Quick Tip on drawing rectangles 'from a center point.'
General discussion related to SketchUp Pro and Make
Postby chippwalters » Fri Jun 02, 2017 5:51 am
I know Fredo has a tool for this, but I sometimes find it's more of a hassle, especially when it's trying to snap to other geometry. I just learned this recently (after many,many years of SU) showing even an old old dog can get lucky and find a bone sometime ;-)
Interested if anyone else has a better way...
User avatar
chippwalters
Premium Member
Premium Member
Re: Quick Tip on drawing rectangles 'from a center point.'
Postby Box » Fri Jun 02, 2017 7:44 am
Use the corner grip and you can do it in one go.
As a side note, if you want a centered square you can use the polygon tool set to 4 sides. Ctrl will toggle the orientation.
User avatar
Postby pilou » Fri Jun 02, 2017 9:48 am
Draw any rectangle
Draw a diagonal
Group the diagonal (by ShortCut : Menu Edit Create a Group)
Move the rectangle from the middle of the diagonal to the "Point" wished
Size as wanted :ugeek:
Oe maybe something like this
Make a Component Rectangle with Axes at intersection of Diagonals
load at any time on the Point wanted
Size as wished! :mrgreen:
etc...
Speedy Galerie
User avatar
Top SketchUcator
Postby chippwalters » Fri Jun 02, 2017 10:03 am
Thanks for the tip!
User avatar
chippwalters
Premium Member
Premium Member
Postby rawbee » Wed Jan 09, 2019 3:55 am
R key for rectangle, then hold down the control key
rawbee
Postby Dave R » Thu Jan 10, 2019 3:03 pm
rawbee wrote:R key for rectangle, then hold down the control key
That became available after this thread started. And you don't need to hold Ctrl. Just tap and release.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: obakenko and 7 guests
Visit our sponsors:
