docked, even though the Large Toolset does. It has been a complaint for many years. And you can't put the large toolset across the top.
Far be it for us to question the design gods of the UI, they obviously know something we don't.
User avatar
Postby ntxdave » Mon Sep 25, 2023 2:38 am
Added.........Alt+Shift+B
Again, many thanks. I had a bad day on the SketchUp forum so this was something very positive. :D
User avatar
ntxdave
Postby ntxdave » Mon Sep 25, 2023 5:11 pm
Box, thanks to your advice/info I was able to modify the Large Toolbar and add some functions (including the erase tool). Here is what I now have in the top section of the Large Toolbar.
Also downloaded the Eneroth Solid Tools plugin for dealing with cutting window and door wholes in my log cabin walls. Like it better than the standard tools (for this situation).
Again, thanks for your feedback and assistance. :thumb:
User avatar
ntxdave
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Discussions
cron
Who is online
Users browsing this forum: No registered users and 6 guests
