issue with rendering lines
Found a bug in LayOut? Report it here
Postby pibuz » Fri Oct 15, 2021 8:10 am
Hi to the community! I'm an old time user of SketchUp but a very recent user of Layout, which I love (like all loves, it has something to be adjusted to work perfeclty, but it's worth it).
I recently noticed a misrendering of very close lines when using the vector modes. I'd like to know if it's a bug or something I'm doing wrong, since I usually use layout for technical specifications and I need to use vector mode in most cases.
I'm attaching some images. Basically, randomly in the viewport, some very close lines are distorted (vertical lines come to be inclined).
Can anybody point me to a solution?
Thanks in advance!
pibuz
Re: issue with rendering lines
Postby orbital » Fri Nov 19, 2021 1:40 pm
Are you still experiencing this problem?
Are you able to share the Layout file?
orbital
Postby pibuz » Fri Nov 19, 2021 5:58 pm
Hi Orbital! Yes, still experiencing,
here are the files! Will you have a look at them?
Thanks in advance!
https://we.tl/t-3IvHPNk19Z
pibuz
Return to LayOut Bug Reporting
Users browsing this forum: No registered users and 8 guests
