Export to DWG 2018 - Student version
Found a bug in LayOut? Report it here
Postby JGA » Mon Feb 25, 2019 3:23 pm
When I export from layout 2019 to the DWG 2018 file format, AutoCAD reports it as a student version.
A student version of DWG will print a watermark onto all AutoCAD drawings.
This issue doesn't appear when exporting to DWG r14 version
Regards,
JGA
JGA
Re: Export to DWG 2018 - Student version
Postby Dave R » Mon Feb 25, 2019 3:55 pm
Not a LayOut bug. It was explained here
Global Moderator
Postby JGA » Mon Feb 25, 2019 4:05 pm
Dave R wrote:Not a LayOut bug. It was explained here
Thanks for replying on this & the SketchUP forums.
I reckon it is a bug, as the Student Version watermark isn't created from Layout with other versions of DWG.
The watermark is like a virus, and "infects" any drawing that the student version DWG is inserted into.
We had a problem a number of years ago with a new start using presentation DWG blocks in production drawings that he created, while a student.
All looked fine till we started printing - when it looks like our business was using student copies of AutoCAD for business use.
Regards,
JGA
JGA
Postby Dave R » Mon Feb 25, 2019 4:12 pm
From what Trent has said in that post and elsewhere, if this is a bug, it is affecting more than just LayOut. Many other applications apparently have the same "bug".
Global Moderator
Postby pbacot » Mon Feb 25, 2019 6:21 pm
Interesting. So SketchUp changed and now ACAD tags files to embarrass the SU user. So why can't SketchUp change back?
MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
Top SketchUcator
Postby JGA » Mon Feb 25, 2019 6:37 pm
pbacot wrote:So SketchUp changed and now ACAD tags files...
It's not aimed at SketchUP users in particular, it's people using the "free" student version of AutoCAD in a business environment.
There was a spell that Autodesk didn't use the watermark, but they are back with the 2019 version of AutoCAD.
Regards,
JGA
JGA
Postby pbacot » Mon Feb 25, 2019 6:51 pm
Well it seems to be targeting anyone making dwg files in some non-AutoDesk software.
OH I thought it was caused by later SU versions. In the explanation someone said "save it as 2013".
They mean save it as ACAD 2013 dwg, I guess, which is a good precaution. Otherwise your consultants will believe you are using a student version of AutoCAD.
Top SketchUcator
Return to LayOut Bug Reporting
